Any ideas what wrong?
Old Apr 16, 2010 | 08:53 AM
RKeatF1's Avatar
My 01 CL-S (214,000) Has now shut off on my 3 times in the last week. First time it happened on the interstate. Felt like the trans went into neutral. I could step on the gas and the engine would rev. I bumped it into neutral, and coasted off the road. As it came to a stop the motor was not running. No lights on , as if it had stalled. Just stopped running. Sat for about two minutes and it re-started and worked fine.
Yesterday same thing happened again. Got it running went about a mile and stopped again.
No codes at all. Never any dash lights like it stalled.
Recently put 6 new coils on. Due to having 2 fail. Idle is still a little funky but that is all????
Old Apr 16, 2010 | 09:00 AM
brian6speed's Avatar
Lone Wolf
Sounds similar to what happened when i had my headers installed and the shop forgot to rehook up the alternator they unplugged.
Old Apr 16, 2010 | 09:20 AM
phee's Avatar
I got the Shifts
is your car getting air?
is your car getting fuel?
is your car getting electrical current?
Old Apr 16, 2010 | 09:59 AM
RKeatF1's Avatar
Yes to all./ it runs fine 98%. This shutting down has me perplexed. I am thinking it is related to the trans?
Old Apr 16, 2010 | 10:30 AM
DaInFaMMuS1's Avatar
have u checked your batter voltage to see if the alternator is recharging it?
Old Apr 16, 2010 | 11:17 AM
civicdrivr's Avatar
Im thinking a fuel issue. I had that issue on my bike before, where Id lose power but because the engine is in gear, the tranny keeps the motor spinning. Its odd that it would only happen sporadically though, and that when you put it into neutral you could rev it up.
How high did it rev? Was it a smooth sweep?
Old Apr 16, 2010 | 02:42 PM
RKeatF1's Avatar
Battery does not seem to be an issue. the first time it happened on the interstate it seemed like ,(my first thought) was the trans went, because it did not seem to be in gear. That is when I bumped it into neutral to coast to the shoulder of the road. The next two times it just shut down. Again today about a mile from the house. So I just put it into park. Wait a minute or two Then start it up and it goes fine.
Old Apr 16, 2010 | 03:15 PM
victypes's Avatar
is planing PrisonBreak in
I also had same thing happen and thought same that tranny is out, but it was not. I have 1500 watt amp in my trunk and fog lights hooked up to the battery, due to the amp battery connection is usually corroded and thats what led to car shut down now and then just like you explained "lights out" so make sure no corrosion and if any clean and greas it and make sure connections are tight. only other thing could be the alternator.
Old Apr 16, 2010 | 03:34 PM
CobraSpdRH's Avatar
Do you still have radio, clock, lights when it shuts down?
Old Apr 16, 2010 | 06:54 PM
nspec_ya4's Avatar
Regional Coordinator (Texas)
he said the motor is fine, but its the tranny that goes into to neutral randomly. if thats what it is, then its a tranny problem.
Old Apr 16, 2010 | 07:41 PM
Jacobpockros's Avatar
x2 on it being alternator related
Old Apr 16, 2010 | 09:13 PM
fuzzy02CLS's Avatar
You over heating by chance? Check your coolant level. Engines are know to shut off due to overheating.
Old Apr 16, 2010 | 11:41 PM
civicdrivr's Avatar
But the car is turning off
Old Apr 17, 2010 | 07:15 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
It's a charging issue.
Old Apr 17, 2010 | 08:41 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
my bro had that happen to him in his prelude and found out it was the ignition switch in the steering column
Old Apr 17, 2010 | 09:07 AM
nspec_ya4's Avatar
but how come he said "the car shuts off" and at the same time "Felt like the trans went into neutral. I could step on the gas and the engine would rev"
its either or.
Old Apr 17, 2010 | 09:30 AM
Rajca's Avatar
wham bam thank you ma'am
ignition switch. common problem on the 99tl's but happens on other 2nd gen tl/cl's. its cheap and easy to replace. but just make sure that its not something else. theirs a diy in teh 2nd gen tl side diy thread
Old Apr 17, 2010 | 02:01 PM
civicdrivr's Avatar
its either or.
True. Maybe two problems occuring at the same time.
Old Apr 19, 2010 | 08:21 AM
RKeatF1's Avatar
Ok again the first time it happened was on the interstate. The car lost drive(like it was not in gear) engine still running. I could rev it. I put it in neutral and coasted to side of road. At that point is shut off. I recycled the key after waiting 1-2 mins and started right up.
The nex three time it happened it was on secondary streets. When it happened it would just shut off. Again I would coast to side of road. Shut off. Wait a minute then it would re-start. There are no check engine codes showing up. ECU?
Old Apr 19, 2010 | 08:50 AM
Nicks01CL-S's Avatar
"DD" Designated Drinker
do u have a check engine light? is it burned out or removed? what happens to ur gauges when it shuts off? does everything die and then come back? check ur ground wires of ur engine/battery/firewall/everywhere just in case
Old Apr 19, 2010 | 11:36 AM
RKeatF1's Avatar
My lights all work OK. no corrosion on battery. Gauges work. No loose wires visable. When it dies I still have battery because the radio would still be working. So it is not that. I still think it is ECU or I don't know if there is a relay going bad somewhere.
Old Apr 19, 2010 | 11:41 AM
Do the neddles on the dash ever stop working threw any of your issues ?
Old Apr 19, 2010 | 12:03 PM
Rajca's Avatar
Ignition switch or fuel pump relay. Common problems. Don't start jumping to the expensive stuff. Chceck the relay first
Old Apr 19, 2010 | 12:37 PM
Check your oil level, make sure that it's not low on anything
Old Apr 19, 2010 | 12:41 PM
HEAVY_RL's Avatar
Is there an alarm on the car? Seen this happen with a faulty brain box and kill switch.
Old Apr 19, 2010 | 01:58 PM
RKeatF1's Avatar
No alarm. Oil is perfect. Where is fuel pump relay?
By the tank?
Old Apr 19, 2010 | 03:42 PM
civicdrivr's Avatar
Under the dash on the drivers side.
Old Apr 20, 2010 | 06:59 AM
RKeatF1's Avatar
Thanks.
Old Apr 20, 2010 | 10:01 AM
could be a fuel filter... does the cl have a fuel filter?
Old Apr 20, 2010 | 10:43 AM
fuzzy02CLS's Avatar
It does, but it's attached to the pump in the gas tank. Replacement requires a new pump. It's not a maintenance item.
Old Apr 20, 2010 | 10:57 AM
civicdrivr's Avatar
Its easy to replace though, everything is in the trunk.
Old Apr 20, 2010 | 12:06 PM
Rajca's Avatar
Its not really a fuel filter. More like a sock. But u can change it out without replacing the pump. But I'm not sure if they sell it seperatly
Old Apr 20, 2010 | 12:17 PM
01RedCLS's Avatar
Check your fuel pump relay fuse .. not that it could be popped but the metal contacts could be FRAYED. I had this problem last year. The car would just DIE on me even on the highway! Once I replaced the blue fuse, no more issues.
Old Apr 20, 2010 | 12:58 PM
civicdrivr's Avatar
They do.
#6 - 17516-S84-A01 - Filter Set - List $23.23
Old Apr 20, 2010 | 03:35 PM
Rajca's Avatar
i consider that a sock. but ok.
Old Apr 20, 2010 | 05:10 PM
civicdrivr's Avatar
It basically is. I just copy/pasted what Honda calls it.
Old Apr 20, 2010 | 08:33 PM
OperationDarkie's Avatar
Ultra Negro
its probably the fuel pump relay, that happened to me several times in my civic, on hot days the solder would move on the relay or wiring whichever, and when I changed out the relay i never had the problem ever again.
Old Apr 21, 2010 | 03:09 PM
RKeatF1's Avatar
I am going to check the fuse. If it continues I will replace the relay. Its only $46
Thanks to everyone for suggestions!
Old Apr 22, 2010 | 09:26 PM
steve_97060's Avatar
My 2001 CL is having the same issue, we replaced the ignition switch about 3 weeks ago and didn't have anymore problems until 2 days ago. after reading this thread I have just changed the fuel relay fuse and will see what effect that has. appreciate all the suggestions, keep them coming.thanks...
Old Apr 23, 2010 | 02:05 PM
it was suggested to me that it could be the coil, anyone else have an opinion?
