AcuraSpook's Build Thread.
Old Apr 6, 2012 | 10:09 AM
  #161
richardparker's Avatar
3.7L Nitrous Breathing CL
Cams fit no problem.
Only thing spacers are for are to sit the pulleys further out to line up the belts.
After using the spacers you will have to shim the cam shaft sensors to clear the cam gears.
To elaborate on what civic said
You can keep CC but,you would run the risk of ruining the TB if you made a mistake.
you would have to work the shaft to fit the pulleys.
You could also use the acura tps but,you would have to completely chop off the end of the shaft and start grinding into the thicker part to get the correct mounting height.
The universal TB swap is not for the adverage joe.
Best to go obx 76mm and only have to worry about remote mounting icav and a little porting to the neck of the manifold to open it up as much as you can.
Also if your planning on running the mdx spacer and have to milled it in half you might as well just get longer manifolds horns it will do the same thing without the appearence of the high rise manifold.
Old Apr 6, 2012 | 04:41 PM
  #162
civicdrivr's Avatar
The TPS must be an issue with the TB you chose. Im running all Honda sensors on mine.
Old Apr 6, 2012 | 06:24 PM
  #163
AcuraSpook's Avatar
Weird
So the cams are just shorter than our stock cams? how did you safely space them? I think when I am turning 7,000 rpms I would like to be sure everything is solid. That is why I am trying to re-use as many stock components as I can... power meeting reliability.
Yeah I can not see there being a reason for changing sensors. A lot of Honda TBs are designed for the same things, such as TPS or IACV. On my old Accord I ran a bored Prelude TB, completely different design, but all the stock sensors were retained. Just their locations changed. I had to rotate the TPS to the correct degree to make sure it read zero throttle when the plate was shut but that was the only "modification" it required.
I might just have a stock one bored for now. 70mm is better than nothing. At least I will know that the airflow and Exhaust flow will be my weakest points when the build is finished, and I will have areas to push further next year...
Old Apr 6, 2012 | 10:51 PM
  #164
1foxbody's Avatar
03 CLS-6
Thanks for the pic of the flywheel! Do you have one of the other side? It does have a removable friction surface right? Good work on the build, subscribed for the hp numbers/et's.
Old Apr 7, 2012 | 09:19 AM
  #165
civicdrivr's Avatar
Yes, the friction surface is replacable. You can just make out the bolts that attach it in this pic:
Old Apr 7, 2012 | 09:45 AM
  #166
Yeah I can not see there being a reason for changing sensors. year...
measuring the cams to get lenths.
Also a few minutes to grind the shaft for the q45 tps or
A hour or 2 to get the lenth of the shaft cut right to get the oem key to fit that will turn the oem tps.
I don't know what I'm talking about
Pieces dissesembled from my oem TB
Some one else's pics so you can see where it goes.
The aftermarket shaft where it needs to go.
The shaft needs to be chopped off.
Then you need to grind into the thicker part of the shaft to be able to bring the sensor down to the mount.
And you will also have to knotch that shaft for the back side of the key so it will turn without slipping.
And finnally drill and tap once centered.
So why go threw the extra work to use a oem sensor when they read the same voltage ?
Old Apr 7, 2012 | 12:24 PM
  #167
Sonnick's Avatar
All motor
I wish Paul's 80mm setup could be flowbenched compared to the 3.7 manifold. One thing is that even it Paul's flows slightly better, the magnesium will stay much cooler, effectively reducing heat soak. Heat soak is a problem with our motors so reducing it should yield more consistent power.
Old Apr 7, 2012 | 12:26 PM
  #168
civicdrivr's Avatar
Because it was as simple as adding an extension collar and mounting the OEM sensor
Buy mine and you can have it flowbenched
Old Apr 7, 2012 | 02:32 PM
  #169
So your tps key is screwed right to the shaft ?
Then you added a big block to mount the tps to ?
Old Apr 7, 2012 | 04:31 PM
  #170
Sonnick's Avatar
All motor
Lol. You're selling the 80mm TB/manifold setup?
Old Apr 7, 2012 | 05:16 PM
  #171
civicdrivr's Avatar
It was part of the shaft.
Yep
Old Apr 7, 2012 | 07:51 PM
  #172
gnuts's Avatar
3.5 psi
ITB's?!
Old Apr 7, 2012 | 07:59 PM
  #173
Sonnick's Avatar
All motor
Ah you have cable throttle though.
Old Apr 7, 2012 | 08:20 PM
  #174
Originally Posted by gnuts
ITB's?!
more like a BRZ
Old Apr 7, 2012 | 08:23 PM
  #175
civicdrivr's Avatar
Old Apr 9, 2012 | 05:25 PM
  #176
AcuraSpook's Avatar
Weird
And on that bombshell.... we have to end tonight's show.
Old Apr 9, 2012 | 07:20 PM
  #177
AcuraSpook's Avatar
Weird
So today I was actually able to unpack and get the motors off the truck and onto stands in my barn. The CL-S motor looks clean as can be... only one busted oil pressure sensor and no Throttle body. The MDX motor looks like it went 175k+ (Because it did) but the valve train looks clean through the oil cap (No sludge or heavy deposit) so hopefully it was well maintained. Cant wait to start tearing these things apart and getting to the gritty.
Old Apr 10, 2012 | 10:30 AM
  #178
kingofdust's Avatar
In search of excitement
That is going to be fun as hell! good luck with the motor tear down!
Old Apr 10, 2012 | 10:48 AM
  #179
CL-S progression 01's Avatar
lowrd on tein CS biatch
damn son... one day i'm gonna have to spring on the whole 3.5l build..
dumb question.. but can u do it without pulling the motor and work from the bottom end of the motor and just do it from underneath to remove the crank, rods and pistons??
wouldn't this make it cheaper than pulling everything out to work on it? id personally be happy with just the added 300CCs. and then doing a port and polish on everything. in time that is
Old Apr 10, 2012 | 12:15 PM
  #180
AcuraSpook's Avatar
Weird
I sure hope it is going to be as fun as I think it will be :-) thanks though.
Yeah I'm going to have everything ported and polished while I can easily do so.
You cannot work on the motor that way, the block is where your motor mounts attach so your dropping the whole motor anyways to get access to the block. Even if you could do something like that it seems like would wind up cause more trouble than helping.
Its not a fast process, I'm hoping three months maximum to get mine together, I don't have a week to just dedicate to getting it done unfortunately. You have to very meticulous and careful with this type of assembly, a piece of dirt can destroy your brand new build believe it or not. I want to get this done so I can get through my break in period and enjoy more ...spirited driving haha.
Old Apr 11, 2012 | 10:35 AM
  #181
AcuraSpook's Avatar
Weird
Think this is going to be my caliper color combination....
and that this is going to me my new base color....
Old Apr 11, 2012 | 01:06 PM
  #182
1foxbody's Avatar
03 CLS-6
Is that the clutch masters stage 3 setup? How do you like it honestly? That's what kit I think I'm going to run also if it is.
Old Apr 11, 2012 | 02:17 PM
  #183
civicdrivr's Avatar
Indeed it is. Ive been running it for 53k miles without an issue. There is a spacer required for the release arm otherwise you wont get full travel.
Old Apr 20, 2012 | 12:23 PM
  #184
AcuraSpook's Avatar
Weird
Oh man super busy with school in the final few weeks but I have a question what is the thread pattern so that I can mount these motors on proper stands? 10x1.25mm is that correct?
Also picked up Neuspeed Strut bar and CT Axleback from BigdaddyKA8, Thanks again man!
Old Apr 20, 2012 | 12:49 PM
  #185
1foxbody's Avatar
03 CLS-6
For the clutch fork or the clutch pedal? Do you know where it goes specifically?
Old Apr 21, 2012 | 03:01 AM
  #186
gotjnco's Avatar
keep up the good work
Old Apr 21, 2012 | 01:15 PM
  #187
civicdrivr's Avatar
Its on the clutch fork, right on the pivot. Some people have bent the fork to get the correct amount of travel, but that weakens the metal and it will bend back over time.
Old Jun 1, 2012 | 09:39 PM
  #188
AcuraSpook's Avatar
Weird
Ok update:
Nothing for the build.
Installed Comptech Icebox (Much quieter [boo] that Injen, but safer and seems more responsive IMO actually. Feels slightly torquier mid range.)
Installed Neuspeed strut bar. (Only slight difference in tight cornering, worth 100$ when coupled with other suspension mods)
My pressure plate lost a tine (WTF never heard of this happening?) and cause quite a bit of a problem a few weeks ago.
Just in time for Finals at school, but finals are over now. I am finishing up this weekend, but I haven't been able to drive the car, much or less do anything with it, for awhile now.
The good news: I have all the parts (including flywheel) that I will need to repair.
Bad news: I have no lift. Was going to do this when swapping motors this summer anyways. Boo.
So, needless to say, once this is corrected, I will be back on track for the build. Life does funny things sometimes.
I miss the car far more than I ever realized I would, stuck driving a 1994 accord Ex auto make me really appreciate my car (not that I didn't, but just how much it brings to my life every day I drive it.)
Puts you in a right funk when you lose your pride.
Good news is summer is here full swing, hopefully the build will gain some serious momentum!
Old Jun 1, 2012 | 10:01 PM
  #189
gnuts's Avatar
3.5 psi
I hear ya on missing the CL. Been driving my winter beater since November! Good luck with things.
Old Jun 28, 2012 | 10:02 AM
  #190
AcuraSpook's Avatar
Weird
Been so busy lately, but things are calming down so more time for the car now. Replaced my clutch, the disc that was in there came loose (the organic material) and was loose in the housing. It was a crappy brand-Luk? I found their stuff on websites like Auto parts warehouse and similar "I'm to cheap for dealership stuff so I'll pay 10% less on money a 50% less quality part" websites. The clutch was only at about half life! Either way its been 1200 miles so I'm finally broken in now, and I have to say the Exedy+AASCO flywheel is what the car should feel like. The car just accelerates so much more willingly now. Kinda like its new and eager again. The stainless slave line make the pedal a little firmer and quicker to me back. Also got the hybrid racing shifter bushings in... between all that, my shifting experience has been transformed to the sublime
just wrapped up the RL bbk last week, still bedding. The SS lines are great and the brakes bite so hard, and really make the car look so good. Got the tl-s wheels on the clear them.
Next up I was able to get the front and side motor mounts (exr8 8~ durameter) in, and that had helped minimize wheel hop greatly. Waiting to do the rear because well, I might be putting a motor in real, much sooner than I had originally anticipated
Pics later
Old Jun 28, 2012 | 10:21 AM
  #191
AcuraSpook's Avatar
Weird
Old Jun 28, 2012 | 02:31 PM
  #192
civicdrivr's Avatar
LUK makes the OEM stuff
Old Jun 28, 2012 | 04:17 PM
  #193
AcuraSpook's Avatar
Weird
Oh I thought it was Diakin. We did it at this guys house my dad works with (he has a lift) and he's worked on Hondas for 30 years and my dad its been ten now and they both said it was not OEM equipment. Then again they probably neither have ever had to do a six speed manual.
Either way the Exedy unit feels smoother but stronger somehow. I hope it can stand up the the 3.7l that's going in...
Old Jun 28, 2012 | 06:50 PM
  #194
AcuraSpook's Avatar
Weird
Although if LUK was the OEM supplier that would make sense because I half expected the clutch to be the stock one... hmm.. I'all grab pics of the old one tonight
Old Jun 29, 2012 | 09:57 AM
  #195
SPoolinspOON's Avatar
OG 3.x^7 rawr
I can confirm this statement.
Old Jun 29, 2012 | 11:50 AM
  #196
AcuraSpook's Avatar
Weird
Cool
And my next mod is going to be... removing my foot from my mouth!
I just have always heard not so go things about Luk, I suppose I am very surprised. Maybe it was the original clutch then. The pressure plate had springs on the center of the hub. It looked kind of like a staged kit almost. But the clutch disc was still organic compound. I know the flywheel that was in there was the dual mass OEM one.
Old Jul 2, 2012 | 11:16 PM
  #197
bigdaddyKA8's Avatar
Damn, that's it... Tomorrow I'm starting my build thread. Im tired of buying shit to have it sit in the garage. Thanks for the motivation Spook!
Old Jul 3, 2012 | 11:33 AM
  #198
AcuraSpook's Avatar
Weird
Do it KA8! Speaking of the devil, you don't need anything I've got in the BM do you man? I'm I'm Silver Spring Thursday night through Friday, I wound up doing what I told you I wasn't going to do and buying a pre-built motor, I'm picking up SPoolingspOON's 3.7l. I could pass it up, I only sold everything I owned to get it haha
Old Jul 3, 2012 | 12:48 PM
  #199
JCharged's Avatar
^ so you're the one...
Old Jul 3, 2012 | 02:03 PM
  #200
civicdrivr's Avatar
I was wondering who it was going to be.
Hey, if you still want an exhaust, mine is sitting at Pauls, Ill make you a deal on it since youre there
