View Poll Results: What am i doing
Making a Dog Cage
6.05%
Making a Roll Cage
1.42%
Making a (not true) Dual Exhaust
11.74%
Making a rear mount turbo setup
17.08%
Just sitting back drinking beer doing nothing.
19.57%
Adding a turbo up front
7.47%
A supercharger
6.41%
The box contains 3.5 parts
6.76%
Time Machine
16.73%
3.7 Build
6.76%
Voters: 281. You may not vote on this poll
Now what am i up to
Old 10-23-2013, 07:04 AM
  #1201
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Originally Posted by Karanx7
Ohhh this is an interesting development. Another ECU option, hmm...
So basically this ECU will work with a Gen 1 J series engine, so that would work well for the 2G TL cars.
But I'm not sure if our cluster uses the same signal as the 3G ECU. Definitely will keep an eye out for updates.
Since the cluster isnt needed for that ecu much of it may work? Ill find out
Old 10-23-2013, 07:05 AM
  #1202
fsttyms1's Avatar
Now to figure out why i get a fuel cut off at 6k and a cel......
Old 10-23-2013, 02:43 PM
  #1203
fsttyms1's Avatar
3.7 mated to a 6-speed hitting the 7k rpm.......
The noise, the power, the speed........
Old 10-23-2013, 05:12 PM
  #1204
Yikes's Avatar
Did you figure out the fuel cut off and CEL?
Old 10-23-2013, 07:08 PM
  #1205
fsttyms1's Avatar
^ See for yourself
Old 10-23-2013, 07:54 PM
  #1206
Yikes's Avatar
It sounds so much beefier than the 3.2.... words cannot describe
I am green with envy
Say... 600k later what ever happened to the 3.2 that was under the hood when you bought it?
Xxb005txx (11-04-2013)
Old 10-23-2013, 08:13 PM
  #1207
fsttyms1's Avatar
Too bad the camera cant capture the sound better. It is deeper sounding. I actually did the above in 3rd today
The original tl-p engine, sitting in my friends garage, engine i pulled out sitting in garage waiting for me to figure out what to do with it.
Old 10-23-2013, 09:23 PM
  #1208
2000 Acura TL
closetprisoner's Avatar
Old 10-23-2013, 09:28 PM
  #1209
fsttyms1's Avatar
Old 10-23-2013, 11:41 PM
  #1210
03 tls nc's Avatar
I know that sound clips never do justice but that sound wicked!!!!
Old 10-23-2013, 11:52 PM
  #1211
Your Friendly Canadian
Aman's Avatar
Received 1,485 Likes on 1,049 Posts
Old 10-24-2013, 12:13 AM
  #1212
HairyMonkey019's Avatar
Omfg.... I wish i could see this beast in person
Old 10-24-2013, 02:43 AM
  #1213
Unregistered Member
Karanx7's Avatar
Ehh, just remembered the 3G ecu uses DBW. I'd rather just figure out the tach for the EMS than convert the throttle.
What was the problem?
Also, are you using the stock CL-S6 ECU right now? How much power do you think you could free up with a proper 3.7L tune?
Old 10-24-2013, 03:08 AM
  #1214
Skirmich's Avatar
Received 1,017 Likes on 867 Posts
HOLY FUCKING SHIT!!! That shit is wacked..
Old 10-24-2013, 06:52 AM
  #1215
fsttyms1's Avatar
After talking to Robert (youngone501) adding the dbw pedal isnt hard, he did it on his accord.
The problem was the Throttle Position Sensor. WOT voltage was too high.
Yep, stock ecu. With some larger injectors and a tune im sure 15 maybe 20. Injectors are maxing out and its running rich, and with typical honda its pulling a ton of timing up top.
Old 10-24-2013, 10:30 AM
  #1216
tOny3's Avatar
Its nice to see what the j series can really do. Im appalled you have a huge passion with this build, if i had the time and another daily beater id prob invest into my own tl but its modding days are over. Money isnt an issue but the 2g tranny is unfortunately
Old 10-24-2013, 11:10 AM
  #1217
CCColtsicehockey's Avatar
Received 3,769 Likes on 2,543 Posts
Wow great work.
Can't wait till I can watch the videos at home.
Old 10-24-2013, 12:06 PM
  #1218
fsttyms1's Avatar
Old 10-24-2013, 04:37 PM
  #1219
David_Dude
Acura_Dude's Avatar
Old 10-24-2013, 10:34 PM
  #1220
deal with it
dreem1er's Avatar
Funny how with everything you've done it still sounds like a honda motor. You would think with the different parts thrown together in a Frankenstein way the motors tone would be different.
Still a good clip but too short. You need a 2-3 min video of you ripping up the streets up there.
Old 10-27-2013, 06:50 PM
  #1221
fsttyms1's Avatar
It does sound different from a 3.2 in person, The tone is deeper. You can hear it in the vid, but it still sounds like a J series, which it should. That is what it is.
Old 10-28-2013, 07:14 PM
  #1222
fsttyms1's Avatar
Here is another lil vid. Driving with my knees, shifting with one hand, holding camera with the other. Hard to tell in vid, but 2nd i was modulating throttle to about 2/3 to minimize wheel spin, Around 70 i start going up hill until i let off in vid for traffic ahead
The following 2 users liked this post by fsttyms1:
nats007 (10-29-2013), Stephen00TL (10-28-2013)
Old 10-28-2013, 07:32 PM
  #1223
Chapter Leader (Southeast Region)
Stephen00TL's Avatar
Old 10-28-2013, 10:10 PM
  #1224
fsttyms1's Avatar
Car go vroom vroom
Old 10-28-2013, 10:15 PM
  #1225
Skirmich's Avatar
And here I thought my fully Bolt-on J32A2 made some power... Its depressing to see this
Need to plan to do a 3.7 build next... minus manual trans obviously..
Old 10-28-2013, 11:02 PM
  #1226
Yikes's Avatar
You should try and set your camera up on a tri-pod and do a proper 0 to 60.
Old 10-28-2013, 11:37 PM
  #1227
Skirmich's Avatar
0 to 60 are easy he recorded post 80mph because its were the original engine start to struggle he went from 60 to 100 in no time compared to the stock engine.
Just by the video I can assure you his 0 to 60 must be in the low 5s high 4s < Completely bound to Tire Traction cuz that thing SLIPS!!!
Old 10-29-2013, 06:44 AM
  #1228
fsttyms1's Avatar
Originally Posted by Skirmich
And here I thought my fully Bolt-on J32A2 made some power... Its depressing to see this .
I know the feeling. My old 3.2 was fast (very low 13 car with good traction) This thing makes it seem slow in comparison. What the camera cant pick up is the feel and pull it has along with the responsiveness of the engine (you can see how fast it drops between shifts)
Old 10-29-2013, 06:55 AM
  #1229
deal with it
dreem1er's Avatar
Old 10-29-2013, 07:37 AM
  #1230
fsttyms1's Avatar
I have the mother of all tripods for cameras . But vids are random right now. 0-60 isnt going to happen anytime soon. The snow tires will be going on soon. If my 255s cant get traction, there is no way my 215 snows will
Oh and 0-60s are for little kids. My power is designed for going around a track where you turn left and right
Old 10-29-2013, 07:38 AM
  #1231
fsttyms1's Avatar
where the 3.2 (even modded) started to slow, this thing just keeps pulling.
Old 10-29-2013, 11:11 AM
  #1232
deal with it
dreem1er's Avatar
now thats a tripod. You shold make an extension with a cup holder like ricky bobby.
Old 10-29-2013, 05:08 PM
  #1233
fsttyms1's Avatar
It works very well Nah, i want to add the rope Liquorice holder from the roof like in waynes world
Old 11-03-2013, 10:45 AM
  #1234
MilwaukeeDave's Avatar
I have 2 GoPros with mounts. I can come up and we make some awesome videos.
Old 11-03-2013, 01:01 PM
  #1235
3.2TLc's Avatar
2 GoPros ....mounts, redline revving, tires squealing, gear banging hot video !!!
Yeah baby, shall we all come together to the orgy ?
Old 11-03-2013, 07:08 PM
  #1236
fsttyms1's Avatar
Works for me
Old 11-03-2013, 07:10 PM
  #1237
fsttyms1's Avatar
Just shy of 2k miles and all is going good. Fuel mileage hasnt been too bad. Just got 435 from this last tank of hwy.
Old 11-03-2013, 08:19 PM
  #1238
crazyasiantl's Avatar
I came here for more videos, not fuel economy
dreem1er (11-10-2013)
Old 11-03-2013, 10:25 PM
  #1239
deal with it
dreem1er's Avatar
Do it...that by far would the best mod ever. And cheap a random bowl with a hole cut in. But don't forget to paint the car blue with a small flame behind the front tire.
It would totally be excellent and ready for party time.
Old 11-04-2013, 07:50 AM
  #1240
fsttyms1's Avatar
Quick Reply: Now what am i up to
