Hope Systems, Inc.
Old Jun 2, 2004 | 11:48 PM
  #241
Red Rider's Avatar
Subie Dubie
Originally Posted by sgmotoring
Any discount if I get your e-manage with PNP harness kit and a high boost pulley?
Good question
Old Jun 3, 2004 | 01:06 AM
  #242
blader's Avatar
Audi S4 driver
Originally Posted by scalbert
I think the biggest thing for people to consider is that the other kits are better systems and would outperform what I am planning. But what I have in mind will be significantly better than stock; slightly shorter distance (if any) but little to no fade.
to be honest with you steve .. I'd be happy if they don't warp like the stock crap the slightly shorter distance and little to no fade would only be a bonus. at 22K miles my rotors make my steering wheel dance at speed on the highway when I press on the pedal.
Old Jun 3, 2004 | 05:35 AM
  #243
types1967's Avatar
steve your costing me money although i will have the fastest acura in nj
Old Jun 3, 2004 | 06:55 AM
  #244
scalbert's Avatar
Originally Posted by mrsteve
Once we get farther down the road and cams are being developed will there need to be different cams for different applications? Specifically the Uni-Chip? I know it is never good to install cams without proper tuning. Just curious if different cams will be used for NA no chip/NA chip/FI
We'll have to see. If most of the gains from the Unichip come by the way of ignition timing changes then no changes should be needed for the cam swap. If the A/F ratio does change noticeably then we will have to look into a new program.
Old Jun 3, 2004 | 06:58 AM
  #245
scalbert's Avatar
The problem is that I am not doing this to grow a business. As such the margins are minimal not allowing for discounts. However, if group buys were organized I could get deeper discounts from the vendors and pass it along to ya'll. Otherwise I am pretty fixed in the pricing.
  #246
darrinb's Avatar
///M POWER
blader
take em to the dealer, they are warped
Old Jun 3, 2004 | 06:59 AM
  #247
scalbert's Avatar
That is really my direction. A good alternative to the stock set up which doesn't warp or fade and doesn't cost significant $$. Any decreased distances is a bonus.
Old Jun 3, 2004 | 07:24 AM
  #248
Chemmech's Avatar
Any update on PayPal yet Scalbert?
Old Jun 3, 2004 | 07:29 AM
  #249
scalbert's Avatar
We are still waiting on PayPal to make the deposits into our account and then we will have Verified status. They should have done it by now but I was going to give them until the end of the week and then check with them again.
Old Jun 3, 2004 | 10:18 AM
  #250
VeeralS05's Avatar
I NEED MONEY!
i need an intake...wait for hope systems or go with comptech.... any ideas?
Old Jun 3, 2004 | 10:22 AM
  #251
scalbert's Avatar
IMO, Comptech.
I will not be revinventing the wheel and making another "I have one too" intake. The intake parts we will be making deal more with the TB and manifold.
Old Jun 3, 2004 | 10:26 AM
  #252
VeeralS05's Avatar
I NEED MONEY!
thanks soo much, "THE DA MAN SCALBERT"
Old Jun 3, 2004 | 11:53 AM
  #253
blader's Avatar
Audi S4 driver
I read in another thread somewhere that initial testing of the RES proved gains as much as the unichip in the mid-RPM range .. is that true? has it even been tested?
Old Jun 3, 2004 | 02:03 PM
  #254
mrsteve's Avatar
I believe in that thread scalbert tested his original prototype as well and didn't see any gains whatsoever. We'll have to see what's different this time around.
Old Jun 3, 2004 | 06:39 PM
  #255
scalbert's Avatar
Yes, the original one which was never released. I am trying a different design which can be manufactured at a reasonable costs and get similar gains.
Old Jun 3, 2004 | 06:41 PM
  #256
scalbert's Avatar
Correct, nothing was gained. But I beleive I know what I missed and am correcting it right now.
Old Jun 4, 2004 | 12:50 AM
  #257
darrinb's Avatar
///M POWER
10 whp would be good for 300 bucks steve
Old Jun 4, 2004 | 02:32 AM
  #258
sgmotoring's Avatar
Bleed Honda Blue
I would say yes except for you having a 3.5L engine. This may require more fuel per PSI boost. Unless you see the A/F ratio it is just a guess.
Does your preprogramming e-manage included timing retard as boost increase?
Old Jun 4, 2004 | 06:12 AM
  #259
scalbert's Avatar
My current program does not but I have another which does. It would be implemented though for a safety measure. I was doing 1 degree retard per two PSI boost. So 8 PSI boost would net 4 degrees retard.
Old Jun 9, 2004 | 11:59 AM
  #260
scalbert's Avatar
Just FYI...
http://www.acura-cl.com/forums/showt...54#post1860454
Old Jun 9, 2004 | 05:36 PM
  #261
Chemmech's Avatar
Thanks for the update Scalbert. Trying to figure out Paypal right now .
Old Jun 10, 2004 | 06:52 AM
  #262
scalbert's Avatar
BTW, for those wanting to put the power down at the strip I just got in the radius rods yesterday (meant to take pictures) and did a test fit last night. I should have the mounting figured out this weekend and will go out to a parking lot to test them.
If all works out I'll do a video showing the car launching without them (wheel hop galore) and with them (no wheel hop at all).
Old Jun 10, 2004 | 06:54 AM
  #263
scalbert's Avatar
One more thing, I also got the exhaust cutout actuator in yesterday. It is going in to be installed tomorrow. I'll video this also and see what the sound difference are like outside the car and inside.
Old Jun 10, 2004 | 07:08 AM
  #264
Louie11's Avatar
Fantastic scalbert!!!!! My baby is in dire need for those radius arms to stop this dam wheel hop and get some good 60' times.
Old Jun 10, 2004 | 08:37 AM
  #265
mrsteve's Avatar
Old Jun 10, 2004 | 09:00 AM
  #266
brian6speed's Avatar
Lone Wolf
Nice work. Just curios when you expect them to be availabe for purchase, and how much you plan on selling them for? Thanks again scalbert.
Old Jun 10, 2004 | 09:06 AM
  #267
scalbert's Avatar
I plan on having two versions available. The first version should be available before the end of the month. This will be a non-streetable but quick bolt on kit. It could be installed at the track in five minutes. I expect the price for this to be around $150.00
The next version, which will be a ways off, will replace the factory radius rods and include a front cross member. I expect this to be priced in the $300+ range, maybe more depending on how much fabrication is required. This is still months off as I haven't begun tearing out the stock pieces to see how it could be mounted.
Old Jun 11, 2004 | 02:30 PM
  #268
RUF87's Avatar
Lead Footed
Ok, I was waiting for SRES2 (Scalbert RES System) as my first need, but since getting my rebuilt tranny back I'm really thinking I'd like a ECM option . . . I hate the way my tranny shifts and even told the dealer that I've toyed with trading it in on something else.
I feel like I'm driving Granny's car now.
So what are the chances this is doable Scalbert? Do you need to talk to the head of engineering? :P
Ruf
Old Jun 11, 2004 | 02:50 PM
  #269
scalbert's Avatar
I planned on (or rather the engineering dept. ) looking at a mod for the transmission electronics which will allow someone to tailor their shift feel. I want to get on this soon but need to clear a few of the other projects first.
Old Jun 11, 2004 | 03:37 PM
  #270
car_lost's Avatar
by non streetable, do you mean not street legal or that it would be impossible to have them for every day use? can u explain?
Old Jun 11, 2004 | 04:19 PM
  #271
cartan's Avatar
Swim Bike Run...
Of all the mods I'd like to do, this would be at the top of my list! I sure hope it works.
Old Jun 11, 2004 | 10:21 PM
  #272
scalbert's Avatar
It would not be practical on the street; it would limit clearance by about 50%. It should be completely street legal though.
Old Jun 11, 2004 | 10:23 PM
  #273
scalbert's Avatar
I'm pretty confident on this as it is not uncharted territory for FWD vehicles. I doubt the CL will be the one unique vehicle.
I'm planning on picking up a few bolts tomorrow which should complete the task. Maybe a test run will be in order for Sunday. But there is another item which needs testing first.
Old Jun 14, 2004 | 01:39 PM
  #274
blader's Avatar
Audi S4 driver
What are we looking at for a time frame on the RES ... and would using the RES require a re-tuning on the unichip?
Old Jun 14, 2004 | 01:43 PM
  #275
scalbert's Avatar
I want to test the first RES plate by the end of the month. If that works out I should have a final design ready to test before the end of July. From there it will be available but I really need to get some miles on a couple just to be sure there are no hidden issues.
As for tuning, if the Unichip's benefits come by way of what I think they do, mainly through timing alterations; then no, it would be fine. I'll have to research this further.
Old Jun 14, 2004 | 01:47 PM
  #276
blader's Avatar
Audi S4 driver
The way I understand it, the RES plate is essentially a type of "spacer" for the intake manifold .. so if I understand it right then we can get more air into the motor more quickly, and I thought in addition to timing the unichip also tunes air\fuel .. so with more air coming in .....
I figured maybe we could take more fuel. anyway I'm not worried I'm sure you'll figure it out
Old Jun 14, 2004 | 01:51 PM
  #277
scalbert's Avatar
Actually, it should help increase the manifold pressure thus enabling greater filling ability. This should be seen by the MAP sensor and adjusted by the Unichip as it would without the RES. How much I can't say right now but there are variables to consider and it is something we will look into.
Old Jun 14, 2004 | 02:37 PM
  #278
blader's Avatar
Audi S4 driver
Ah, makes sense, I get it. Can't wait to see how it works out on the dyno. Hopefully it will aide my quest for 13's on NA 5AT .. I think I have it locked down with just the addition of the unichip and mugen cooling stuff tho.. I only need .18 seconds
Old Jun 16, 2004 | 12:42 PM
  #279
Chemmech's Avatar
We'll the deposits been made . Just gotta wait now.
Old Jun 16, 2004 | 01:14 PM
  #280
scalbert's Avatar
Thanks, everything is in motion...
I'm going to try a different heat exchanger in the mean time. This one might be better and would look pretty cool. I'll post some pictures once it is in and ready.
