Finally started ordering parts for the swap**work starts pg 9**
Got my first piece in today
03 CL-S cuphodler $37.00 (shipped) off eBay. It's a little dirty but I'm going to take it apart and clean it real good.
There was still a piece of broken glass in it
Also have a shift boot on the way. I'm going to reuse the stock knob for now.
I'm about to put in my order with acuraautomotiveparts.org for all the other stuff I need besides the trans itself.
instead of buying parts from acuraautomotiveparts.org try oemacuraparts.com.
they have the cheapest price+shipping on parts that i have found. comparing all the acura parts sites and honda parts sites. even cheaper than dealer with shipping and not calculating the cost of gas or tax!
for example, im buying a few nuts and bolts and im saving a few dollars and its being delivered to my door
just trying to help you save much dollars
if you need to know about the clutch pedal assembly, remmeber, you can use the assemblies from an old civic, rsx, or cl from what I know so far. You can modify the brake pedal as well for the new rubber sleeve that fits over it (for the 6-speed). If needed, I have a parts list you've probably seen before, but it gives you more options of different parts than the standard list you see here.
Yea I meant to ask in my original post about the cheapest place to get the OEM parts. I'll add everything up there and see what it comes out to be. The shipping doesn't really matter if it takes a little while b/c I still need to order the tranny and work out with you when we are going to try and do everything.
I posted on the module thread and he (Richie) said he didn't know if the AV6 or TL module would work since mine is the 99 4 spd.
And I didn't mention that I am keeping the TL-P motor so it will be even less work. Just bolting up the tranny and everything on the inside.
My complete parts list:
03 CLs-6 speed manual
03 CLs-6 Flywheel 22105-PGE-305
03 CLs-6 Clutch Assembly 22105-PGE-305 (unfortunately right now there aren’t many options for aftermarket clutches) - $223 (for clutch and flywheel)
03 CLs-6 Flywheel bolts (Qty 8) 90011-PGE-000 - $2.08 x 8 = $16.64
03 CLs-6 Shifter and cables. 54100-S3M-A01 - $59.03, 54310-S3M-A01 - $109.49
03 CLs-6 Gauges
03 CLs-6 Hydraulic Clutch lines. 46960-S3M-A01 - $4.31, & 46970-S3M-A01 - $6.40
03 CLs-6 Trans mounts (2 of them) 50806-S3M-A03 - $37.89, 50805-S3M-A03 - $26.79
03 CLs-6 Cup Holder 77230-S3M-A01ZA - $81.80 – eBay - $37.00
03 CLs-6 Parking brake 47105-S3M-A04ZA - $47.33 and to go with it,
Spring 47537-671-670 - $1.29, Nut 47522-594-000 - $0.73, Equalizer pin 47365-538-000 - $0.47, Equalizer 47360-SB2-000 - $1.36
BRAKE PEDAL ASSY 46600-S3M-A51 - $51.26
If you decide to buy it new you will need the pedal and mount CLUTCH PEDAL 46910-S3M-A01 - $46.80 & CLUTCH PEDAL BRACKET 46990-S84-A01 - $18.98
MASTER CYLINDER ASSY 46922-S3M-A01 - $52.58 & Clutch Fluid Tank 46965-S5A-013 - $14.61, & Clutch Hose 46961-S3M-A02 - $20.49
Shift Boot 83414-S3M-A01ZA - $91.61 – eBay - $11.94
Shift Knob 54102-SL0-023ZB - $161.25 – reuse stock
Headers – reuse XS
Richie's Module ~$700
After I add everything up on that list it's right around what the dealer wanted for the new auto tranny
03 CLs-6 Gauges
Headers – reuse XS
InNeedOfa6speed (09-09-2012)
I just tried it out and though the items are a few dollars cheaper each, they charge $45 more for shipping the same items (other one charges $21 and it charges $66).
My site's a total of $18 cheaper
Your Friendly Canadian
Received 1,492 Likes
looks much nicer.
good luck with the swap
The ICEMAN
Originally Posted by Rajca
i know but do the Tl have a notch in one of the pipes bc for the cl mt that what your gonna need
I'm reusing the XS headers I already have on there. They have the notch and will fit the CL-S trans.
I'm going to take a bunch of photos as we do it. I'll see what I can come up with as far as a DIY. Again, I'm not doing the whole motor swap, just the tranny for now.
Originally Posted by Bob_F
Best of luck with the swap!
Take a lot of photos.
Originally Posted by phee
Please Make A Diy!!!!!
This isnt something you make a DIY of. Its not like installing a CAI. If you really need a step by step DIY you shouldnt be doing it.
I broke alot of it down for every one, included part#s and pics. And i also stated that if you were honestly attempting it and ran into issues i would help out as much as possible (via PM or a thread on it)
Originally Posted by fsttyms1
Not to sound like a ASS, but..........
please continue with a DIY.
I am interested in changing out the handbrake set up as the CL-S 6 has, having the parking break on the floor is :theghey:. I would love to switch out the center console just for the handbrake...
Originally Posted by johnr5
dude. PM me... I can make it cheaper for you with the list I have. lol
Post here so everyone can see.
the stupid flywheel and clutch are expensive
