Slow off-the-line acceleration - ways to compensate?
I bought an 07 last week and it's definitely one of the funnest cars I've had. However I'm surprised/disappointed by the off-the-line performance -- it's so slow taking off from a stop. I've never owned a turbo before but I know about turbo lag generally. Is this slowness unavoidable in older turbos? The car has been meticulously serviced throughout it's life so I am pretty confident there's no mechanical issues (owner is mechanic, and Acura PPI found no problems).
Is slowness from a dead start the nature of the beast? Are there driving techniques to compensate that won't damage the powertrain? If there aren't, this might be more of a fling than a LTR.
Thanks.
Thanks.
The awd RDX at +4,000 lbs with a compression of 8.8:1 for the 2.3L I-4 at low rpms that hasn't had time to spool the turbo is probably only making low 100 hp or less off the line.
I did the Hondata reflash and that shorten the spool time for the turbo a little bit. I've noticed you have to ease into the throttle for faster get away compared to a lead foot/flooring it. You really can't put your foot into it until the turbo spools up.
It bogs down the turbo. You can hear it growling straining and sucking through the intake but the car barely goes. If you let the engine do more of the work off the line, then let the turbo loose from a rolling start it accelerates more efficiently, without all of that turbo lag.
Thanks.
Thanks.
