K23a1 Build
Old 07-31-2014, 02:51 PM
  #361
FLETCH
TheWrench116's Avatar
Originally Posted by crxtype-r
anybody having MAF problems p0103 sensor high voltage . have the adjustment maxed on the flashpro and wont rev past 6k rpm . any aftermarket higher voltage sensors or ideas . 247 awhp 299 awtq
are you running an after market intake? what kind of boost psi are you running? could you send my a data log file to look at?
Old 07-31-2014, 03:29 PM
  #362
KenB350z's Avatar
Weather's good, time to go for a test drive!
Old 07-31-2014, 03:53 PM
  #363
DRR98's Avatar
Will you lose air flow without a shroud to channel the air into the fins?
Old 07-31-2014, 05:05 PM
  #364
richard cranium
crxtype-r's Avatar
boost is at 15-16 psi no more than the reflash , and i am running a after market intake . my tuner said the maf housing is to small (i.d.) but its stock cut off the stock airbox. maybe after market intakes have different diameter. or the maf housing is designed different. stock diameter is 3 inches
mods include UR pulley, ets tmic, 3in dp, gutted stock cat 2nd, atlp catback ,cai, flash pro.
Old 07-31-2014, 06:04 PM
  #365
RZANYS2K's Avatar
What size injectors are u running?
Old 07-31-2014, 06:12 PM
  #366
KenB350z's Avatar
NOt sure, I will run with and without to see.
Old 07-31-2014, 07:28 PM
  #367
KenB350z's Avatar
Lets see if this does better!
DRR98 (08-01-2014)
Old 07-31-2014, 07:31 PM
  #368
KenB350z's Avatar
Poor Civic, doesn't get any love.....
Old 07-31-2014, 09:23 PM
  #369
WTF?
bluecarbonfiber's Avatar
no video??
Old 07-31-2014, 09:40 PM
  #370
KenB350z's Avatar
No vid, did not notice any change, the intercooler could have been warmer with the shroud on.
Old 08-01-2014, 06:15 AM
  #371
KenB350z's Avatar
I wish I could get my hands on this prototype intercooler shroud.
Old 08-01-2014, 06:49 AM
  #372
richard cranium
crxtype-r's Avatar
stock injectors . I think there 410cc. was thinking about getting the ct enginering 510cc.
Old 08-01-2014, 07:23 AM
  #373
KenB350z's Avatar
A lot of people are using DW or ID's, look into them.
Old 08-01-2014, 09:55 AM
  #374
WTF?
i wish i could get my hands on that too.. i would be make carbonfiber one =)
Old 08-01-2014, 03:02 PM
  #375
FLETCH
take the factory intercooler and the cover and make a mold to work off of. maybe???
Old 08-01-2014, 04:09 PM
  #376
Slow98teg's Avatar
Absolutely no point in barely upgrading. You'd max them out fast. 1000's and call it a day. You'll be set for a while.
Old 08-01-2014, 05:42 PM
  #377
KenB350z's Avatar
Nearly complete! Just need to schedule a TUNE!!!!
DRR98 (08-01-2014)
Old 08-01-2014, 06:56 PM
  #378
FLETCH
When did you get a red valve cover? Man I must be blind...
Old 08-01-2014, 08:34 PM
  #379
KenB350z's Avatar
Red valve cover?
Old 08-02-2014, 12:08 AM
  #380
KenB350z's Avatar
What size is your intake?
Old 08-02-2014, 01:16 PM
  #381
420Coupe's Avatar
You're maxing out the Flow on the MAF sensor options are have a bigger housing for the maf sensor or disable maf and tune using Speed Density. I find it hard your maxing out the MAF sensor with a 3" housing double check on housing make sure it doesn't reduce where the MAF sensor is located. Or if they placed the sensor right after or before a bend
Old 08-02-2014, 07:11 PM
  #382
KenB350z's Avatar
Yeah, there are some option on the flashpro for different size intake, like 3", 4", or custom. Let your tuner know about this, it is in the calibrations settings.
Old 08-02-2014, 10:45 PM
  #383
exist12's Avatar
There is no speed density for the rdx in flash pro
Old 08-03-2014, 10:58 AM
  #384
420Coupe's Avatar
if you have the Beta ver of FlashproManager its available now.
Old 08-03-2014, 01:21 PM
  #385
exist12's Avatar
Thanks I will check that out since last time I asked hondata they said it wasn't available.
Old 08-03-2014, 05:14 PM
  #386
not an SUV ...a Big Hatch
BigHatch's Avatar
sounds like the RDX glory days are just beginning.
Old 08-03-2014, 08:41 PM
  #387
KenB350z's Avatar
Sounds like it!
Old 08-04-2014, 08:54 AM
  #388
exist12's Avatar
I am on the beta version and still do not see the speed density option
Old 08-04-2014, 11:21 AM
  #389
FLETCH
not trying to step on toes. but this is kens build thread start your own and you wont have nearly so much information to sort through that does not pertain to your issue and vice versa.
The following 3 users liked this post by TheWrench116:
bluecarbonfiber (08-04-2014), KenB350z (08-04-2014), protoRDX (08-04-2014)
Old 08-04-2014, 07:34 PM
  #390
KenB350z's Avatar
Well just finished emailing Evergreen Turbo back and forward, and it's a pretty good chance I will be upgrading the stock TD04HL-15TK31-VFT 49389-01031 (RDX turbo), Charlie from Evergreen say that he has seen gains of 40hp with the upgrade. With those numbers I cannot pass that up.
Old 08-04-2014, 07:46 PM
  #391
randeez's Avatar
Do it.
Do it now.
Old 08-04-2014, 08:33 PM
  #392
FLETCH
were you able to get the tune uploaded?
Old 08-04-2014, 08:35 PM
  #393
FLETCH
how much $$$
Old 08-04-2014, 08:56 PM
  #394
KenB350z's Avatar
My mechanic suggested that I get it tuned first before I get the turbo upgrade. Just to see what the cams did. Evergreen didn't give me a price, but I'm sure it will be around the same as Dresx said before in the earlier post (page 1).
Old 08-04-2014, 10:33 PM
  #395
KenB350z's Avatar
TheWrench116, you are not blind. What you saw was a FD2 Civic Type-R valve cover. Only thing is does for me is that it looks good; however, it is going to make oil changes a lot more fun (monster garage on the weekend).
Old 08-04-2014, 10:36 PM
  #396
KenB350z's Avatar
Old 08-05-2014, 08:41 AM
  #397
KenB350z's Avatar
I got the OEM turbo ordered, it will be shipped to Evergreen Turbo within a few days. In the mean time I will be trying to schedule a tune.
Old 08-05-2014, 09:01 AM
  #398
FLETCH
sounds good! any chance at a copy of the tune when you get it done? I'd like to see what it looks like compared to mine.
Old 08-05-2014, 09:24 AM
  #399
KenB350z's Avatar
Yeah, we can compared the two.
Old 08-05-2014, 10:08 AM
  #400
WTF?
fricken tune time!!!
Quick Reply: K23a1 Build
