Hard to start the car
Old Oct 28, 2005 | 09:38 AM
afax226's Avatar
Does anyone notice your car takes a few more cranks to start sometimes? Mine is stock, no mod (Please don't ) . There were a couple times that I thought it wasn't going to start. It did afterall but barely.
Old Oct 28, 2005 | 11:07 AM
peter_bigblock's Avatar
C'mon, man! Row yer own.
I've noticed it on occasion, takes a little longer to turn over and light up. I'm going to try the DIY grounding kit, see if it improves.
Old Oct 28, 2005 | 11:46 AM
afax226's Avatar
OK, Keep me posted!
Old Oct 28, 2005 | 12:11 PM
joerockt's Avatar
Just dial 1911
Stock battery is crap IMO. Pick up an Optima...
Old Oct 28, 2005 | 01:15 PM
LoveMyTL-S's Avatar
My car is coming up on 25K Miles with no starting problems..............
Old Oct 28, 2005 | 01:28 PM
JoesTSX's Avatar
Custom TSXr's
Owners manual states this is normal. The car is trying to find the best way to start with the lowest emissions. But if it is taking too long to start there may be another problem.
Old Oct 28, 2005 | 03:50 PM
wesleyl524's Avatar
Thanks for pointing that out. I had this happen earlier today. Do you know what section of the owner's manual its in and if its an '05 what page.
I thought i read all of that.
Old Oct 28, 2005 | 05:26 PM
What's the difference between a good and bad battery? How can you tell?
Old Oct 28, 2005 | 06:40 PM
kyotousa's Avatar
he can't...just assumes.......
well maybe it is crap.....but who cares when you only have the car for like 3K miles.
anyway i have the same problem......but i guess that's not a problem at all
thx for the info.
Old Oct 28, 2005 | 06:45 PM
Powered by Honda's Avatar
You have to show your car love and say common baby. Starts instantly. Dont even need key once you become one with your car.
Old Oct 28, 2005 | 07:19 PM
Ellas9's Avatar
TSX: Boeing Dreamliner!
I read it was hard to start in the quick reference booklet they gave me with the car. Its one of the first things.
Yea, I don't have a clue why the battery on all new Acura's/Honda's is so cheap - but it doesn't take many CCA's to start these engines anyways.
If its really slow to start I would suggest ensuring the oil is not "thicker" than 5/30 and ensure you have the right fuel.
Old Oct 29, 2005 | 09:40 AM
JTso's Avatar
If the engine turns over easily, then it's not the battery. The next thing to look is fuel or ignition, but don't rule out the immobilizer system.
Old Oct 29, 2005 | 10:52 AM
joerockt's Avatar
Just dial 1911
thx for the info.
We've been over this many times before. The Panasonic battery in our TSX SUCKS. Dosent take a charge, isnt strong enough, drains easily, etc...
Here are my "Assumptions"
https://acurazine.com/forums/showthr...ight=batteries
Old Oct 30, 2005 | 11:15 PM
Mokos23's Avatar
dang Honda/Acura should've gotten a Sony battery instead..........
Old Nov 3, 2005 | 10:26 PM
Brandon24pdx's Avatar
Por Favor?
Mine will sometimes take a few extra cranks to start than the "usual" startup sequence.
According to the Quickstart manual: NORMAL. (A function of the engine management system to reduce startup emissions.)
Old Nov 4, 2005 | 12:36 AM
FrankO's Avatar
FrankO
Sun Grounding Wire System to Improve Hard Starting
I installed a Sun Grounding Wire kit just because of this situation. I thought my 04 Auto was hard starting. I did not improve a thing. Acutually while I was doing the install I noticed how well grounded the TSX is. The grouding wires are in the right place and very heavy duty. The sun system was just redundant as far as I could see. And, it did not rid me of the hard starting, and I dont think it added one iota of HP.
Old Nov 4, 2005 | 01:33 PM
afax226's Avatar
I have to look it up my manual again. So far, I haven't found the section yet. I have driven many other brands of cars but this is my first Honda. Are other Honda models like this too?
Old Nov 4, 2005 | 01:55 PM
moda_way's Avatar
Guys, remember this motor is a stroker in comparison to almost all the other Hondas. It has to get over the pump/suck of these pistons. Same reason why getting it to move in 1st gear (on a 6MT of course) takes a bit more gas pedal. The K series is not like any other motor (per se).
Old Nov 4, 2005 | 05:35 PM
Por Favor?
Its there. Its in that little spiral-bound book with the plastic laminated pages with the tabs at the bottom. Its on like the first page or so under "things you should know."
I dont know if other Honda engines do this, the TSX is a fairly new model with a fairly new engine design. Mine is the first Honda/Acura product I have owned as well.
Old Nov 5, 2005 | 03:15 PM
ILoveMyHonda's Avatar
17781708
yes i"ve had a problem with this a few times too in my '04. But I agree with Joerockt, the panasonic batteries are crap .
Old Nov 5, 2005 | 03:18 PM
17781708
But it's really not a problem per say. It's in the manual as Brandon pointed out, Moda_way's explanation is right too, the K24 is a high compression motor
Old Nov 7, 2005 | 03:04 PM
afax226's Avatar
Found it. Thanks!
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Phambam12
Sep 6, 2015 06:57 PM
jordanboi
Sep 5, 2015 01:33 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
