*** Official Uni-Chip Group Buy ***
#1601
Originally Posted by CLS2001_97124
Also, remember guys, trying out B map without some higher oct gas does you no good. If anything, you car will produce less power. I wouldn't waste the time.
The gas station i'm going to has 100 and 105 which should I get. And I can only get enough to fill a gas can. They won't let you fill it directly into your car. So 5 gallons of which 100 or 105?
#1604
Originally Posted by scalbert
If you are mixing with 93 then I would go with the 105. But whose 105 is this??
#1605
Luvn' the S
Originally Posted by mrsteve
Yep. Already thought of that. 1st runs will be with Map A, then probably 2 with Map B running 100+ octane, then i'll uninstall the chip for baseline.
#1607
Luvn' the S
#1608
I don't remember what gas station brand it is. I'm down to less than half a tank. I drove 240 miles yesterday LOL. To get the gas is another 20 miles to the station and then another 15 or so to the dyno. So I will only have maybe 7 gallons, give or take a gallon, by the time I'm at the dyno.
((93 * 7) + (105 * 5)) / 12 = 98 octane final.
#1610
Originally Posted by withoutcomp1
Yeah, I feel i go screwed! I don't think i should have had to pay more considering that i have no b map now, only A and nos i think it should have been the same price
#1611
Revving at 9K...
I think Matt should shed some light on what was needed in order to get his car the way it is. I mean, from what I've read, not only they made more power with the Unichip on Zex, they also made it safer, and staright forward by intergrating their chip with the Zex switch. I mean, you are literally getting a whole different product then what the NA guys are getting if you think about it. Different map, different wire hook up, and a different setup for switch controls. I think say if one of the guys later on went NOS, and it probably cost about that to get it remapped and rewired?
#1612
Okay cool, thanks for explaining it a little better Todd really didn't tell me anything of why it was costing more. Sounds good now i just need to get my car back! Will it come with instructions on how to connect it to the NOS ? Thanks alot guys! Now i don't feel like i got screwed that you explained it better. i can't wait!
#1614
I would think the memory seats would be deleted once you unhook the negative cable. I didn't attempt to use them so I wouldn't know for sure. Don't know about the auto down (don't have up) though. ![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
#1615
I think you missed my previous post... a few pages back
What exactly do you mean by turning it off? you mean unplugging it? If so, then no, the dealer will not be able to detect anything unusual.
#1616
Revving at 9K...
The other switch is the ECU reset switch. There is no on/off button for this chip. You want it off, you'll have to just unplug it. Should be in the instructions. :o
#1617
#1619
#1620
Not Asian
But then we have this thread...http://www.acura-cl.com/forums/showthread.php?t=145395
#1624
Originally Posted by J.T.'s 3.2TL
I hope everything ends up working out. Hopefully they just didn't see a bunch of eager people and developed a product that doesn't work as advertised.
Is it funny that the only dyno's we have seen (besideds mine) are directly from Uni-Chip??!? Hmmmm... little fishy if you ask me. Plus they weren't actual whp they were crank corrected. This all makes me sick right now.
![Hurl](https://acurazine.com/forums/images/smilies/hurl.gif)
#1626
Originally Posted by darrinb
mr. steve i know your pissed but this may not be uni-chips fault, could be a # of different factors
before u put in the 100 octane how did your butt dyno feel???
The butt dyno felt like there was power there, but that may have been because when I reset the ECU I felt like power had been lost until I had drove around a lot.
#1629
i will write up my review as soon as i get strap it on, gonna do a dyno soon too
#1630
Revving at 9K...
Is it funny that the only dyno's we have seen (besideds mine) are directly from Uni-Chip??!? Hmmmm... little fishy if you ask me. Plus they weren't actual whp they were crank corrected. This all makes me sick right now. ![Hurl](https://acurazine.com/forums/images/smilies/hurl.gif)
My original dyno was done at a 3rd party dyno shop, and this shop has been around for a long time, longer than/prior to Unichip moving from CA to OR. I've posted that dyno as well as the Unichip version.
mrsteve, i know and understand how you must feel, but lets just wait and see what others have come up with in terms of results. Your statement about question their dyno could be said about yours, lets just wait and see how others do, and if the result is the same, I will go down there myself to get an answer from them personally.
![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
#1632
Luvn' the S
I just made an appointment at Performance Autosport in VA that has installed a Dynojet 224x. They do mostly Saleen Mustangs there but their dyno is open to all. I told him that I'm interested in a with and without Unichip dyno and a/f results. Mike, the owner, was like "yea... those chip guys (generically speaking) can talk some big gains... bring it on down and we'll show you exactly your gains." Just as an additional reference Can't get there until Sat. morning though.
#1634
Steve,
Thanks for the e-mail. This should be a pretty easy fix. The car is obviously a bit too lean, and but that can easily be accounted from individual vehicle tolerances, and can be quickly corrected.
One thing to note from the dyno sheet is that even being too lean, the only place the car’s making less power is above 6,300 rpm. (Yeah like 2 more whp) It will definitely make more power once the Unichip’s directed to get a bit more fuel in there. Do you have any other modifications on the car other than the intake, headers, and axel back which might account for the difference?
I see you got the dyno pulls at Altered Atmosphere… they are a Unichip shop although they haven’t done anything in quite a while. Is there a reason they didn’t just jump in there and add some fuel? If the car was already on the dyno, they could have corrected the A/F in ten minutes.
To correct things, we can proceed one of two ways. The best would be to go back to Altered Atmosphere and have them do a tune. Alternatively, you can send the Unichip back and we’ll modify the map to pull less fuel at full load. The later I can do for free, but you’d have to work something out with AA.
Tony my lead tuner will also call you later today to find out how you want to proceed. You can also shoot me an e-mail.
Jack
Jack Friedman, General Manager
Unichip of North America
www.unichip.us
Toll free 1.866.643.7400
Local 1.503.6407465
Fax 1.503.214.6444
Jack
www.unichip.us
Local 1.503.6407465
Fax 1.503.214.6444
I am on my second transmission with the new PCM. This might make a difference eh?
#1635
Audi S4 driver
Great to see that jack is standing by it. Weird that Altered Atmosphere didnt tell you they were a unichip shop though, and weird that they didnt offer to go in and fix it in the first place. ![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
I still swear I feel gains all over the place, but it IS starting to act a little weird. Once or twice I hit the gas and it felt like it hesitated then went. Sometimes at like 1\4 throttle the engine will be revving but it doesnt feel like its making power, then all of a sudden a little above 3K RPM I get this surge of power that feels as strong as VTEC engaging, and the car pulls HARD as hell to redline. Other than that the car is definetly running stronger all through the RPM band, straight to redline.
#1636
Only disapointment is that I feel I have to do some dyno runs now to make sure I'm getting what I paid for. And may have to travel to a UniChip dealer to make things easiest.. Hmmm..
#1637
Originally Posted by Jonesi
Only disapointment is that I feel I have to do some dyno runs to make sure I'm getting what I paid for. And may have to travel to a UniChip dealer to make things easiest.. Hmmm..
