RDX Factory Service Manual Requests
Old 12-17-2019, 06:55 PM
  #41
8th Gear
Sam Farid's Avatar
Hello Dave
I need to replace me power Liftgate Lock Actuator Latch (74800-SZN-A01) on my Acura RDX 2018 tech package.
Would you be able to kindly post the PDF to explain how can I open the liftgate trim and replace the latch ?
I will also need to reset the error after I replace the part.
Any idea how to reset the error ?
Old 12-19-2019, 01:41 PM
  #42
8th Gear
Sam Farid's Avatar
Hello Dave
Old 12-19-2019, 04:51 PM
  #43
dave08902's Avatar
Originally Posted by Sam Farid
Hello Dave
Hello Dam Farid,
I got your first message as I am subscribed to the thread. Please do no double post.
I can only access the manuals from work as the access to the manuals are locked to my work IP address.
Patience is needed because of this restriction and the busy holiday season along vacations.
I will get your request filled as soon as I can since I am on vacation. I already contacted a co-worker on the 17th after your first post to email me the manuals.
I have not heard back from him yet. Please be patient.!!!
Old 12-19-2019, 06:51 PM
  #44
8th Gear
Sam Farid's Avatar
Originally Posted by dave08902
Hello Dam Farid,
Apologies, I was not sure you will see the post
No rush take your time
Happy Holidays
Sam
Old 12-21-2019, 07:21 AM
  #45
dave08902's Avatar
Hello Dave
Sam Farid
Here is the service manual on replacing the latch.
You need a scanner capable of reading and clearing B codes.
The following 2 users liked this post by dave08902:
Sam Farid (12-29-2019), wsw (12-21-2019)
Old 12-21-2019, 12:28 PM
  #46
egads's Avatar
Why would a 2018 not still under warranty?
Old 12-29-2019, 01:29 AM
  #47
8th Gear
Sam Farid's Avatar
the latch is damaged in accident which is not covered under warranty
Old 12-29-2019, 01:30 AM
  #48
8th Gear
Sam Farid's Avatar
Sam Farid
Many thanks Dave
Old 12-30-2019, 09:43 AM
  #49
dave08902's Avatar
Many thanks Dave
You're Welcome, Happy to help out.
Old 01-04-2020, 01:45 AM
  #50
cgvnoon's Avatar
Hi Dave,
My 2013 RDX isn't starting. I hear a single click when trying to start the car. Tried jumping the battery but no luck, I think it could be the starter.
Do you have any information on replacing the starter, such as the location?
Old 01-04-2020, 08:33 AM
  #51
dave08902's Avatar
Originally Posted by cgvnoon
Hi Dave,
Hello,
Here is the Service Manual on starter replacement. Hope this helps.
File Type: pdf
File Type: pdf
cgvnoon (01-04-2020), wsw (02-17-2020)
Old 01-04-2020, 09:46 AM
  #52
cgvnoon's Avatar
Hello,
Thank you Dave. Happy New Year!
Old 01-04-2020, 01:10 PM
  #53
dave08902's Avatar
Hello cgvnoon
Thank you and a Happy New Year to you too. Good luck on your repairs.
Dave
Old 01-05-2020, 09:16 AM
  #54
atis's Avatar
Hi Dave,
Can you share 2016 Advance parking sensors (front and back) wiring diagram?
Do you know if the sensors used in Advance package (39680-TX4-A01ZF + 39681-TX4-A01ZF) and back-up sensors from accessories (08V67-TX4-210J) are the same?
Regards,
Old 01-05-2020, 02:13 PM
  #55
dave08902's Avatar
Originally Posted by atis
Hi Dave,
Regards,
Hello atis,
Don't know if the two different types of sensors are compatible. One sensor is factory installed with factory computer, the aftermarket one is using a different computer and setup.
Here is the wiring diagram for sensors.
Dave
wsw (02-17-2020)
Old 01-05-2020, 04:27 PM
  #56
atis's Avatar
Thanks for the quick response and diagram.
Do you have access for wiring diagram from Chinese or Russian market? There was factory installed back sensors for RDX 2013-2015: ??,SENSOR ASSY., CORNER *NH782M*,39680SNVH01YA - Yiparts https://podkapotom.ru/RDX.KR.USA.TEC...ipment.B.13.60
Regards,
Old 01-05-2020, 04:35 PM
  #57
dave08902's Avatar
Regards,
Hello,
All I have access to is manuals for the US market.
Dave
Old 01-08-2020, 12:40 AM
  #58
Muzh's Avatar
wow!! It’s so nice of you!
regarding the front and rear parking sensors, could you please help to see if there is any documentation for INSTALLING the front parking sensors, please?
I recently own a 2017 rdx tech and would like to add parking sensors, which those advance model have. Don’t know if anyone knows it will simply plug and play, without going for dealer labor charges.
Old 01-08-2020, 12:45 AM
  #59
Muzh's Avatar
Forget to mention, I see installation guide for rear parking sensors really easy, but nowhere for the front ones. Thank you in advance!
hopefully they are also plug and play for MID unit of technology version as well!
Old 01-09-2020, 12:16 AM
  #60
egads's Avatar
There are no accessory front parking sensors, only rear ones as far as I can tell.
I also don't see, on the dealer accessory sites like Bernardi, rear sensors for the 2013-2015.
Old 01-09-2020, 11:42 AM
  #61
Muzh's Avatar
yes we don't see front parking sensor accessories, but doesn't the Advance model equips? Can't we buy parts and install? any trial?
Old 01-09-2020, 02:18 PM
  #62
egads's Avatar
Honda does not do things that way. The Advance will have a completely different wiring harness.
Old 01-10-2020, 07:07 AM
  #63
4th Gear
artj14's Avatar
Multi Information Display
Do you have a troubleshooting guide/schematic for the 2014 RDX Multi Information Display? To include the steering wheel controls? Thank you!
Old 01-10-2020, 01:16 PM
  #64
Muzh's Avatar
ok I see, the MID and Dashboard seems different from Advance model, so even I install it would only get beeps.
Curious if I install the back sensors in front, will it detect correctly.
I would replace the control signal, originally for backup light, to a signal triggered once the speed is below 10 miles per hour. How is that idea? lol
Now the problem is, is there a signal shows up like this??
Old 01-11-2020, 08:25 AM
  #65
dave08902's Avatar
Hello artj14,
Here is the troubleshooting for the gauge control module. Without a specific fault code, I can't give you the specific troubleshooting. Attached is the wiring diagram for the Gauge system. Hope this helps.
Dave
File Type: pdf
The following 3 users liked this post by dave08902:
artj14 (01-11-2020), freddy Sanchez (04-05-2020), wsw (02-17-2020)
Old 01-11-2020, 10:14 AM
  #66
4th Gear
artj14's Avatar
Thank you very much. The problem I am having is I cannot cycle through the displays on the multi information display from the steering wheel controls. And I cannot cycle through the trip meters or reset them via the knob at the gauge cluster. So there are no fault codes that I am aware of. Thanks again.
Old 01-14-2020, 09:24 AM
  #67
8th Gear
mytmai2099's Avatar
Hi Dave,
Can you upload the Self-diagnostic test for HVAC system ?
Thank you.
T.
Old 01-14-2020, 09:34 AM
  #68
8th Gear
mytmai2099's Avatar
Hi Dave,
Can you upload "How to test and replace the Temperature in-car sensor"
Acura 80530-SNB-941 Sensor Assy., In Car
Part Description In-Car Sens
Thank you.
T.
Old 01-14-2020, 04:11 PM
  #69
dave08902's Avatar
Originally Posted by mytmai2099
Hi Dave,
Thank you.
T.
Look at this post # 11 and #15
https://acurazine.com/forums/second-...s-fine-948525/
The replacement of sensor will need to looked at a later time.
Old 01-14-2020, 09:53 PM
  #70
8th Gear
mytmai2099's Avatar
Hi Dave,
On #11, it only shows the "Troubleshooting Index" and there is no steps to do the Self-Diagnostic test of the HVAC system.
All 4 pdf files mention the "Climate control DTCs".
NOTE: Before testing the motor, check for climate control DTCs
Can you check the Service manual for steps to check the "climate control DTCs" ?
Can you check the Service manual for steps to do Self-Diagnostic test of the HVAC system ?
On #11: Climate Control System Symptom Troubleshooting Index 1543.pdf
On #15:
Recirculation Control Motor Test 783.pdf
Passenger%27s Air Mix Control Motor Test 781.pdf
Driver%27s Air Mix Control Motor Test 780.pdf
Thank you.
T.
Old 01-15-2020, 04:36 AM
  #71
atis's Avatar
Hi Dave,
Can you upload front fog lights wiring diagram for RDX 2013-2015?
Regards,
Old 01-15-2020, 05:48 AM
  #72
dave08902's Avatar
Hi Dave,
On #15:
Thank you.
T.
Hello T
There is "NO" self diagnostic testing for the HVAC system, this is an Acura. The system is connected to the can bus and therefore all testing and diagnostics is done through the Honda HDS. If you have a professional scan tool like the Bosch ADS 625 you may have access to the HVAC module for testing.
Invest in a professional Scan tool, It may cost $4000 but it is the only way to work on modern Luxury cars.
The reason for the troubleshooting index is for troubleshooting without fault codes and from symptoms only.
Attached is the in-car temp sensor replacement.
Good Luck
Old 01-15-2020, 05:53 AM
  #73
dave08902's Avatar
Hi Dave,
Regards,
Hello atis,
Here is the front fog light wiring diagram, Hope this helps.
Dave
File Type: pdf
Old 01-15-2020, 08:21 AM
  #74
8th Gear
mytmai2099's Avatar
Hello T
Good Luck
Hi Dave,
Thank you very much for all of the info.
Can you look at the below thread and see if there is something like that in the 2G - RDX Service Manual.?
Thank you.
T.
Example to get to DTC menu on 3G - TL:
https://acurazine.com/forums/3g-tl-p...orking-910734/
See #2:
How to retrieve DTC (without HDS)
Old 01-15-2020, 10:00 AM
  #75
dave08902's Avatar
Hi Dave,
Thank you.
T.
See #2:
Like I said before "There is "NO self Diagnostics" for this vehicle. What you are referencing is for a 2004 to 2008 TLX. Those vehicles are pre CAN bus and is old technology that is over 10 years old and obsolete.
AGAIN NO SELF DIAGNOSTICS.....
Old 01-15-2020, 10:33 AM
  #76
atis's Avatar
Hello atis,
Dave
Thank you. You are really fast
There should be also diagram showing how the combination switch is connected with MICU (and MICU diagram itself).
Regards,
Old 01-15-2020, 12:34 PM
  #77
dave08902's Avatar
Regards,
Hello atis,
Here is the headlight circuit, it includes the combination switch, as for the MICU it includes information pertaining to light circuit. There is no individual diagram for the MICU, it is integrated into too many systems.
You're Welcome, happy to help
Dave
File Type: pdf
wsw (02-17-2020)
Old 01-15-2020, 02:54 PM
  #78
atis's Avatar
Hello atis,
Dave
Thanks! This is for RDX 2013-2015? There is information about LED headlights on diagram and document creation year is 2017 (same for fog lights diagram). Can you attach taillight diagram too?
Old 01-16-2020, 11:42 AM
  #79
dave08902's Avatar
Hi Dave,
Thank you.
T.
See #2:
Hello T,
I looked at my service manuals numerous times and did not find any self diagnostics for the HVAC system. I called my friend who works at Honda and he has access to Honda service Express. He found the information your looking for.
Sorry if I was blunt, I spent way too many hours on this request and was starting to get annoyed.
Dave
freddy Sanchez (04-05-2020), mytmai2099 (01-16-2020), wsw (02-17-2020)
Old 01-16-2020, 12:39 PM
  #80
dave08902's Avatar
Hello atis
Here is the exterior lamps and head lamps for 2013-2015 hope this helps
Dave
File Type: pdf
File Type: pdf
freddy Sanchez (04-05-2020), Mr Twisty (10-29-2021), wsw (02-17-2020)
Quick Reply: RDX Factory Service Manual Requests
