*** Official Uni-Chip Group Buy ***
Old 06-28-2004, 02:32 PM
  #1641
mrsteve's Avatar
Originally Posted by Jonesi
I wish there was another way to test this to make sure I'm seeing/getting what I paid for.. How far away is that place from me ?
A good 3+ hours. You never went to the track either so you don't have baseline ETs.
mrsteve is offline
Old 06-28-2004, 02:42 PM
  #1642
Jonesi's Avatar
No, but I should be able to atleast see gains with the basic bolt-ons and have a general idea.. Also with being able to just unplug the chip I should atleast see gains from it.. If not I know I have a problem..
Jonesi is offline
Old 06-28-2004, 04:01 PM
  #1643
EricL's Avatar
Changes in ECU/PCM during transitions...
Originally Posted by mrsteve
I might be going to Altered Atmopshere tomorrow and see what they can do.
I am on my second transmission with the new PCM. This might make a difference eh?
I don't see why it should; at least not when doing a "pull" on a dyno.
PCM changes were "supposed" to be limited to slight change in RPM limits during shits. The solenoids that control the shifts get a slightly different "profile" during the shifts as well. The docs submitted to the NHTSA showed higher Gs during the shifts. This doesn't mean there is more "overall" acceleration; it just means that there is more "shock" during the shifts. If you don't slip a clutch as much, you get slightly harsher shifts -- and this is interpreted as higher G force during the shift transitions. I believe the advance is changed a bit too during transitions.
EricL is offline
Old 06-28-2004, 04:16 PM
  #1644
mattg's Avatar
mrsteve, how many pulls the dyno shop do with your car? w/ chip and w/o?
mattg is offline
Old 06-28-2004, 05:05 PM
  #1645
Louie11's Avatar
I have a 4pm appointment tomorrow at Garage Kwai for a baseline dyno run, Then another appointment next week tuesday with chip. I want to make sure the chip's settings have set in and the ecu has adjusted properly to get some true results. Since some people are saying they didn't feel the power right away. This might help or I'm just waiting a week for no apparent reason
Louie11 is offline
Old 06-28-2004, 05:06 PM
  #1646
mrsteve's Avatar
Matt, I did 2 pulls on each setting and 2 on the stock setting. Only two pulls are shown on the graph because with 6 different pulls the graph gets very cluttered. They represent a stock ECU pull and a Map A pull.
I'm getting everything worked out:
http://www.acura-cl.com/forums/showt...93#post1900193
mrsteve is offline
Old 06-28-2004, 05:07 PM
  #1647
mrsteve's Avatar
Don't wait. Install the chip now and make your FIRST runs with the chip. Then take the chip out and run the stock ECU. No need to have two dynos if you don't need to. Make sure you get your A/F ratio tested during the dyno too!!! You shouldn't be much higher than 13.2 according to Uni-Chip.
mrsteve is offline
Old 06-28-2004, 05:27 PM
  #1648
Revving at 9K...
CLS2001_97124's Avatar
This is very interesting reading that has to do with gas and piggyback ECU's provided by Ericl.
http://www.acura-cl.com/forums/showt...=145614&page=2
I think this artical deserves some attention in light of whats been happening with some Unichip owners.
CLS2001_97124 is offline
Old 06-28-2004, 06:39 PM
  #1649
withoutcomp1's Avatar
Well i am finally happy! I received my unichip today! But i am going to have to call them up and see if it is the same connections as the zex dry kit, (i have a nitrous express wet kit) NOW ALL I NEED IS MY CAR BACK!! It's only been two months (sarcasm) I went out and bought an 04 civic just so i can back and fourth to work! Oh well one day i will get it back (I Hope)
withoutcomp1 is offline
navtool.com
ILX Audio, Bluetooth, Electronics & Navigation
32
12-22-2015 12:46 PM
navtool.com
11-16-2015 08:03 PM
navtool.com
ZDX
10-31-2015 08:26 PM
navtool.com
14
10-31-2015 08:16 PM
navtool.com
09-25-2015 06:21 PM
Quick Reply: *** Official Uni-Chip Group Buy ***
