6 speed conversion, 2nd problem 9/2/17
Old 06-04-2006, 07:09 PM
  #721
ChucksCL-S's Avatar
Kris don't overheat your new masterpiece!
Old 06-04-2006, 10:18 PM
  #722
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Yep i wont. Im not sure what the CL-S 6 uses to control the radiator fans. the autos use a actual control unit and the manual motor doesnt have that. I need to do some good reading of the manual to figure it out. That and what keeps draining my optima battery dead in 2 days time
Old 06-05-2006, 10:23 PM
  #723
I need 2 more gears
sbuswell's Avatar
how old is your battery?
Old 06-06-2006, 09:12 AM
  #724
fsttyms1's Avatar
2 years. its not age. there is something that is on as far as power goes thats draining it
Old 06-09-2006, 12:11 PM
  #725
fsttyms1's Avatar
So im trying to replace the passengers sideengine compartment to dash harness and its a biotch. I may have to dump the 134 and take out the heater blower ect just to gt it out Any one know some one with a magic wand to wave it for me and have the wiring harness replaced
Old 06-09-2006, 04:42 PM
  #726
B8 S4
scuc's Avatar
Originally Posted by fsttyms1
^ there probably wont be a dyno.
Why not?
Congrats on this project. I would have gone with a TL-S if they had come in a 6 spd.
Old 06-09-2006, 05:14 PM
  #727
fsttyms1's Avatar
Originally Posted by scuc
Why not?
Why not?? WHY??? its nothing special for a motor. Its a type s motor and 6 speed trans. it will be most likely putting down what the CL-S is with the manual.
Old 06-09-2006, 05:17 PM
  #728
fsttyms1's Avatar
Well new sensor and harnes redo today and NO CHECK ENGINE LIGHT!!!! havent brought it for a test drive cause i cant. My road is completly torn up and there is a mountain of dirt infront of it! It does run better. Now i need to see if the rad fan comes on. i let it idle for like 10 min but nothing. The temp needle went up to normal spot but neer went higher?? I want to get a actual temp gauge on to see
Old 06-09-2006, 06:17 PM
  #729
On the way!
fla-tls's Avatar
Good progress! Keep us updated!
Old 06-09-2006, 08:02 PM
  #730
318whp/289wtq @ 6psi
blk2001tlon19s's Avatar
nice kris! Keep up the good work.
Old 06-09-2006, 09:03 PM
  #731
PenancE's Avatar
ya u almost dere..........almost
Old 06-10-2006, 08:24 AM
  #732
2002 ABP TL Type S
keiser sozae's Avatar
come up with a figure, i'll send you my 02 abp tl-s, all i got is the 6 spd tranny, so far, and an overwhelming sense that i cant do it myself.
Old 06-10-2006, 01:19 PM
  #733
wow
Old 06-11-2006, 08:49 PM
  #734
fsttyms1's Avatar
Ok little update. Finally got home and took it for a drive, and after about 5 min the cel came back on. It still wont rev past 5k. Would a O2 sensor cause that? I need to make a appt to get it in to have teh codes read. (man i need to get a good reader)
Old 06-11-2006, 08:58 PM
  #735
No, I don't believe an error with the o2 sensor would stop the car from reving to a certain rpm.
Old 06-11-2006, 09:02 PM
  #736
99 SSM Tl
MrAlex's Avatar
its like when your at park and it doesnt rev pass 5000-5500rpm .. when you floor it
Old 06-11-2006, 09:06 PM
  #737
fsttyms1's Avatar
When i floor it
Old 06-11-2006, 09:07 PM
  #738
fsttyms1's Avatar
Humm. i just replaced the other crank sensor. those were the only codes showing up. I guess ill have to get it tested to see. I dont know what else it would be.
Old 06-11-2006, 09:16 PM
  #739
SSMTL01's Avatar
Is there a sensor from the auto tranny leftover thats setting off the rev limiter thinking its in park?
Old 06-11-2006, 09:32 PM
  #740
fsttyms1's Avatar
Nope. Its a all new ECU and Engine harness for the Manual tranny.
Old 06-12-2006, 12:58 AM
  #741
02 TLS SSM - Hi Oh Silvr!
BLADE RUNNER's Avatar
How about an air intake sensor?
Old 06-12-2006, 08:04 AM
  #742
fsttyms1's Avatar
last time it was in for reading the codes there wasnt any other code other than the one i replaced and a O2 sensor which i didnt replace
Old 06-12-2006, 01:16 PM
  #743
On the way!
fla-tls's Avatar
When it gets to 5000-5500, does it cut out like red line? Have you verified that the RPM gauge is reading correctly at higher RPMs?
Hmmm - VTEC engagement is now at 4800 for you... When in Park, an auto Type S will not enter VTEC range (I know you addressed this earlier on this page). Perhaps something to do with VTEC?
Old 06-12-2006, 06:42 PM
  #744
dwboston's Avatar
My wife's 2000 BMW 528i had a faulty O2 sensor which caused a similar problem. The engine wouldn't rev past a certain point and the car was severely "de-powered." We replaced the sensor and it was fine.
Old 06-12-2006, 07:04 PM
  #745
fsttyms1's Avatar
Yes its like redline (but a soft limiter-not as fast) i didnt have a code for any thing vtec related before. Im hoping its the O2 sensor causing it Guess ill find out as soon as i can get teh car out of the driveway (road work)
  #746
fsttyms1's Avatar
Thats what im hoping
Old 06-12-2006, 08:22 PM
  #747
ara606's Avatar
It is the O2 sensor.. I had the same problem in my Camry
Change the O2 sensor and u r good 2 go! (make sure u do NOT get an aftermarket sensor though)
Good Luck!
Old 06-12-2006, 08:24 PM
  #748
fsttyms1's Avatar
i wonder if i should just get a emulator???
Old 06-13-2006, 09:37 PM
  #749
GreenMonster's Avatar
Hmmm... still debugging it, eh ?? Sounds like you're getting really close now...
Someone needs to buy this man a code reader
Old 06-14-2006, 07:54 AM
  #750
fsttyms1's Avatar
Yep really close. Its been on a few maiden voyages around town. Drives great. like it was ment to be, just workin out a few lil bugs.
Old 06-15-2006, 01:37 PM
  #751
Flyboy4yang's Avatar
Wow, good stuff man. I would love to do this too but I think I'd get a new manual TL instead. Props for all the determination and hard work.
Old 06-15-2006, 03:26 PM
  #752
fsttyms1's Avatar
And spend 35k as opposed to 5k? not for me
Old 06-16-2006, 10:54 AM
  #753
haha. In that light of things I suppose. I'm just lazy I guess.
Old 06-16-2006, 11:57 AM
  #754
fsttyms1's Avatar
Old 06-17-2006, 07:25 PM
  #755
ThinJim's Avatar
Look into your cam sensor. I think from following this thread that you have the auto transmission motor which has different sensors. I've done a little check with the online oem part sites, and as far as I can tell, there may be two different sensors, one for the automatic and one for the six speed. I beleive the six speed needs two sensors while the auto needs one and they are completely different part numbers. the 6 speed part number is 37840-PGE-A11 and you need 2 of them, the auto number is 37840-P8A-A01. if that's the case, you'll also need the timing gear for the front head.
Old 06-17-2006, 09:55 PM
  #756
Future JDM Whore
Da_iLLeZt_TL973's Avatar
hey kris remember when i got my car back from the tranny shop it wouldnt let me rev over 3500 RPM.....what felt like the rev limiter would kick in at 3500 RPM and i replaced the VTEC Solenoid and it solved the problem.....im not sure if it is the same problem that your having but try checking the solenoid maybe???.....good luck cant wait to see it all done
Old 06-18-2006, 03:08 AM
  #757
The wood god
MegaKillTron's Avatar
Soo....you wouldn't happen to be around the houston area anytime soon would?! Tranny just went out again!!!! Im looking into a new car now either a new TL or a RDX.
Old 06-18-2006, 03:44 AM
  #758
Master Graphic Artist
PixelHarmony's Avatar
I've actually had a very similar problem happen on my 6MT TSX a while back. I don't know how related this can be to your issue but I might as well let you know.
Apparently a rodent went inside my engine bay and chewed out the wiring harness. This left a whole bunch of problems for my car, mainly the speedometer didn't work. I know the TSX for one has a rev limiter set around 4500 I believe. So when I'm not moving (ie Speedo is at 0mph) I can't rev past 4500. And yeah it's not like I hit the hard limiter, it just goes to 4500 and drops down softly.
I assumed that the ECU just thought my car was not moving so it set the limiter. I don't know if that might be an issue for you, but I guess you can check if all the electronics are reading properly. Is there a way to check if your ECU is in fact reading a speed even though your speedometer is getting something?
I hope this info might be of some help. Anyway, mad props on your conversion... it's late so I couldn't read through all 30 pages but I'll be sure to re-read your progress.
Old 06-19-2006, 08:49 AM
  #759
fsttyms1's Avatar
I already replaced teh 2 camsensors. i replaced teh 500 dollar crank sensor, replaced teh timing belt pulley which is also different for the crank sensor. Replaced the crank sensor "b" also.
all the harnesses are brand new. so i dont think any thing is wrong there. I need to get teh code read this week to see what teh cel light is for, and try to address it from there
Old 06-19-2006, 06:56 PM
  #760
DzTL-S's Avatar
kris, when i convert my integra to a 5sp i have to splice and connect wires from the shifter connection plug from your auto to set it D. i think the reason you car not reving over 5k because is still showing park on your ecu. hope that is the prob.
Quick Reply: 6 speed conversion, 2nd problem 9/2/17
