Help With DIY Amp and Subwoofer install
Old Aug 11, 2008 | 10:41 AM
JRhodes88's Avatar
Need an OEM lip kit on my
This is what i want to do:
I want to install my Kicker Amp and L5 subwoofer into my 02 TL type s. For now, i want to install the amp and sub to the stock Head Unit and keep all the Bose speakers in there for now. I understand that the Bose stock Subwoofer will not work if I install an Amp of my own, but that doesn't matter seeing that I'm putting in my own.
Are there any DIY threads that will help me with the wiring in the stock Head Unit? If not, can someone explain where to put the RCA and Remote cables? Maybe even a place to put the bass controller?
Old Aug 11, 2008 | 11:44 PM
jaycohh's Avatar
I recently put a new head unit (Jensen flip out VM93112) with a MTX amp and dual kickers..i can help you with the wireing to the head unit, as far as getting it to work with the stock, not really sure. My stock Bose sub still works. I put my amp contorller right next to the seat belt-clicker-in part (basicly my hip). i just ran the cables from my trunk, under my back seat (witch keeps coming unclipped for some reason now? If anyone knows how to fix that would be greatly appreciated) up the left side of the car under the plastic door sills and into the hood through a small hole located in the front door sill. Ill post pictures to help you out if need be just let me no. hope this helps!
Old Aug 12, 2008 | 01:44 AM
LacViet's Avatar
291hp & 245 tq @ 3.5psi
This link will help you how to install aftermarket sub +amp to stock head unit. Follow post #2 from Brewboy's instruction and it will work. https://acurazine.com/forums/audio-video-electronics-navigation-22/need-help-advice-anything-adding-sub-185395/
Note:
if you want both aftermarket sub and stock sub working, just plug the stock amp wiring hardness back after splicing for aftermarket amp.
Positive cable run from battery to the trunk: this link will help you how to run it. The picture won't work in this link but instruction is clear enough to follow: http://silverknight.clickhere2.net/sound.html
Old Aug 12, 2008 | 10:03 AM
JRhodes88's Avatar
Originally Posted by LacViet
This link will help you how to install aftermarket sub +amp to stock head unit. Follow post #2 from Brewboy's instruction and it will work. https://acurazine.com/forums/showthread.php?t=185395
Note:
The second link doesn't have any pictures. They are not loading correctly.
Old Aug 12, 2008 | 10:09 AM
JRhodes88's Avatar
Note:
Old Aug 12, 2008 | 10:23 AM
JRhodes88's Avatar
If you could PM me some pics or post them here that would be awesome.
Old Aug 12, 2008 | 10:25 AM
LacViet's Avatar
I know the pics in second link did not work, that's why I said: "
Just read the instruction, go to your car, open the hood, get a flashlight and look at the firewall on driver side and you will see.
btw, all information about audio is from here: https://acurazine.com/forums/audio-video-electronics-navigation-22/%2A%2Aaudio-video-diy-info-faq-all-models-%2A%2A-299065/
Old Aug 12, 2008 | 12:08 PM
JRhodes88's Avatar
btw, all information about audio is from here: https://acurazine.com/forums/showthread.php?t=299065
Ok, i just really wanted a picture of the hole to put the wire through. It's really hard to find it from instructions.
Old Aug 13, 2008 | 11:30 PM
jaycohh's Avatar
hope it helps
hope this can help..
engine bay:
[IMG](http://img292.imageshack.us/my.php?i...ture119vs6.jpg)[/IMG]
through the top of the door sill:
[IMG](http://img292.imageshack.us/my.php?i...ture120uq7.jpg)[/IMG]
the next door sill:
[IMG](http://img292.imageshack.us/my.php?i...ture127dm0.jpg)[/IMG]
run it under the back seat:
[IMG](http://img292.imageshack.us/my.php?i...ture130ol1.jpg)[/IMG]
from there run it to the hole between the back seat, and trunk right under the pullout thingy in the back seat lol..i cant show you how it should look in the trunk due to the fact that my amp is wired to my box pretty tight so i cant move it.
[IMG](http://img292.imageshack.us/my.php?i...ture121wm7.jpg)[/IMG]
and thats it...hope that helps sorry for the crappy quality, yes it was cell phone.
Old Aug 14, 2008 | 12:19 AM
david-s's Avatar
I have a planet audi amp. Will it make my system sound strange with just stock speakers and sub, or will i need to upgrade those as well?
Old Aug 14, 2008 | 01:00 PM
JRhodes88's Avatar
engine bay:
the next door sill:
thanks for the help, but i wanted to do something a little more professional. I dont want to see the wiring running through the door sill every time i open the door. It's kinda an eye-sore. I want to run the power cable through the firewall.
Old Aug 14, 2008 | 02:09 PM
fsttyms1's Avatar
Get under your dash with a flash light, Look up and to the left of the brake pedal. You will see a grommet with wires running thru. Take a cloths hanger and push it thru and get it from the engine compartment side. Tape your power wire to it and pull it thru.
Old Aug 16, 2008 | 08:37 AM
pimpassacura's Avatar
In order for it all to work your goin to have to tap into the rear speakers with a line out converter so u can plug in the rca's. factory headunit dont have rca outputs
Old Aug 18, 2008 | 02:29 PM
k1ng87's Avatar
what do you mean by tapping into the rear speakers with a line out converter....I just bought a sub and amp and want to same type of install as JRhodes
Old Aug 18, 2008 | 07:49 PM
LacViet's Avatar
There is no need to tap into the rear speakers! The TL, or at least TL-S already has separate amp for the bass so just tap into sub signal wire before it goes into factory sub amp and voila, great sub signal. Adding sub+amp and tap into rear speakers using line out converter is pointless, imo.
K1ng87: just follow the intruction in the links I provided above and you should be fine. I follow the instruction when I add aftermarket sub +amp few months ago and they are working perfect.
Old Aug 20, 2008 | 11:24 AM
k1ng87's Avatar
how do you remove the back seat?
Old Aug 20, 2008 | 01:23 PM
k1ng87's Avatar
and where is the stock amp located when i remove the back seat?
Old Jan 27, 2013 | 04:29 PM
bakers13's Avatar
How do I take out rear speaker cover?? I'm stuck
Old Jan 27, 2013 | 05:31 PM
MilwaukeeDave's Avatar
Pull up on it.
AndrewS
19
Mar 14, 2024 06:59 PM
cycdaniel
Dec 17, 2019 10:58 AM
TxRzrBk
Sep 17, 2015 01:07 PM
Pegon95
Sep 15, 2015 01:54 PM
3GTLOwns
Sep 9, 2015 09:51 PM
