fuse keeps blowing
Originally Posted by Vijay TL
i heard there is a shortage (electrical)...the heated seats fuses keeps blowing..i replaced it several times.
but this is related to the heated seats..any other advice?
First thing you do is disconnect both seats and see if the fuse blows. Then connect one seat at a time and see which seat blows the fuse. You cannot guess a fix. There could be a pinched wire in one of the seats, or the heat wire has broke and is touching metal in the seat. Try my method and report back.
Heated seat fuses keep blowing -- here's why...
Originally Posted by phmeyer
ANSWER: The heat pad is bad -- mine was replaced very easily by the dealer and fixed the problem. I thought at first the switch was bad but it was the actual pad that was bad.
what did this cost you to replace at the dealer?
Nothing -- it was under warranty. Took 2 days, however.
Acura604
20
08-05-2017 12:55 AM
xsilverhawkx
09-28-2015 06:51 PM
ripit
09-26-2015 06:19 PM
