well ladies... the time has drawn near....
#121
B A N N E D
so i'm in the process of ordering the UR crank pulley from exelerate, and i'm looking at intakes so i can grab both things at same time, i'm wanting the injen intake, but it says :
Color Polished
Filter X-1014
Notes Race Division Intake
Vehicle Notes Excl 2003 Manual Transmission
what's the deal? why wouldn't it fit the 6spd?
Color Polished
Filter X-1014
#123
B A N N E D
if you reuse the VSA tb (that extra one you see on the S's) then yes it will fit, but if you delete it (which you should if you don't plan on using it) then you will need the manual intake system (but a spacer pipe, with some couplers would works also to delete that tb)
#124
and no the tranny does not really matter as far as the intake system, it was the additional options that matter as to what intake is needed
#134
now i'm waiting on my injen cai, and my yokohama avid v4s
the chair was the girlfriends parents, it was free haha
#135
B A N N E D
pulley is easy enough to change out, as long as you can get the crank pulley bolt off, should just slide right off and back on with no more then a little wiggle
and btw those tires are not very good in the snow
, could be better, but not horrible though; cause they are what i got on mine
#137
B A N N E D
but yeah for that price they are not too bad, and they seem to wearing quite good also on mine (but i don't know how many alignments i have done though
![what](https://acurazine.com/forums/images/smilies/what.gif)
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
and there is somewhere around 10 k on them, with rotating each oil change
#139
it's a beautiful day outside, i figured i'd snap some shots of the engine, and some work that i'm going to have to do.
it appears that they cut the harness when removing the engine, so i'm assuming i'm going to need a type s harness? cause i've only got base harnesses
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1470.jpg)
where my brother and i removed the timing covers to change the belt without air tools haha that was a nogo, he's gonna bring his air gun and compressor this weekend so we can finish the job and pop the light weight crank pulley on.
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1471.jpg)
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1472.jpg)
throttle body is dirrrrrty. looks like i have some cleanin to do. (it's gonna have to come off when i do valve adjustment anyway.) where is this VSA TB? this TB looks almost like mine?
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1473.jpg)
here some tranny shots, parts are lookin pretty rusty.
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1474.jpg)
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1475.jpg)
#140
B A N N E D
vsa throttle body is an additional one, that sticks out furthe then the normal tb, and you did not proably get it with the motor, it is geneally considered a seperate "item" from the motor itself
and about the harness, they are basically the same, just the vsa tb, and the irc is additional, and by the sounds of it you might be going with the vsa tb, so no need to worry about wiring for that, then the irc, might be easier to just run seperate wiring from the harness, and just reuse your origional harness, then trying to find a new harness![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
and i figure you should not really have an issue with wiring it yourself, probably did many wiring repairs on those planes
#141
B A N N E D
and the cutting of that harness is actually quite normal, faster to cut then actually disconnect it
, but yes that one does seem like it has been cut a little more then normally, but ethier way the harness is jacked
also make sure to do a cylinder leak down test on that motor before you go any further, want to make sure it is a decent motor first, then worry about fixing it up
![Sad](https://acurazine.com/forums/images/smilies/sad.gif)
#142
what is the IRC?
on the contrary, i have no real wiring experience because i was just a mechanic on the plane, i worked with the engines, we had electricians to do the wiring haha.
#143
B A N N E D
ah, so i don't have the VSA TB on this? that's a good thing then that's one less part i have to take care of haha.
what is the IRC?
what is the IRC?
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
and i guess i am use to, where you have to be able to fix basically anything, and not have specialist, especially for wiring
#144
might be the wrong acronym ![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
, but the intake runner control, that huge honking motor that is sitting on top of the rear valve cover, what that is connected to ![what](https://acurazine.com/forums/images/smilies/what.gif)
and i guess i am use to, where you have to be able to fix basically anything, and not have specialist, especially for wiring![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
#158
installed the shaft of the short shifter last night (all the other gear will go on during the rigging of the shifter cables)
the height of the shifter will probably be lower (plus the knob is pretty long to begin with) since it's sitting directly on the shifter assembly whereas we know it won't be the case when installed
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1530.jpg)
here you can see where everything is adjustable. are my settings right? the lowest setting for shifter height, but the highest on the shaft to get the best leverage/throw??
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1531.jpg)
#160
update. got some misc parts in from acura, bolts, gaskets and such, had some time on my hands and put things together.
edit: i also replaced the rear main seal
![](https://hphotos-snc3.fbcdn.net/hs658.snc3/32493_10150204616635007_671045006_12598097_6402522_n.jpg)
flywheel is on and torqued
![](https://hphotos-snc3.fbcdn.net/hs658.snc3/32493_10150204616625007_671045006_12598096_7873094_n.jpg)
clutch disc
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs618.snc3/32493_10150204616640007_671045006_12598098_5221915_n.jpg)
pressure plate
![](https://hphotos-snc3.fbcdn.net/hs618.snc3/32493_10150204616650007_671045006_12598099_274147_n.jpg)
now i took some more detailed pics of the tranny. one thing that concerns me is this right here. on the slave cyl, it looks like the boot is torn and such. i'm sure it shouldn't be like that right? if i get a new slave cyl will it come with a new boot for the clutch release fork?
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs618.snc3/32493_10150204620515007_671045006_12598263_1877542_n.jpg)
here's an undershot of the fork
clutch disc
pressure plate
![](https://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs558.ash1/32493_10150204616655007_671045006_12598100_6874331_n.jpg)
