nspec's 01 CL-S thread
Old Aug 21, 2010 | 09:44 PM
  #241
nf3d0149ab's Avatar
Nice. That's always a nice benefit to have at your disposal.
Old Aug 21, 2010 | 10:07 PM
  #242
StreetKA's Avatar
460 iirc but u should get flywheel too
Old Aug 22, 2010 | 01:32 AM
  #243
nspec_ya4's Avatar
Regional Coordinator (Texas)
Did you get the flywheel too? The disc, pressure plate and throw out bearing retail for about $340 but can be had for about $250 online. The flywheel retails for $650 but you can get it for alittle under $500 online as well. For that price you might as well get the AASCO lightweight flywheel though. Or get a used one resurfaced if you find a shop will to do it.
The throw out bearing is separate. The disk and plate were about 250, then about 30 for bearing. I'm just gonna resurface the fly wheel. dont see it reasonable to spend that kind of money on a new fly wheel.
no need to.
Old Aug 22, 2010 | 10:18 AM
  #244
StreetKA's Avatar
i resurfaced mine and it holds up right for now... but sometimes i got hard clutch issue and the engagment point is very low... i want to remove dampner and slave to see if thats make any difference
Old Aug 22, 2010 | 01:40 PM
  #245
Nersh7's Avatar
I Drive Like A Dick 8≈
^From what I hear it will make a huge difference
Old Aug 23, 2010 | 06:06 PM
  #246
nspec_ya4's Avatar
How do u guys think a 3G TL A-spec front lip would look on our car?
I picked one up for pretty good price today. as soon as i get the car back from the shop, i'll do some test fitments.
can anybody photoshop that lip on a CL?
Old Aug 23, 2010 | 06:24 PM
  #247
p.diddy's Avatar
i dont really think it will go with the body lines of the car.
Old Aug 23, 2010 | 06:51 PM
  #248
brian6speed's Avatar
Lone Wolf
I dunno about a 3g tl lip. I know someone used a prelude lip before, or the 2nd gen tl wings west lip and shave the side things off, or just get a ron jon front. Just suggestions. Good luck.
Old Aug 24, 2010 | 09:03 PM
  #249
nspec_ya4's Avatar
Im gonna give that lip a try anyways. I think i can pull it off, if not, then you wont see it, thats for sure.
The civic lip was too short to even mess with.
Started pulling the motor out already. some progress pictures
3.2 Type-S MOTOR FORSALE. CHECK MY THREAD
Old motor out
This one for diddy
tomorrow, the flywheel's going to the shop, a few hours after it comes back the car should be out and running
Cleaned out the wire harness some what
Old Aug 24, 2010 | 09:10 PM
  #250
StreetKA's Avatar
dont forget to take your picture inside the engine bay if you dont thats bad luck !
Old Aug 24, 2010 | 09:12 PM
  #251
p.diddy's Avatar
Originally Posted by nspec_ya4
This one for diddy
lol. are you going to paint the calipers?
Old Aug 24, 2010 | 09:17 PM
  #252
nspec_ya4's Avatar
not any time soon. not until i repaint the car
Old Aug 24, 2010 | 10:57 PM
  #253
nf3d0149ab's Avatar
^ Ewww......
Old Aug 25, 2010 | 12:54 AM
  #254
DarkSithCL's Avatar
Be Strong AND Courageous!
you go man! Good times!
Old Aug 25, 2010 | 07:39 PM
  #255
nspec_ya4's Avatar
Cleaned the engine bay somewhat
Subframe
Changed out the cam and crank sensors on the new motor.
Since i was transferring the sensors between auto and manual motors, i also had to switch out the rear cam gear plate because the auto sensors wouldnt go through the holes in the manual's plate. but it will work the other way around.
Havent taken the flywheel out yet, missing the 12 point 17mm socket. That will be done tomorrow and hopefully by afternoon the motor should be in the car.
Old Aug 25, 2010 | 07:52 PM
  #256
Jacobpockros's Avatar
Very nice. Do you plan on boosting this motor eventually?
Old Aug 25, 2010 | 08:47 PM
  #257
nspec_ya4's Avatar
boosting this fwd = waste of money for me.
Old Aug 25, 2010 | 09:02 PM
  #258
Better get a head start on that rwd conversion
Old Aug 27, 2010 | 11:47 PM
  #259
nspec_ya4's Avatar
Motor is in. Sounds Awesome and revs up very nicely
Have a CEL P0386 Crank Sensor code. I'll have to check into that later on. I'll install the wide band pretty soon.
oem fuel pump next to walbro 255lph
Old Aug 27, 2010 | 11:54 PM
  #260
Motor looks great! Make a video man.
Off topic question:
Do you have to take a motor out to replace a sub frame or can it be done with the motor in?
Old Aug 28, 2010 | 12:03 AM
  #261
nspec_ya4's Avatar
u can leave the motor in and remove the subframe. just need something to hold the motor while its up there, like a piece of wood that runs from the fender to the fender.
I'll make a video pretty soon. need to break in the clutch.
Old Aug 28, 2010 | 01:12 AM
  #262
Most people probably don't pull the motor then (if there not swapping motors) right? Otherwise it would just require alot more work
Old Aug 28, 2010 | 09:45 AM
  #263
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
Looks familiar!
CONGRATS!
It occurred to me, why not ask for the alt pulley back? They can't use it without the other ones.
Old Aug 28, 2010 | 10:18 AM
  #264
gnuts's Avatar
3.5 psi
i used a TL wings west lip, cut those flares off the sides. It's really easy to work with as it's super flexible, and i like it better than the OEM TL front lips.
Old Aug 28, 2010 | 10:51 AM
  #265
nf3d0149ab's Avatar
Saweet!
Old Aug 28, 2010 | 01:37 PM
  #266
civicdrivr's Avatar
Old Aug 29, 2010 | 12:34 AM
  #267
nspec_ya4's Avatar
Looks familiar!
CONGRATS!
I sold so many parts, i dont even remember who i sold it to. and i deleted most of the emails. not a big deal, i'll get the new pulley and belts soon.
Old Aug 29, 2010 | 12:38 AM
  #268
nspec_ya4's Avatar
wideband is in too.
took some pics with another buddy's (cu0ngsayz) CL
even at the lowest settings on the teins, the car still looks high as hell on the teins.
Paint getting buffed and waxed. My guy worked majic on this paint. It came out amazing.
Old Aug 29, 2010 | 12:49 AM
  #269
Damn that looks nice. Where are your mufflers?
Old Aug 29, 2010 | 01:04 AM
  #270
civicdrivr's Avatar
03 tails will complete the look.
Old Aug 29, 2010 | 01:20 AM
  #271
nspec_ya4's Avatar
for some reason, i'm not a fan of the 03s.
im gonna have another set of rims coming in soon. 18s this time.
Old Aug 29, 2010 | 01:21 AM
  #272
nspec_ya4's Avatar
i cut them off because i was going to install the lip kit, but that got delayed, so i'll leave em off until i finish the project.
Old Aug 29, 2010 | 01:23 AM
  #273
nspec_ya4's Avatar
I just looked it up and see what ur talking about. Thats a pretty good idea. Let me see how it goes with TL Lip and i'll look in to that after if i have to.
Old Aug 29, 2010 | 08:54 AM
  #274
StreetKA's Avatar
wow that detailing came out amazing love it.
Old Aug 29, 2010 | 09:00 AM
  #275
e30cabrio's Avatar
Looks great. How does it feel?
Old Aug 29, 2010 | 10:21 AM
  #276
nspec_ya4's Avatar
Havent stepped on it yet. not gone over 4-5k rpm.
right now i'm so broke, i cant afford anything to go wrong with this car. Not until i get some more cash.
Old Aug 29, 2010 | 10:38 AM
  #277
StreetKA's Avatar
get an 3.6 badge i know how you feel GOOD LUCK !
Old Aug 29, 2010 | 11:19 PM
  #278
nspec_ya4's Avatar
Rolled the front fenders today. The cheap roller sucked ass so I just used a hammer, a heat gun, and a piece of wood. I spent about 15m on each fender. Came out pretty good. I think atleast. No more rubbing when going over highs and lows. Only when i'm turning and on an incline. No flaring what so ever.
oh and forgot to thank the guys here for helping me out through out the swap.
Thanks Morgan and Stefan!
Old Aug 29, 2010 | 11:31 PM
  #279
civicdrivr's Avatar
What roller were you using?
Old Aug 29, 2010 | 11:42 PM
  #280
nspec_ya4's Avatar
http://cgi.ebay.com/ebaymotors/New-F...motiveQ5fTools
straight out piece of shit. didnt wanna spend another 100 for a eastwood.
The built quality is pretty bad. its loose at some joints so it moves around a little when u put the roller on the fender.
so dont buy it. Im gonna try to return it soon.
