Cooling Fans
Old Oct 6, 2011 | 09:56 PM
Rivera_TL's Avatar
Cooling Fans
My passenger side fan hasnt been working for a while, and today while driving my other fan stopped working and my car started to overheat..the driver side fan comes on sometimes if i give it a little push, anybody know how i could fix this? Thanks
Old Oct 7, 2011 | 11:49 AM
01tl4tl's Avatar
the passenger side fan is On with AC on - does that happen?
driver fan is on with temp sensor as needed for a minute when sitting at lights
and with ac on it runs full time
If the driver fan runs several minutes after shutdown- it needs a sensor
may run 1-2 minutes on a warm day but not 5 to 10 minutes- thats sensor failure
hard to push blade--coaxes it into running = bad motor
50 bucks aftermarket- direct replacement part, no sweat, can buy with a new blade attached or not
call local parts stores, that motor fits millions of hondas
Just make sure you get the same blade--count the number of blades on current setup
driver side is different blade
Old Oct 7, 2011 | 02:54 PM
Rivera_TL's Avatar
Thanks, and the sensor is on the passenger lower side of the radiator right?
Old Oct 8, 2011 | 01:57 PM
Rivera_TL's Avatar
Idk if it makes a difference but if i touch the fan itll start to spin and then stop?
Old Oct 8, 2011 | 10:26 PM
01tl4tl's Avatar
thats a nearly dead fan motor and its dangerous, as it may stop with power running to it!
the sensor is on lower pass side corner,,
on 99s its on the thermostat housing on top of engine
Im not sure when the production was changed- with your 00??
look for the thing with 1 wire going to it, if its not there look at the other place~
Old Oct 9, 2011 | 03:27 PM
57 Handyman's Avatar
01tl04tl...I thought the single wire sensor is for the temp indicator. Don't the fan sensors have two wires and a larger connector?
Old Oct 9, 2011 | 06:25 PM
Rivera_TL's Avatar
Just put in my new fan motor and wow what a world of difference, do you think the motor is whats wrong with my other fan too since it doesnt spin?
Old Oct 9, 2011 | 07:39 PM
01tl4tl's Avatar
it doesnt turn with the ac on- or by hand??
when power supplied by main fan?
fuse replaced- relay swapped?
Doh- I bet it is 2 wires for fan sensor,,too many cars in my head
there is only 1 sensor on the bottem corner of the rad- hows that ?!
Old Oct 10, 2011 | 08:22 AM
Rivera_TL's Avatar
The relay and the fuse are fine, checked em yesterday..i can spin it by hand so its not locked up, i just dont want to go buy one thing and then it be another
Old Oct 10, 2011 | 11:58 AM
01tl4tl's Avatar
use power from the other fan to test it,
or use a set of small jumper wires you keep in the toolbox for such occassions~
have you tested for power at the fan connector with ac on?
Old Oct 11, 2011 | 11:40 AM
Rivera_TL's Avatar
No, im gonna have to try that when this rain stops..thanks ill let you know what the turnout is
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
hashbrown
Sep 29, 2015 12:13 PM
dirleton
Sep 29, 2015 08:26 AM
