fuse keeps blowing
Old Dec 11, 2006 | 06:55 PM
Unhappy fuse keeps blowing
i heard there is a shortage (electrical)...the heated seats fuses keeps blowing..i replaced it several times.
Old Dec 11, 2006 | 07:12 PM
Trackruner228's Avatar
I know a penny in the cigarrette lighter can cause the fuse to blow if its on the same circut. So that could be it.
Old Dec 11, 2006 | 07:40 PM
Blazin_TL's Avatar
Registered User
Old Dec 11, 2006 | 08:40 PM
but this is related to the heated seats..any other advice?
Old Dec 11, 2006 | 08:51 PM
dwest1023's Avatar
First thing you do is disconnect both seats and see if the fuse blows. Then connect one seat at a time and see which seat blows the fuse. You cannot guess a fix. There could be a pinched wire in one of the seats, or the heat wire has broke and is touching metal in the seat. Try my method and report back.
Old Dec 11, 2006 | 09:17 PM
phmeyer's Avatar
6th Gear
Heated seat fuses keep blowing -- here's why...
ANSWER: The heat pad is bad -- mine was replaced very easily by the dealer and fixed the problem. I thought at first the switch was bad but it was the actual pad that was bad.
Old Dec 12, 2006 | 09:01 AM
what did this cost you to replace at the dealer?
Old Dec 12, 2006 | 09:19 AM
fsttyms1's Avatar
Agree. Take teh time to find out whats wrong first. That will be a better idea of what it will cost to fix.
Old Dec 13, 2006 | 10:42 AM
phmeyer's Avatar
6th Gear
Heated seats fuses keep blowing...
Nothing -- it was under warranty. Took 2 days, however.
Old Dec 13, 2006 | 10:42 PM
djdonte's Avatar
the stealership told me that the seat heaters were not covered under warrenty
Old Dec 13, 2006 | 11:41 PM
MrAlex's Avatar
99 SSM Tl
They is a diy on the forum check it
Acura604
20
Aug 5, 2017 12:55 AM
hashbrown
Sep 29, 2015 12:13 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
ripit
Sep 26, 2015 06:19 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
