AcuraSpook's Build Thread.
Old Mar 29, 2012 | 09:59 PM
  #121
AcuraSpook's Avatar
Weird
Well that is it, I am not bailing so easily on this car
I decided I will be rolling with this car long enough to actually spend some $$ and make this car all that it can be...
I ordered the Comptech Ice Box
P2R thermal taskets (All)
P2R TL SH-AWD intake manifold TB adapter
Exedy OEM clutch replacement
AASCO aluminum flywheel
Comptech short throw shifter
Hybrid Racing shifter bushings
Stainess steel clutch line
XLR8 75a mounts
XLR8 high flow cat
Stainless brake lines
Won some RL calipers on Ebay
EBC red stuff pads
EBC USR Slotted sportimax 12.8" Rotors
Got two motors also for a few hundred each:
J35a4 from 02 MDX
j32a2 from 01 Cl Type S (only 68k!!!)
Going to tear down and service the block and heads from the j32a2,
tear out the rotating assembly from the j35a4 and have that all machined and treated back to tolerance (Hopefully be able to afford a crank lightening, I have heard so many good things about that procedure.)
Then I am going to make sure the mdx block is serviceable, and bore each cylinder .25mm and stuff the .25mm over bore RL pistons in the block along with the MDX rotating assembly. Replace bearings and seals and gaskets.
Re-assemble with the UR pulleys and Comp-tech headers and new water pump, timing belt, tensioner, all right on board.
My father is going to be handling the engine assembly, hopefully I will be able to learn a lot about this process. He said we can probably just drop the sub frame out with the motor attached and swap it all on the ground then stuff it back up in. Hoping to be done with this in two months so that the brake bedding and engine break in and the clutch break in period can all expire while it is still nice out around here. I want to go hunt some older mustangs and corvettes haha.
Figuring with the A'PEXi Neo and harness I have I can at least get a decent street tune, and am shooting for a solid 280whp. that would mean well over 300 at the crank, reasonable enough for me. I just wish these cars were RWD so much so. They would be perfect haha.
Next year I'll redo the suspension and hopefully get a catback, that should keep me happy until I cave and spend to put a blower in.
Old Mar 29, 2012 | 10:20 PM
  #122
civicdrivr's Avatar
Congrats!
BTW, its pretty easy pulling the engine out from the top. Dropping it along with the subframe is a bit more work.
Old Mar 29, 2012 | 10:34 PM
  #123
AcuraSpook's Avatar
Weird
Congrats!
Thanks.
Somehow it all feels right, sticking with this car for awhile. I know she isn't ever going to be RWD, but the comfort, and cheaper parts, (Dad hooks me up haha) and the rarity of this car suits me.
I love that so many other drivers have no idea what to make of it when they see it, they have no gauge on what they are capable of.
I am low on money now though, and still need the machine work. Anybody tell me what a reasonable figure to guess what the machine work will cost?
I am hoping like less than 600$ (perhaps I am too optimistic though.)
I am saving a ton in labor though, the whole build is probably going to be well below 2k though which isn't bad IMO for the level of power and reliability I will have.
That only leaves suspension work, and exhaust, and tranny rebuild, and this will be an all new car, capable of another decade of good fun haha.
Old Mar 30, 2012 | 12:41 PM
  #124
AcuraSpook's Avatar
Weird
Well I forgot that RL BBK doesn't clear stock CL-S rims, so I just picked up a set of 2008 TL-S rims. I will just stretch the S-drives from 225 to 235. I doubt they will look wonderful but they will be lighter and clear the BBK. Next year I will have to get some decent rims. My stupid but sold the Type C SSRs because I was offered 1000$ from them and I paid 300$ I was a little tight at the time then, so I took the offer.
Old Mar 30, 2012 | 02:05 PM
  #125
richardparker's Avatar
3.7L Nitrous Breathing CL
I got my cylinders bored and honed for $20 per hole.
Old Mar 30, 2012 | 09:21 PM
  #126
AcuraSpook's Avatar
Weird
That really is not bad at all. I am wondering what my total will look like, I am doing as follows:
Crank: True and polish
Rods: Magnafluxed
Block: Honed and .25mm Overbore
Heads: P&P
Thanks for the info!
Old Mar 30, 2012 | 10:16 PM
  #127
XxXboboXxX's Avatar
Told Ya'LL...DYNASTY !!
Originally Posted by zeta
Interesting, if you go to CT's website, you cannot find headers for either the 2G CL/TL.
Yupp, actually if you check out their Facebook page they have a pretty awesome time lapse video of those headers being welded/assembled... Was curious who scooped up the last pair made!! good stuff!!
Old Apr 1, 2012 | 03:00 PM
  #128
AcuraSpook's Avatar
Weird
Hmmmm looks a lot faster on there, I waited four months for the part
Old Apr 1, 2012 | 09:42 PM
  #129
AcuraSpook's Avatar
Weird
shift-feel make over, and half the brake components are here!
Old Apr 2, 2012 | 05:54 PM
  #130
AcuraSpook's Avatar
Weird
The pile grows, my patience diminishes. I cant wait for this summer. The engines are en route finally. Paid 700+150$ for motors+Shipping for the MDX motor and a 68K 01 CL-S motor. Going to build everything in the 68k CL-S Block and heads (Pending no nasty surprises) and then do the swap in one day. Minimal down time, getting all the parts like Pulleys and headers and timing belts and tensioner on is easier, will be a perfect opportunity to install the AASCO Flywheel and Exedy Clutch I have coming....
Needless to say I am super excited. I would like to have this all in and breaking in by June's end. That gives me about three months.
Old Apr 2, 2012 | 06:56 PM
  #131
XxXboboXxX's Avatar
looks good!... RL BBk is on my radar as well!! jus waiting to see how XLR8 & stop tech bbk comes out!
Old Apr 2, 2012 | 07:10 PM
  #132
civicdrivr's Avatar
Out of curiosity, why are you using the CL block and not the MDX block?
Also, why the two motors?
Old Apr 2, 2012 | 09:41 PM
  #133
AcuraSpook's Avatar
Weird
To address the first half, I wasn't sure if the block was exactly the same, and since I need to do the swap quickly I figured that having the correct block would help tremendously (Plus look the cl motor has only 68K on it. For the $425 the motor was I couldn't resist. Spare coil packs, less worn cam shaft than my 165k motor, block should still be immaculate, ect.)
Most importantly the mdx motor was $250, I can rob the rotating assembly and sell off at least $200 in parts to put back into the build. I only need the crank and rods. Plus I heard the injectors were the same CC but better spray pattern.
The idea is that I can build the whole motor separate. Then when swap day comes, it will literally be plug and play. Everything should just swap over neatly. Then I'll have a parts motor or something to sell off in order to keep my modding moving forward. A working CL-S motor should be worth a few hundred I can then put back into the suspension or something. Especially with J-swaps becoming so popular...
Old Apr 2, 2012 | 09:43 PM
  #134
AcuraSpook's Avatar
Weird
Thanks! I was unaware that XLR8 was doing anything to make a new kit. That should be nice when it comes out, they are one of the few shops that actually seem to dedicate their time to our car...
Plus I'm a sucker for the RL look. Big old OEM ACURA staring back at people on the highway...
Old Apr 2, 2012 | 11:54 PM
  #135
civicdrivr's Avatar
Sooooo many people stare at the brakes. Even the [few] people in RLs
Old Apr 3, 2012 | 01:57 AM
  #136
1foxbody's Avatar
03 CLS-6
The more and more I look at rl calibers it makes me want to buy them. Nice looking parts collection, keep up the good work!
Old Apr 3, 2012 | 02:04 AM
  #137
civicdrivr's Avatar
IMO, even if you are keeping the car low key, go all out on the caliper color.
/pic whore
Old Apr 3, 2012 | 02:20 AM
  #138
XxXboboXxX's Avatar
thats literally the one thing thats making me want to go with the RL brakes... The OEM quality, finish, and acura stamp.. especially with a nice powder coat on the calipers!!
Old Apr 3, 2012 | 10:26 PM
  #139
AcuraSpook's Avatar
Weird
Yeah I think they don't realize what they have until the see it out of context...
Thanks... I am feeling so excited all the time now just knowing this storm is gathering.
/pic whore
Definitely going to stay low key. Honestly I might be boring and just do black crinkle finish..... for now.
Less attention is better. Not every civic and cobalt will try to rice past me because I have a set of rims on.
sums it up nicely
Old Apr 3, 2012 | 11:32 PM
  #140
civicdrivr's Avatar
No many Civics and Cobalts bother with me either.
I very rarely get many cars to play with, which sucks. I love hurting peoples feelings
Old Apr 4, 2012 | 12:39 AM
  #141
AcuraSpook's Avatar
Weird
Talking
Yeah no one ever seems to race me either. Audi tt and a hyundai tiberon were the last two who tried to mess with me and discovered what CL-S6 is all about. I think the low profile style of the cl contributes to that, but its a double edged sword. Now if I accidentally cruise past a cop hauling ass they don't seem to look twice... I love and hate it. I'm hoping BBK and my mods will change my "road presence" enough to draw a few fair fights...
The CL-S6 is such an odd ball segment. 260 horse, but pulls even harder than most around that, and there aren't many. 350z/g35 are really the only legit segment match up on paper.
Then on the road I find the CL-S6 barks well up other 'bigger' dogs' trees. It's really odd.
Old Apr 4, 2012 | 12:47 AM
  #142
civicdrivr's Avatar
Agreed. As I mentioned in one of Fox's threads, the CL can definitely punch above its weight class.
Ive hung with cars I clearly shouldnt have. But out here most of the cars I want to race dont want to "waste" their time When I do get a fair race, its usually these damn ricers that dont even require me to downshift.
Old Apr 4, 2012 | 01:19 AM
  #143
1foxbody's Avatar
03 CLS-6
Lmao exactly!! Before we raced I actually had one of the guys I ran last weekend driving the k series car say he would never expect that from my car it's a true sleeper since he saw me race the wrx sti earlier. Then after the race he said that's the fast cl he's ever seen in his life lol. I was laughing that whole night about what happened and peoples reactions.
Old Apr 4, 2012 | 08:44 AM
  #144
gnuts's Avatar
3.5 psi
i've only ever had one car try and mess with me and i realized i can't launch this car, lol.
I drove to Myrtle Beach and all i see are SUV's in the states!
Old Apr 4, 2012 | 09:01 AM
  #145
kingofdust's Avatar
In search of excitement
Hahah you aren't in the right areas then!!!
Spook, have you tried the short shifter part of that kit yet? I was skeptical when I saw it online.
Old Apr 4, 2012 | 09:39 AM
  #146
jeffcosta123's Avatar
8th Gear
I was wondering what car do those calipers come from that say acura on them?
And do those rotos that are black, do you have better performance than some normal colored ones that are drilled and slotted?
Also are these good upgrades: radiator (3 or 4 rows) and transmission cooler (I want to used braided lines)?
Old Apr 4, 2012 | 11:14 AM
  #147
AcuraSpook's Avatar
Weird
That was from a roll right? Those damn 4wd cars that use three gears to get to sixty are stupid fast off the line. All the rex STIs are like sub 5 second 0-60... then an eternity to 90 haha.
Same boat. It's bad in Buffalo because all the nice cars are only out for ~ four months. So the only things I ever see that are fair races during the non summer months are Mustangs and Camaros... not exactly exciting match ups.
Lately I have seen a few things like Genesis =around though... and the 3.8l seem be just about in our realm....
You 6 Speed Gnuts? I have found the quickest way to launch this car is actually only around 3k, just enough to give a quick chirp, roughly half throttle until you are sure you're fully hooked up. You launch quick and are in peak torque right away.... This car is far to rowdy to just go. FWD at work
That is on my to do list today or tomorrow. I have been working non stop the past five days... finally only work four hours today and none tomorrow so U am going to actually get something done...
05+ Acura Rl
They are coated to prevent rust. The black will wear off where the pads touch still... but the rest will remain nice. Especially important here in Buff,the rust is a killer. Color doesn't affect performance :wink:
Tranny cooler for Auto: Yes
Radiator: only is you are running really high boost or some crazy track setup. These cars usually don't have over heating problems.
Old Apr 4, 2012 | 12:31 PM
  #148
civicdrivr's Avatar
The Genesis' arent that difficult to beat. Theyre heavy. Ive beaten one of the V8 sedans too. I havent raced any of the new coupes yet though. The new V6 should be an exciting race.
And whenever I go from a stop, I do a "street launch". I roll out for about 5 feet then get on - and I still end up having to pedal it.
Old Apr 4, 2012 | 09:56 PM
  #149
duyx817's Avatar
DFW AREA,
you need a drop asap!
Old Apr 5, 2012 | 12:24 AM
  #150
AcuraSpook's Avatar
Weird
I only raced a 2.0T... it was a joke. He was able to leap out half a car on me off the line (RWD ) but after that I walked away like he was standing still. I waved as I drove by and he lost it hahaha.
I'm on eibachs... Really isn't anything more I can do besides coils....
Old Apr 5, 2012 | 12:52 AM
  #151
1foxbody's Avatar
03 CLS-6
Yepp we went from a 20 and 40 roll. We were both in the same gears pretty close to the same time sooooo lol. Yeah I agree awd's can 60ft good!
How much did you pay for the aasco flywheel if you don't mind saying? Any pictures?
Old Apr 5, 2012 | 09:11 AM
  #152
AcuraSpook's Avatar
Weird
~500$ XLR8 can get them even though they are not listed on their site.
I'll post pictures when I get it :wink:
Old Apr 5, 2012 | 12:41 PM
  #153
termo001's Avatar
@civicdrivr did you paint/powder coat the rear calipers the same color? What color is that by the way?
Old Apr 5, 2012 | 01:38 PM
  #154
AcuraSpook's Avatar
Weird
Motors came!!!
So did flywheel and motor mounts and P2R thermo blockers/adaptors.
Also going in two weeks to pick up CT mufflers (Thanks Bigdaddyka8!) and going next week to pick up a 3/ valve job head from Rush. That means I only need a TL SH manifold and the RL pistons and various rings, seals and gaskets and all the parts are assembled. Then it is a matter of time and machine work. So excited that this is all coming together so nicely. Considering that my father and I are doing all the labor this really is not costing me as much as I had feared...
Old Apr 5, 2012 | 02:23 PM
  #155
AcuraSpook's Avatar
Weird
Ok just t clarify some things... I would love for those with actual first hand experience to chime in here. I have done a lot of reading on these subjects to try and sift out the crap from the correct. There are a lot of thread that do not actually verify or deny claims and I really need to try and get all this straight. Anyone who can legitimately make a claim or answer please do so...
Motor Questions
All CL-S and TL-S motors are the same. There is not a single difference between the two. t/f
There is a difference between the CL-S 6 speed motor and every other j32a2, the difference is only the addition/absence of the VSA module and the camshaft Position sensor. The mechanical aspects are identical across all J32a2. (Camshaft, Block, crank, pistons, rods, bearings, valve springs, valves, ect) t/f
For the 3.5l MDX swap, the crank and beearings and rods are used from the MDX motor. The Pistons and rings come from either 01-03 CL-S or 05+ RL. t/f
The RL piston actually has 11:1 compression ration in the 3.5l build (There were descrepencies on that point that I could not verify.) t/f
The 05+ TL Type S valve spring may be used in the 01-03 CL-S and 01-03 TL-S with the 05+ TL-S retainers. These springs are stiffer than the stock CL-S and help prevent valve float/allow for a more aggressive camshaft. t/f
The j32a2 block is best for the 3.5l swap due to it having stronger steel sleeves. This helps with the heat and forces created during high rev operation. t/f
The MDX crank and block is superior to the Oddy crank due to the MDX crank being forged. t/f
There are no performance camshafts for the J series. The only thing available are regrinds by Bisimoto (through Webcam) There is not any end user testing of this cam re-grind, but is not a good choice for reliability reasons. t/f
Oddy, MDX and CL(S)+TL(S) motors all have interchangeable blocks. The j32a2 head is the highest performance head from the factory. The Oddy block is inferior to the MDX/CL(S)+TL(S) blocks, which both have forged internals vs. cast. t/f
The 05+ TL-S camshaft is usable in the 01-03 CL-S and 01-03 TL-S. This however requires a shim to properly fit, and shows minimal gains. NO machine work is required to any other part of the head. The only noticeable major benefit is the lighter weight because the 05+ TL-S cams are hollow t/f
With the P2R adapter, the 09+ TL-SH AWD affixes to the j32a2 head .With electrical work this setup retains the j32a2 butterflies. t/f
The above mentioned IM has roughly a ~75mm opening, but the stock j32a2 TB may only be bored to ~71mm. t/f
That is all I can think of right now. I will be compiling all of this stuff to hopefully create a huge resource with a ton of FAQ and not so FAQ to help people with upgrades and swaps for the CL-S and TL-S. Thanks again guys.
Old Apr 5, 2012 | 03:49 PM
  #156
You should do something crazy if you going to do a build looks like you could afford a nice build to me.
07 - 08 tls cams are the hollow ones.
Old Apr 5, 2012 | 04:34 PM
  #157
XxXboboXxX's Avatar
Wow, your really moving along here! Can't wait to see the finished outcome... Looks like this thread is going to hold a lot of good information for future builds!!
Old Apr 5, 2012 | 04:51 PM
  #158
civicdrivr's Avatar
Havent done the rear yet.
Motor Questions
true, J32A2
The crank sensors are different as well. The Auto has one crank sensor and its a Mag sensor (iirc). The manual has two, one on the timing belt side and another on the bellhouse and its a Hall sensor(I may have the sensor type backwards).
True
Eh. There are conflicting reports.
True, exhaust side is the most important.
IIRC the J35A4 in the MDX has the same sleeves as well. However, the J32A2 block has reinforcements (supposedly).
Its not really forged, but yes.
True
The bigger difference between the Honda blocks and the Acura blocks are sleeves. As for heads, Ive heard different things from different people.
But all blocks - aside from the J37 - are interchangeable. The bore is the same 89mm.
True, TL-S cams.
True. However, IMVHO, that setup doesnt breath enough for stroked motors.
True. And the TB bore of 71mm is at the inlet. It tapers to a smaller diameter.
Old Apr 5, 2012 | 09:24 PM
  #159
AcuraSpook's Avatar
Weird
Actually, I am flat broke thanks to all this. I am selling stuff to complete the build. I am just getting everything assembled to make sure I do everything once, and only once. Do it right the first time IMO.
Did you need shims to fit this cam richard or does it fit? I like the idea of a cam that is designed to use more displacement. Thanks for the info...
Yeah I have had half these parts since last year, and half from taxes this year. One more year and this car will be pretty tidied up. I hope this becomes a well of knowledge for future individuals walking my path. Thanks for the support. If it wasn't for these forums and those going before me I never would have thought to do half of the amazing mods the community cooked up.
CIVIC
Thank you for all the information. You have been the most indispensable resource for my build. Your time and patience with my questions have been the difference between this being a pipe dream and a reality.
I hope when I am all done to compile this information and make some sort of compendium to help others.
I see that you don't think the TL-SH AWD intake manifold is STILL enough for a stroked motor... I was going to use the spacer of my MDX motor and the SH-AWD swap also to see if I can maximize my output. Also your 80mm TB was custom made by Paul wasn't it? Also the SH-AWD IM cannot be ports due to its material design correct? If so were you able to retain Cruise?
That might be wort looking into over spending on a port. I am trying to do everything right the first time.
Old Apr 6, 2012 | 05:33 AM
  #160
civicdrivr's Avatar
The MDX spacer wont fit unless you mill it down. I had mine milled in half and the manifold still hit the hood.
I did have Paul build the 80mm TB setup, but I didnt use the 3.7 manifold for it. CC was not retained, but you could given enough fab time. It wasnt a top priority for me.
The 3.7l manifold could be ported if you are very careful, but its a bitch due to the material.
