well ladies... the time has drawn near....
Old 02-09-2012, 08:10 PM
  #681
AznWay's Avatar
Originally Posted by assclown
On the reverse lights, you mention connecting to the range switch terminal, and then plug into what? Are you talking about #15?
Is there a plug on the auto harness that fits that or do I have to manually pin them to the range switch?
Yes, #15 is where you connection #3 & #9 an it don't matter which way you do it.
There no Auto plug that fit that. You will have to go to junk yard an find that plug an it can only be found on manual engine harness. For Honda 99+ an Acura 2004+. I did try at 1st, but had no luck. So I just hookup some wire an use male quick disconnect an made it
Old 02-26-2012, 05:52 PM
  #682
2000 acura tl FPR
assclown's Avatar
I has cruise control!!!
Old 02-26-2012, 08:59 PM
  #683
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,394 Likes on 4,939 Posts
Old 02-27-2012, 02:47 PM
  #684
2000 acura tl FPR
assclown's Avatar
I'm still trying to locate the wire I need to tap into with the purple wire for richies harness. Forgive me for being ignorant. I've snapped some pics....
Old 02-27-2012, 08:12 PM
  #685
Srb
00 ssm
Srb's Avatar
The black w/ white stripe wire that goes to the ignition should be where purple goes. I think it's a little bigger guage than the other wires. Although I don't see it in your pic. My memory has turned into shit as well so don't believe everything I say. I'll take a quick look from under my dash later to make sure I know what I'm talking about.
Old 02-27-2012, 08:22 PM
  #686
Srb
00 ssm
Srb's Avatar
And yes, reverse lockout works. It's 3 and 9 because that's what it says in the instructions, it just doesn't really explain much on what to do.
Oh yea did you get the reverse lights to work? AznWay explained it correctly, I completely forgot about wiring up to the wires that went to the range switch for the reverse lights. It's been a while since I did everything lol
Old 02-27-2012, 08:45 PM
  #687
2000 acura tl FPR
assclown's Avatar
So you're talking about the black and white wire right here right? I'm splicing it, just cutting of some insulation and soldering the purple wire to the fully intact black/white wire right?
I have not gotten the reverse lights to work yet only because I don't have the ignition wired up yet. So I'm still using my auto trans range switch and I can't use the wiring for the reverse lights, but as soon as I get the purple wire hooked up I'll get reverse lights working.
Old 02-27-2012, 09:56 PM
  #688
Boosted...
WBA-01's Avatar
^^I think you need the heavier gauge wires on the other end of the switch.
Old 02-28-2012, 02:47 PM
  #689
AznWay's Avatar
Wrong area....
Here what you post to be looking for under steering wheel to top left area
here anyone pic almost same view
Mainly look for brown connection that your ignition plug
also was cruise control are to do??
Old 02-28-2012, 06:51 PM
  #690
2000 acura tl FPR
assclown's Avatar
Thanks AT, I found it this afternoon, saw the purple wire dangling in that area from when I cut it last year. I was able to solder the ignition wire and the clutch safety wires in and it works. so I now have clutch safety, however it makes a weird noise before it starts to crank over.
I wired up the reverse lights, two wires to the reverse sensor and then to pins 3 and 9 on the range switch plug in the engine bay. But when I put it in reverse with the clutch down and the engine running or the key in "on", Richie's module starts to make buzzing noises and if the engine is running it starts to rev to about 1100-1300. But I do see the reverse icon light up in the gauge cluster, but no reverse lights in the tails... could it be a bad connection? Any one have this issue?
Yes cruise was super easy. just clip pin 14, wire it to the lower clutch position switch and hook the other one up to ground and you have cruise.
Old 02-28-2012, 09:38 PM
  #691
AznWay's Avatar
When you hear noise coming from Richie module it mean you hookup backward.
BTW:
Thank for cruise control help
Old 02-29-2012, 04:17 PM
  #692
2000 acura tl FPR
assclown's Avatar
ah, Thanks, that fixed the reverse light and buzzing debacle. I guess I was reading the diagram on Richie's instructions wrong but it's all good.
Now on to the starting. It's making that noise like it won't crank over b/c the battery is low before it actually cranks over. Could it be an open wire? Could I have wired the clutch safety switch backwards?
Old 03-06-2012, 06:18 PM
  #693
2000 acura tl FPR
assclown's Avatar
I'm going to try getting a better connection for the wires. Do you know where I can get my hands on some pigtails? I can't find them on the acura parts sites and I know Richie has to get his (his harness comes with reverse lockout pigtails) from somewhere. I'd like to use the pigtails for both clutch sensors and reverse signal.
I've tried emailing junk yards and they say they won't cut wiring harnesses, they only sell them as a set.
Also, I'm thinking about wiring a hot wire to my fan timer. The fan timer pin 2 is connected to fuse #3 according to the wiring diagram but I'm looking all over in wiring diagrams and service manual to find a wire that connects to fuse 3 but I can't find it. Does anyone have an idea where I can tap into power for fuse 3 to go to the fan timer?
Old 03-11-2012, 11:14 AM
  #694
2000 acura tl FPR
assclown's Avatar
turns out I was reading the wiring pinouts wrong and the fan timer was indeed receiving power. nevertheless I have a new fan timer on order (that's the next step in troubleshooting) and we'll see if that works.
I've also got two other issues.
I've looked at the SRS reset vid and the guy moves so fast with that yellow plug I'm not sure where he got it from (plus it's for a civic) Is our plug located under the steering wheel? and if it is this plug, how do you undo it? It seems like it requires a special way to pull it apart
the other problem is when I have the auto trans range switch plugged in, there is no problems (only a CEL for "short in range switch" and obviously my reverse lights wouldn't work) but when I unplug the range switch, it seems I have an idle problem. Sometimes the idle will bounce between 800 to 1500 RPM (which is really annoying) or sometimes it'll idle at 1500 or it'll idle around 750.
anyone else have this problem?
Old 03-11-2012, 11:40 AM
  #695
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
you use the small yellow plug in the back of the drivers side fuse panel for the srs
Old 03-11-2012, 12:53 PM
  #696
2000 acura tl FPR
assclown's Avatar
Roger. Thanks!
Old 03-15-2012, 07:36 PM
  #697
2000 acura tl FPR
assclown's Avatar
Parts came in today. The fan timer fixed my issue now the fans work whenever they need to
The SRS reset worked, so the next light to troubleshoot is the ABS light.
I also need to fix the "gatling gun" sound when I try to start it before it actually cranks. as mentioned before it might be a bad connection.
Brakes are next on order, then power steering gear. I've also got an EVAP canister code so I need to fix that. Once all these issues are resolved my car is back to normal lol.
Old 03-27-2012, 11:33 AM
  #698
2000 acura tl FPR
assclown's Avatar
Oh, and for shits and giggles, and because I'm selling it to MoneyPit, I've hooked up my AEM EMS Series 2 to see if it works since I've changed the engine. It works great! I'm guessing the old engine was off in time...
Old 03-27-2012, 05:16 PM
  #699
civicdrivr's Avatar
I though MP had a Series 2 already.
Old 03-28-2012, 12:11 PM
  #700
KatabaticSaint's Avatar
What exhaust setup do u have? Sounds magnificent!
Old 03-29-2012, 09:15 AM
  #701
2000 acura tl FPR
assclown's Avatar
He does, he want's a backup I guess lol.
Old 03-29-2012, 09:17 AM
  #702
2000 acura tl FPR
assclown's Avatar
Maybe from inside the car, otherwise it sounds like absolute dog shit. When I had the shop do my exhaust when I was turbo, they deleted my resonator and I didn't catch it until the car was actually running right, by then it was too late. So I'm going to get around getting a resonator. Other than that, it's an XS header/Tsudo Axleback combo.
KatabaticSaint (03-29-2012)
Old 04-01-2012, 11:05 PM
  #703
2000 acura tl FPR
assclown's Avatar
changed the brakes yesterday, jumped on that steal of a deal BrakeMotive has and no more shaking in the steering wheel! I did have a seized rear caliper though :-/ luckily autozone had one in stock.
On the other hand, I found out why my ABS light is on in the dash, the ABS sensor wires are cut. I'll be getting around to replacing those. I'm sure I ran them wrong when I took the knuckles off the car.
Old 04-12-2012, 09:41 PM
  #704
kidduce's Avatar
Damn man, I've gone through your thread twice now. You must feel so much relieve after going through all that crap. Good for you.
Old 04-14-2012, 11:19 AM
  #705
2000 acura tl FPR
assclown's Avatar
Thanks and yes it is a blast to drive. I'd rather get my ABS sensors replaced and have a resonator installed before I rip on it though. I'd like to be able to stop better and not sound like shit lol.
Once power steering system is replaced I'll be refinishing these (I'm thinking hyper black) and saving up on some rubber for them.
Old 04-14-2012, 03:16 PM
  #706
n1njai's Avatar
Dang, you had to go through so much nonsense. Glad it's coming along positively though!
Old 04-14-2012, 05:13 PM
  #707
civicdrivr's Avatar
Old 05-07-2012, 06:51 PM
  #708
6mt swapped..smart
AnthraciteTypeS's Avatar
Thanks for everyone's responses in this thread, I now know how to hook up my reverse lights and make my cruise control work on my 6mt swap.. Howeverm, i am having an issue with my drivers side memory seat not working or moving forward when the door is open and someone wants to get into the back seat. The passenger seat however works fine..
Also, does anyone know what wires I need to connect to get the passenger side mirror to tilt when in reverse? Anyone chime in? THANKS
mossman77
1/2G MDX (2001-2013)
18
09-16-2015 12:21 PM
Skirmich
09-15-2015 06:41 PM
forrie
09-15-2015 09:57 AM
PortlandRL
09-14-2015 12:01 PM
ShyGuyMcFly83
ILX
09-11-2015 10:51 PM
Quick Reply: well ladies... the time has drawn near....
