Innovative motor mount discussion. **New mount info on page 13**
#401
Lead Footed
Originally Posted by rp_guy
then i'm gonna say it's safe to install front/rear in the meantime, and wait for the side ?
If it doesn't, then you'll be in the same boat as the rest of us . . . waiting to get the front/rear mount problem resolved.
Ruf
#402
Lead Footed
Originally Posted by 02type-s
I know it will a little, but not to the point where I turn on my A/C and stuff starts rattling, right?
There's a HUGE difference between a little vibration and what we are experiencing. If I were close to Innovative I'd go there and guarantee they would be freaked out by how bad it's vibrating.
Has anyone been in one of those fancy vibrating massage chairs? Well go sit in one and turn it on vibrate only and that's what it feels like when mine's in gear, and like Fuzzy says, it gets worse with the A/C on. It will literally rattle the fillings out of your teeth. I feel like I'm in a NASCAR . . . and I'm not exaggerating.
Ruf
#403
the only time i have vibrations that i would consider this bad is when i let my clutch out about halfway in first. other than that it does have increased vibrations but it's hard to compare without ridding in someone else's car with the same issue. or maybe it's because i'm use to raggedy old cars and trucks.
on that note RUF are you ever in Dallas or Austin? I sometimes go to Dallas for the weekend and maybe we could meet up and compare. i go skating up in allen at the skatepark and will be up again with my car on may 9th - 11th.
#404
Lead Footed
Ruf
#405
-Arsenic-
Ruf
Ruf
#406
'03 ABP YA4-S 6MT
what do you guys think about the tranny mounts? should we even try?hhahaha
http://www.acuraoemparts.com/delray/...s3m0_b4701.gif
5 and 6 i believe.
5 and 6 i believe.
#407
5 and 6 i believe.
5 and 6 i believe.
1.
2.
3.
no thanks on the trans mounts. i've had enough fun with this last round.
#408
Kilos of yayo in
5 and 6 i believe.
5 and 6 i believe.
#422
Originally Posted by yunginTL
just recieved my mount today and was wonder, how hard is it to install the side mount? Anyone got a link to a DIY
you will notice that the little black ABS/SRS box is blocking access to the side mount. remove those 3 bolts, unplug it but i left the cable attached. just set it on top the motor out of the way. with the front and rear mounts still installed just unbolt the side mount. 3 bolts hold the mount to the body/frame, 2 in the engine block and then the main center one. you will need some ratchet extensions to get to the bolts. then just wiggle it around until you get it to slide out. once that's out get the new one in bolt everything back down. once you get the frame and block bolts started by hand go ahead and slide the main center bolt in while everything is loose. i tightened the frame and engine block bolts down in a rotating pattern to make sure everything stayed aligned. then place the SRS box and bracket back in place and plug it back in. waa-la!
#423
Originally Posted by Excelerate
I will have the rest of the tracking #'s by the latest Wednesday, possibly tomorrow.
#429
is that just with the new side, and 1st rev. front and rear?
i used new longer bolts that i bought at the bolt store.
#430
Uses turn signals in my
Anyone put the new side mount in yet? How is it?
Old one on the left, new one on the right:
I used the factory bolts.
#431
-Arsenic-
that's with the new side and the first model of the front and rear. yeah i have vibrations but nothing more than i was expecting. there are still plenty of little vibrations and they do increase a little with the AC turned on. if it was a daily i would not have these.i used new longer bolts that i bought at the bolt store.
#432
Do you mean if it was your DD you wouldn't be able to put up with it? I DD my TL-S and I know there will be a little, but I'm just worried about how much.
#433
if you have driven an older car and are use to little vibrations and rattles then you probably won't mind these mounts. i daily a 96 mustang that handles worse than a drunk slut on friday night. it has all kinds of rattles and such. just listening to some people on here complain about some little rattles in the sunroof or behind the radio. these mounts are not for those type people.
#436
-Arsenic-
I wish someone in my area had these so I could see if it would drive me nuts or not...I mean mine vibrates al little bit b/c of whichever one is torn, but I do DD mine....grrrrr I don't know what to do. I want them bad, but not if its gonna piss me off every time I drive it..
#437
Former Sponsor
More FEDEX tracking #'s:
Bonlie 632885961015606
Mike 632885961015620
Bielecki 632885961015576
Solyar 632885961015507
Fuzzy 632885961015583
Cavallo 632885961015514
Hong 632885961015491
Suchdeve 632885961015521
Lee 632885961015545
Rehmat 632885961015613
Arandomstore 632885961015484
CleanCL 632885961015637
Johnson 632885961015538
Bing 632885961015569
If you haven't already received your side mount and your name isn't on this list please PM me. Thanks.
Lee 632885961015545
#438
Could one of you guys post a picture of the new side mount installed? I am now starting to have some of these crazy vibration issues with the new side mount, that I did not have with the old side mount.
Thanks.
Thanks.
#439
I was examining the new side mount today, made sure everything was tightened up correctly and it appears to be, but I noticed that my new side mount appears to be at an angle:
What do you guys think, installation issue (on my part) or faulty replacement mount? Everything lined up fine when I was installing it.
#440
I got tired of the excessive vibration problem and tried trouble shooting with the new innovative mount, but with no luck. I just ended up putting the old innovative one back on and now the problem is gone.
