Any ideas what wrong?
Old Apr 23, 2010 | 08:15 PM
  #41
Allout's Avatar
Blown is Best
Originally Posted by CL-S progression 01
my bro had that happen to him in his prelude and found out it was the ignition switch in the steering column
X2
Old Apr 23, 2010 | 08:18 PM
  #42
Allout's Avatar
Blown is Best
Originally Posted by steve_97060
it was suggested to me that it could be the coil, anyone else have an opinion?
It could be in the ignition systems with only one common coil. Ours utilize 6 individual coil packs above each spark plug so - no not a coil problem.
Old May 27, 2010 | 07:11 PM
  #43
steve_97060's Avatar
can anyone else suggest anything.. we replaced the ingition switch already but are still having problems. it happens every couple of weeks, sometimes stopped, other while driving, the car will just gradually lose power and die, giving it gas does nothing... after the car dies, if you turn it off it will start back up, no codes ever come up.. the rest of the time it runs fine, although I have noticed a couple of times the tach needle seems to drop really quick even though the engine doesn't seem to be changing much, but that could just be nothing..
could really use some help... thanks
Old May 27, 2010 | 07:56 PM
  #44
russianDude's Avatar
Originally Posted by RKeatF1
My 01 CL-S (214,000)
Still on original transmission?? how often do you change fluid?
Old May 28, 2010 | 10:24 AM
  #45
fuzzy02CLS's Avatar
By this info I'd say a bad IAC valve. It doesn't give a code when it's faulty. Ever change it?
Old May 28, 2010 | 07:38 PM
  #46
what is an IAC valve? I just got a call that it died on the freeway when she was doing about 60, now it won't start at all..
Old May 29, 2010 | 10:00 AM
  #47
Rajca's Avatar
wham bam thank you ma'am
idle air control valve. car wouldnt die and not start from it being bad. the idle would be all over the place but still drivable
Old May 29, 2010 | 10:26 AM
  #48
richardparker's Avatar
3.7L Nitrous Breathing CL
That sounds like the timming belt broke or overheated.
Does the car turnover fast or not at all ?
Old May 29, 2010 | 12:07 PM
  #49
friesm2000's Avatar
B A N N E D
IGNITION SWITCH jackasses lol
Old May 29, 2010 | 12:13 PM
  #50
friesm2000's Avatar
B A N N E D
My 01 CL-S (214,000) Has now shut off on my 3 times in the last week. First time it happened on the interstate. Felt like the trans went into neutral. I could step on the gas and the engine would rev. I bumped it into neutral, and coasted off the road. As it came to a stop the motor was not running. No lights on , as if it had stalled. Just stopped running. Sat for about two minutes and it re-started and worked fine.
Yesterday same thing happened again. Got it running went about a mile and stopped again.
No codes at all. Never any dash lights like it stalled.
Recently put 6 new coils on. Due to having 2 fail. Idle is still a little funky but that is all????
no power gets through the ignition switch means no dash lights and such on, and as far as codes, the pcm is in "essence" just thinking your are turning off the car, so it will never set a code
then the restarting no issues, you turn the key which made the connection in the switch again
and btw when they go out, they seem to kinda do it intermittently at first, then BAM, one time you go to start it, it will, but as soon as you let go of the key from the start position the car will die immediately
Old May 30, 2010 | 04:39 PM
  #51
already replaced the ignition swittch, still have the same problem. I have a new fuel pump relay and will replace it today, just trying to find instructions on how to do it..
car runs fine except for when it does this periodic shutdown
Old May 30, 2010 | 05:00 PM
  #52
Sometimes the fiter on the pump will collect garbage from the botom of the tank and keep colecting till not enough fuel can get threw and it will stall like that.
Then by turning off the key some will come back off to allow you to start the car again later , the time it takes for you to get the lines fully flow with fuel.
I Had that problem before with another car.
Don't know if it's yours.
Old May 30, 2010 | 05:12 PM
  #53
thanks for the info, if the relay doesn't fix it, that will be the next step. can anyone tell me if there are instructions for removing the lower dash panel so I can get access to the relay?
Old May 30, 2010 | 05:40 PM
  #54
civicdrivr's Avatar
When you open the door, you'll see the fuse box cover. Pull that cover off. There is a screw behind that holding the panel on, and IIRC another near the center console. Then gently pull it towards the seat.
Old May 30, 2010 | 05:47 PM
  #55
thanks for the info, now just trying to identify the actual relay, and is there anything I need to do before removing it?
Old May 30, 2010 | 06:14 PM
  #56
civicdrivr's Avatar
Make sure the car is off
From what I hear, its a bitch to remove from the bracket. You may be able to unbolt the bracket from the car and bring the whole thing down so you can work on it. I believe it uses a 10mm bolt.
Its up there kind of high, so it'll be a pain getting to it.
Old May 30, 2010 | 06:29 PM
  #57
tell me about it, I can't get the damn relay to come off the bracket... what a pain in the ass
08KBP_VA
Oct 22, 2019 01:55 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
Gout
Nov 2, 2015 12:22 AM
Houston
Oct 8, 2015 01:27 AM
