Problems w/ the clock on the Navi.
Old Sep 11, 2003 | 04:04 PM
STC's Avatar
STC
I posted this on the "Audio and Electronics" forum, but this forum moves much faster. Pls help!!
I just got my TSX today!!
But when the sales guy was going over all the specs, I noticed the clock in the Navi is different from clock on the dash. The technicians cant figure out the problem.
I read the Navi might take a few hrs to "pinpoint" me. Since the clock is controled by GPS it might be that.
Any of you guys experience this?
Old Sep 11, 2003 | 08:28 PM
Bass Mechanic's Avatar
there is a clock in the navi? wierd i never noticed, but i know for a fact it adjusts to the timezone your in if you cross a time zone. it takes a little while to change but it will eventually
Old Sep 11, 2003 | 09:10 PM
idx's Avatar
idx
Senior Grasshopper
I remember reading somewhere that if the GPS needs to pinpoint where you are (and its really off), then you need to keep the car on in the same place for 10-45 minutes. (or something crazy like that)
Can you tell which one is the right time?
-r
Old Sep 11, 2003 | 09:55 PM
STC's Avatar
STC
-r
The Navi time is correct, the clock on top of the dash is 45 mins ahead.
Pls help!!!!!!! Thanks!
Old Sep 11, 2003 | 11:20 PM
Y2K4 TSX's Avatar
TSX, baby!
There is an option to set the clock (in the dash) via the GPS, keeping them not only sync'd, but very accurate, due to the precision of time of the GPS.
I don't have my manual handy, but look inside the Navigation System manual for "Auto Clock Set" or something like that. That should fix your problem!
Old Sep 11, 2003 | 11:43 PM
dnl2ba's Avatar
-r
I've had it be off by like 2 blocks before and it corrected itself after a minute while I drove.
Old Sep 11, 2003 | 11:46 PM
STC's Avatar
STC
I did that, didnt work at all.
The time has been 45 mins ahead the whole day now.
GPS and everything else works. I dont get it!!!!!!!!
Old Sep 12, 2003 | 12:33 AM
Y2K4 TSX's Avatar
TSX, baby!
STC, how old or new is your car and what's your build date/#? I know the nav systems had some updates (mine is 1.003) - maybe you need a software update from your dealer?
Old Sep 12, 2003 | 08:35 AM
STC's Avatar
STC
Okay mine is 1.00. I will ask the dealer today!
Old Sep 12, 2003 | 12:32 PM
idx's Avatar
idx
Senior Grasshopper
Yeah, have them check it out. I looked at mine today and in the clock/TZ config (page 2 on nav setup), when I manually adjusted the time on the nav it would automatically update the dash at the same time.
-r
Old Sep 12, 2003 | 02:55 PM
Stevestr's Avatar
Looking at the '15 TLX
It sounds like you need to resynch the GPS. For some reason (esp. the 45 min being off) it sounds GPS related.
The owner's manual describes how to do this. Well, specifically the Navi Guide.
Old Sep 12, 2003 | 04:35 PM
STC's Avatar
STC
I didnt know u could do that, thanks man! I appreciate the help, I'll look when I go home.
Actually the Acura tech diconnected the battery to reset everything, wouldnt that resync it?
Old Sep 12, 2003 | 05:48 PM
STC's Avatar
STC
Ok im looking at the Navi book now, I dont see where you can resync it. I went through the book 3x. Pls help!
Old Sep 12, 2003 | 09:24 PM
Stevestr's Avatar
Ok I checked and apparently the procedure is only in the Service Guide and not the Navi guide.
1. First check what is displayed in the GPS Offset Time screen:
a. Turn ignition switch ON (position II).
b. Hold down MENU and ZOOM OUT (since your battery was disconnected this is the recommended keypress). If that combination does not take you to a Diagnosis Item menu the press MENU, MAP/GUIDE, and CANCEL for 5 seconds.
c. Choose GPS Information
d. Choose GPS Offest Time
e. See if the time is somehow being offset here. DO NOT use any of the DATE HOUR or MINUTE or SET keys here. Check local time vs Disp. Time. Is one or the other off or are they the same?
Also note (per 22-318) that the GPS cannot detect the vehicle position for as long as 45 minutes after the battery is reconnected.
Make sure there are no items on the back shelf.
When the battery is disconnected the GPS internal clock will reset to 0:00. The clock will reset the correct time after the system finished GPS initialization (22-319). During initialization the vehicle has to be parked in an open area for the car to pick up GPS signals.
If after all this the time is still off then you probably have a defective navi unit or the time was changed in Setup Screen #2.
Old Sep 12, 2003 | 09:27 PM
Stevestr's Avatar
The fact that the dash clock is 45 ahead now seems to indicate somehow in Setup Screen 2 of the Navi that someone has misentered the time, overriding that of the GPS.
Otherwise I stick with defective Navi.
Old Sep 12, 2003 | 10:10 PM
Stevestr's Avatar
I created a page for you on my site with sample screen shots. It's here:
http://www.stevestr.org/TSX/NaviTime.html.
Hope it helps.
Old Sep 13, 2003 | 12:50 AM
STC's Avatar
STC
Hope it helps.
stevestr.........YOU ARE THE MAN!!!!!!!!!!!!!!!!
It works now and you helped me fix it. I owe u!!!!!!!!!!
I turned on the head unit time send and it set!
Thanks again man!!!!!
Old Jan 3, 2007 | 05:27 PM
JohnLine's Avatar
Stevestr~ Your divine knowledge helped fix the upper display clock problem I had (stress HAD) with my '05 TSX/navi. You're good! ~J
Old Jan 4, 2007 | 04:48 PM
tirebiter's Avatar
A man with a watch knows what time it is.
A man with two watches, isn't sure.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
2Quik
Sep 23, 2015 01:03 PM
