did I blow a fuse?
Old Apr 27, 2008 | 10:00 AM
TaSeX's Avatar
did I blow a fuse?
I changed the center lights to the 9 led feston from superbrightlights.
today when hopped into the car the center console lights were dead.
I can't turn on the stereo or the air. the only buttons that respond on the whole center are the defrost buttons.
I can't control the sound systemfrom the buttons on the steering wheel either
help! the dealerships are closed today
Old Apr 27, 2008 | 11:10 AM
TaSeX's Avatar
btw
i did notice that my temperature control system works because at an angle i can tell that the numbers are chaning.
however, i cant turn the radio on at all. plus the security light that blinks normally doesnt do so anymore =(
Old Apr 27, 2008 | 12:44 PM
TaSeX's Avatar
zomg!
no acurazine love? =(
im freaking out
Old Apr 27, 2008 | 02:20 PM
PrecyseStylez's Avatar
Special-K
check the fuses.. try changing it out and see if that works...
Old Apr 27, 2008 | 07:39 PM
TaSeX's Avatar
fuses are fine.
any one else want to take a gander at this?
the stereo doesnt NOT work =( so i cant use the fix
Old Apr 27, 2008 | 08:46 PM
CGTSX07's Avatar
sounds like a fuse. did you check all of them?
Old Apr 27, 2008 | 08:58 PM
GTSX-05's Avatar
ASM 3G TL Type-S
Check specifically the 'small lights' fuse in the engine bay, reffer to the owners manaul for the fuse information and location.
Old Apr 27, 2008 | 09:00 PM
TaSeX's Avatar
its a bit dark now but i will do it tommorw.
but it would sitll be the samll light fuse if the whole stereo wont turn on?
Old Apr 27, 2008 | 09:02 PM
CGTSX07's Avatar
check all of them. i had a similar scenario and it was a fuse i would've never guessed...
Old Apr 27, 2008 | 10:39 PM
GTSX-05's Avatar
ASM 3G TL Type-S
Yup, my center console lights blew out one day randomly, I thought it was the pcb bord, but since my TSX is a 05 I new it wasn't likely, I checked the small lights fuse and what did you know it was blown.
Check fuses first, if the problem remains, contact local dealer.
Old Apr 28, 2008 | 05:35 PM
TaSeX's Avatar
thanx for the help guys =) still cant find that broken fuse >.<
Old Apr 28, 2008 | 05:45 PM
CGTSX07's Avatar
did you check the fuse box inside the car as well?
Old Apr 28, 2008 | 05:57 PM
TaSeX's Avatar
working on that now
its raining like crazy here ='(
i needz mymusics!
edit:; i ran not a post online that said that all the lights in the car are wired to one fuze so if my dome lights are out and its the fuse that is causing the problem the rest of the lights should also be out. Is that true?
Old Apr 28, 2008 | 06:37 PM
CGTSX07's Avatar
look for the "Meter" fuse. that took out my gauges, center console, and some lights. it is located in the in-cabin fusebox
Old Apr 28, 2008 | 06:40 PM
TaSeX's Avatar
will do
thank you so much fir your help!!
Acura604
20
Aug 5, 2017 12:55 AM
hashbrown
Sep 29, 2015 12:13 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
ripit
Sep 26, 2015 06:19 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
