P0700/1740 transmission code
Old Sep 9, 2011 | 06:06 PM
tanders's Avatar
Probably already a thread for something this but the search is timing out. I have a 2000 TL and it is coming up with a P0700 and P1740 code. Would someone tell me what those codes mean?
Old Sep 9, 2011 | 07:24 PM
01tl4tl's Avatar
google them or at the end of our diy master list is all the codes
or the other trans prob threads
codes are clues,, not a direct diagnosis
diy master: https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
what is the mileage, trans history? fluid smell? fluid changed?? oil jet kit installed?
trans ever warranty replaced (blue paint on bolt heads on trans)
Old Sep 9, 2011 | 07:32 PM
BN3DC2's Avatar
how did you get that code? you can go to autozone or any autoparts and ask them to run it for you for free...
Old Sep 10, 2011 | 01:17 PM
webmastir's Avatar
2003 TL
I doubt he just picked a couple random codes & posted about it
Old Sep 10, 2011 | 01:38 PM
Sperry's Avatar
2000 TL Black on Beige
The link to the codes is not working for me! Anyone else?
P1740 is popular on this forum.
4th gear pressure switch fault.
There is a thread floating about of a guy who cleaned his, and the code stayed away for a few months. He then replaced the switch. I just ordered the 3rd and 4th gear pressure switches [and a new fuel cap], $125 delivered. I'll post photos of the install.
Old Sep 10, 2011 | 01:45 PM
webmastir's Avatar
2003 TL
awesome. thx
Old Sep 10, 2011 | 04:17 PM
Sperry's Avatar
REad this:
https://acurazine.com/forums/3g-tl-2004-2008-93/110-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2004-2006-a-729149/
A-110: DIY Guide to replacing 3rd & 4th gear pressure switch for 3G TL (2004-2006)
Old Sep 10, 2011 | 06:52 PM
Sperry's Avatar
I took out both the 3rd and 4th gear pressure switches, hit'em with brake fluid, and reinstalled them.
Didn't see any screens. The switches have metal rings, like the transmission plug uses.
The plastic wire clip has a tab you push in when pulling the clip from the switch.
I pulled just three or four connectors and pulled the wheel well lining down, exposing the side of the transmission.
The 3rd gear switch has a heat shield over it; easy to remove with a 10mm socket w/extension.
There are little "3" and "4" numerals cast into the trans housing, indicating which switch is which.
Oh yea, I raised the car, put stands under it, and pulled the left front wheel.
I have pics, but will post them at a later time.
The new switches are still on order, but I reset the light for now, and will monitor mileage and drive cycles.
Old Sep 11, 2011 | 07:39 PM
Sperry's Avatar
3rd gear pressure switch behind X heat shield
A fault on the pressure switch pictured below can evidently cause the P1740 code.
Old Feb 14, 2012 | 08:56 PM
grahampham's Avatar
Similar situation
I'm having a similar problem with my 2000 TL... TCS and CEL are on, codes are P0740 and P1740. I have noticed a slight drag or slip between 3rd and 4th gear. Would cleaning the pressure switch help with the slip?
Old Feb 15, 2012 | 05:44 AM
Sperry's Avatar
We have the same car.
I found the best resuts after the 3x3 trans oil replacement.
Every year or 30,000 miles.
As far as cleaning, I bought two [still uninstalled] pressure switches. $100 delivered.
I cleaned the old ones, and still have not had the lights come back on.
Wanting to move forward without parts in hand, I cleaned only.
But consensus seems to be that because of the age of the car, I'd be best off replacing,
and that I'd notice the difference.
Your issue might want viewing at from both angles, but the oil would be my first look.
TypeS860
Jan 10, 2026 11:11 AM
Mike Pilipenko
Mar 26, 2024 09:21 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Skirmich
Oct 1, 2015 12:59 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
