burn to much oil
Old Apr 1, 2010 | 06:59 PM
myTLgoesBWAAH's Avatar
burn to much oil
wats up, just a uick question? does anyone elses tl burn alot of oil! i asked a question not to long ago bout vtec kicking in late so i checked i got NO oil!!! wtf my car gobbles up oil! lucky nothing happened! so is there a reason why i burn so much oil?!>help PLEASE
Old Apr 1, 2010 | 09:05 PM
anyone?????
Old Apr 1, 2010 | 10:05 PM
ANC297's Avatar
Bonki' Ehrite!
Like, NO oil at all?
The engine might burn up a little bit, but it should not be anything serious...
If I were you I'd check for leaks. Make sure the drain bolt is tight, with a metal washer, make sure oil filter is on tight, etc.
Old Apr 1, 2010 | 10:25 PM
MOBB's Avatar
Is it normal for the TL to take some oil? I find myself putting in a quart after 5k to bring it back to full.
Old Apr 1, 2010 | 10:44 PM
ANC297's Avatar
Bonki' Ehrite!
My car stays just about full all the time...My dads car burns a little off, its a 03 tl-p. So I would assume that as long as you are not leaking oil, and you are conscious to keep an eye on it, you'd be alright.
Old Apr 2, 2010 | 07:25 AM
NSXNEXT's Avatar
How often do you check fluid levels? Who does your oil changes?
How long ago did you last check the oil level?
Old Apr 2, 2010 | 08:20 AM
well i usually do mine oil changes everytime my maint light comes on, but yeh i have NOOO oil i couldnt believe it, i checked the dip stick about 5 times its clean!!!!! i didnt see no leaks the oil filter it on properly, the bolt is on properly! i actually got scared! i had no idea my car burned so much oil!
Old Apr 2, 2010 | 09:53 AM
fsttyms1's Avatar
My type-s motor uses about a quart in my 12-15k intervals. I typically replace the filter and top off the oil around 7500 (at which point its down around half a quart)
If your TL is using a lot of oil, the first things to look for are leaks, from the valve cover gaskets, oil pan, oil filter and a over looked one the Rear Main Seal. If none of them are leaking have a compression/leak down test done. You may be burning it.
Old Apr 4, 2010 | 03:47 PM
smartypants's Avatar
Hi TLers :
Yeah, me too !
My 99 burns about a quart (liter) every other month. It doesn't seem to come out the tail pipe or leaking out on the ground. It just seems to consume it somehow.
Anyone else have this issue !
smartypants
Old Apr 4, 2010 | 06:07 PM
jdjohn84's Avatar
2003 TL-S w/Navi NBP
Must be all that red-lining and using dirty oil...bad for the rings
IBankMouse
Jun 13, 2020 12:53 PM
calrow
May 3, 2017 10:21 PM
Thuneau
Oct 3, 2015 04:19 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
