RL Section Ramblings
Old Mar 15, 2010 | 07:47 PM
  #41
Ken1997TL's Avatar
Originally Posted by silver3.5
for those with a '04 RL, does your center armrest open from the driver's side instead of just up? also, is the height adjustable? does anyone know if it'll fit an '02? my '02 only opens up and that sometimes bothers me because all my coins or whatever that is small would slide out the back.
Yep, '04's have the side opening center console lid.
I don't think its height adjustable, its been a couple years since I've driven one though.
I would assume it would fit
Old Mar 15, 2010 | 08:10 PM
  #42
OLD_HATCH's Avatar
what he said.
Old Mar 22, 2010 | 03:48 PM
  #43
vas25tl's Avatar
The Box
An 04 ran through the auction last week. Black with 98K miles. These cars have become so rare.
Old Mar 22, 2010 | 03:51 PM
  #44
OLD_HATCH's Avatar
what auction n how much it go for?
Old Mar 22, 2010 | 03:53 PM
  #45
vas25tl's Avatar
The Box
I check Manheim once in a while. Sold for $9200 + fees
Online for $11995 a couple days later.
Old Mar 22, 2010 | 04:53 PM
  #46
silver3.5's Avatar
where do you go to check these auctions?...manheim?
Old Mar 22, 2010 | 08:40 PM
  #47
vas25tl's Avatar
The Box
I used to have a buyer's license and still have access to stuff.
Old Mar 28, 2010 | 08:38 PM
  #48
vas25tl's Avatar
The Box
Went on a trip to Chicago again this weekend. 5 people in the car and full trunk of groceries on the way back. 200 mile trip, will fill up tmrw morning and see how the mpg were. I was pretty conservative the whole trip, kept it 75 and under.
Old Mar 28, 2010 | 08:53 PM
  #49
OLD_HATCH's Avatar
Im going to say 21, 22 tops.
Old Mar 28, 2010 | 10:00 PM
  #50
Ken1997TL's Avatar
I got 25 mpg going to California and back. Did 72 mph most of the time with several mountain passes.
Old Mar 29, 2010 | 10:54 AM
  #51
vas25tl's Avatar
The Box
The best I've seen so far was 21.xx
I didn't have time to fill up this morning so it may be skewed a little.
I gotta admit with all that weight in the car, the RL would look awesome dropped!
Old Mar 31, 2010 | 07:41 AM
  #52
vas25tl's Avatar
The Box
I just broke my record. Got 23.2mpg on this tank And that was driving the last 2 days in the city (although I take mostly freeway anyway).
:P
Old Apr 5, 2010 | 08:25 AM
  #53
vas25tl's Avatar
The Box
23.8 over the weekend.
Getting so close to the magic 24 #!
Old Apr 5, 2010 | 11:12 AM
  #54
OLD_HATCH's Avatar
fill them tires up to like 40-42psi
Old Apr 5, 2010 | 11:41 AM
  #55
silver3.5's Avatar
the best i've gotten was about 22.8mpg; that was a trip to the twin cities from milwaukee, 330 miles, average cruising speed was 75mph.
Old Apr 5, 2010 | 12:29 PM
  #56
vas25tl's Avatar
The Box
All these good mpg's are from trips to Chicago. Hopefully I can stop going every weekend now and get back to a normal routine in life...and save some miles on the RL.
Old Apr 6, 2010 | 08:59 AM
  #57
blexann's Avatar
02 RL with 180k km. VSA light always on and cannot get rid of it.
I've got a smelly exhaust. do other RL owners notice this ?
btw, great idea this ramblings thread.
Old Apr 6, 2010 | 06:34 PM
  #58
OLD_HATCH's Avatar
VSA is probably a bad sensor somewhere. Get the service manual from pdftown.com for the RL and it will tell you how to pull and read the code.
hows the maintanace on the car? Need of a tune up maybe?
Old Apr 6, 2010 | 09:16 PM
  #59
blexann's Avatar
dealer cannot read the codes due to a computer problem (they are not sure and of no help). tried an independent acura mechanic and he could not read the codes either.
Dealer told me the yawn sensor is one possible problem but the part here in Canada is $1200 and they dont gaurnatee the fix. I can live with it for now just thought I'd put it out there for ideas on fixes.
fluid changes are done frequently but have not had the plugs changed in long a while - I guess that could be the cause of the smell
Old Apr 6, 2010 | 09:21 PM
  #60
OLD_HATCH's Avatar
the yaw sensor? I think the only yaw sensor is in the Nav unit in the trunk and thats completely seperate of VSA.
A common problem in Legends is a faulty sensor on one of the wheels. The rear I believe. You could have those checked out. The service manual will also show you how to troubleshoot or check sensors I beleive.
Old Apr 7, 2010 | 12:26 AM
  #61
Ken1997TL's Avatar
Yep, vehicle speed sensor or something similar.
Old Apr 7, 2010 | 09:09 AM
  #62
blexann's Avatar
The proper name for that part is Yaw Rate Sensor but I will definately try the wheel sensors.
btw..is there a way to reset those VSA lights ?
Old Apr 14, 2010 | 03:33 PM
  #63
vas25tl's Avatar
The Box
I think the dealer has to reset the VSA light. Takes a lot more than a code reader/reset...
Try unhooking the battery
Old Apr 14, 2010 | 05:47 PM
  #64
blexann's Avatar
dealer is of no help - they want to charge me 1200 dollars and not gaurentee the fix(???). I tried disconecting the battery but it did not reset the lights.
Old Apr 14, 2010 | 08:17 PM
  #65
OLD_HATCH's Avatar
DTC Clearing
1. Press the parking brake pedal.
2. Push the VSA off switch, and hold it, then turn the ignition switch ON (II).
3. Hold the VSA off switch for 3 to 5 seconds, then release the VSA off switch.
4. After 3 seconds, the VSA activation indicator blinks 4 times. It means that the DTC is cleared.
5. If the VSA activation indicator stays on, replace the VSA modulator-control unit.
Old Apr 14, 2010 | 08:25 PM
  #66
OLD_HATCH's Avatar
look on pdftown (I think) for the RL service manual. See if you can do it yourself.
Theres a service check connector under the glovebox that you can use to pull the codes.
Oh and that yaw sensor the service manual says its in the trunk you need to remove the cover behind the back seat and the lid that covers the spare to get to it.
This is how to pull the code I beleive.
DTC Indication
NOTE: This operation can also be done with the Honda PGM Tester.
1. Connect the SCS service connector to the service check connector (2P) under the glove box.
2. Turn the ignition switch ON (II).
3. The ABS indicator comes on for about 2 seconds and goes off. Then it will indicate the DTC.
NOTE:
• If the DTC is not memorized, the ABS indicator will go off for 3.6 seconds, and then come back on.
• If the ABS indicator stays on, troubleshoot for ABS indicator does not go off (see page
19-213).
4. Turn the ignition switch OFF, and remove the SCS service connector.
NOTE: The Malfunction Indicator Lamp (MIL) will stay on after the engine is started if the SCS service connector is connected.
Conditions for DTC indication:
Vehicle speed is 6 mph (10 km/h) or less.
The SCS service connector is connected before the ignition switch is turned ON (II).
The brake pedal is released.
Look for that service manual it will help alot.
Old Apr 15, 2010 | 10:21 AM
  #67
vas25tl's Avatar
The Box
Hatch, how much time have you spent working on the RL? You've got all the info!
Old Apr 16, 2010 | 10:24 AM
  #68
OLD_HATCH's Avatar
Ive had it for a little over a year and half now.
I'm use to working on non standard Honda platforms. lol Have you ever seen a picture of my other No aftermarket support Honoda?
Old Apr 16, 2010 | 11:24 AM
  #69
vas25tl's Avatar
The Box
The hatchback? That thing is nice.
Old Apr 16, 2010 | 11:25 AM
  #70
vas25tl's Avatar
The Box
My pops has been driving my TL since I don't and I'm picking it up tomorrow morning to take some pictures of it rolling over to 250K It's at 249,921 now.
Old Apr 16, 2010 | 12:52 PM
  #71
OLD_HATCH's Avatar
yeah the hatchback.
alot of hunting for that one.
5 cylinder still in that year right?
Old Apr 16, 2010 | 02:56 PM
  #72
vas25tl's Avatar
The Box
Yup it's the 2.5 I5 with a 4 speed trans. Been in the family since 1999. Got it with 124K miles, ran from Milwaukee to Louisiana so it was all hwy miles, company car with all maintenance done.
I can imagine the hatch being difficult to mod...
When I had my first TL (beige), I was having a tough time finding any parts for it, it was all $$$ stuff from Japan and I couldn't swing that in high school working at a car wash so I just dropped it, put rims on it, tints, tv, stereo, grill, exhaust and called it a day. That was 8 years ago and there still isn't much aftermarket for them.
Old Apr 20, 2010 | 08:40 AM
  #73
vas25tl's Avatar
The Box
It's done
http://www.youtube.com/watch?v=FGZ8hWCd4NA
Old Apr 20, 2010 | 09:32 AM
  #74
OLD_HATCH's Avatar
cool
there's a guy with a 2nd gen Legend coupe that hit 400k not to long ago and his car is mint. Hope that's me one day.
on a side note I just noticed that there's a "Guided missiles and space vehicles" category in the nav. Now I can get my guided missles. Lol
Old Apr 20, 2010 | 10:11 AM
  #75
silver3.5's Avatar
it's no secret why hondas (and toyotas) are ranked so high in quality and durability (the older models, of course)....they just keep on going and going and going.
Old Apr 20, 2010 | 10:39 AM
  #76
damionphillips's Avatar
Question for the random question forum..
I can't seem to find performance mods other than a good ol K&N filter. Can anyone point me to a place where i can make this lumbering 3.5 breathe easier? Intake? AEM parts to use from another Honda/Acura? Thanks...
Old Apr 20, 2010 | 12:49 PM
  #77
vas25tl's Avatar
The Box
For sure.
And +1 on older models. I feel like they were built stronger and are more reliable.
Old Apr 20, 2010 | 01:01 PM
  #78
OLD_HATCH's Avatar
91-95 Legend parts are almost bolt on.
look for cai with VSA for a Lgend.
OBX haders will bolt up, but I believe they Y pipe might need some changes in the RL.
Alot of Legend parts are almost drop in on the RL
Old Apr 20, 2010 | 04:18 PM
  #79
ryk's Avatar
ryk
Old_hatch is a real life geyser of RL knowledge.
Awesome.
Old Apr 21, 2010 | 03:32 PM
  #80
silver3.5's Avatar
is there such a thing as leather replacement kits out there for our 3.5RL? all the popular leather sites do not carry anything.
