Forum help on Meguiars Wax - static
Old Oct 28, 2014 | 02:15 PM
colohusker's Avatar
I'm a little new to anal car care, never had a new nice car worth the effort, so sorry if this is a real amateur question but.. Got a new TLX and washed and waxed it for the winter. Used Meguiar's products and did two very thin wax coats over two day period. Looks great, but now a few days in and the car attracts anything light weight by what looks like static electricity. EVERYTHING now seems to "stick" to the car... leafs, grass blade, flower petals, tons of dust. Did I miss something in the process, or do something wrong in the wax process or is this something with mequiar's product?
as a follow up, if I need to redo it, what is a good product to strip the wax and begin again?
thanks
Old Oct 28, 2014 | 02:23 PM
understand what a wax/sealant does.
it protects from the sun, it aids in washing, and it gives the car paint an amazing shine.
as you found out, your car is now VERY slick and things will get attracted to it.
that's the name of the game!
except now, its very easy to wash off.
do a full wash every week which will help keep the dust off.
Old Oct 28, 2014 | 02:52 PM
maybe it could be your wax media.
microfiber cloths can hold static electricity
Old Oct 28, 2014 | 03:11 PM
robpp's Avatar
Graphite Ghost
static is what it is/
the towel is the most important part of detailing IMO.
draw the MF towel over your palm and open hand...if it grabs use it for wheels and under areas. buy GOOD towels for the paint.
i only use Adam's double soft on my paint.
also, wax burns off from heat and sun.
I would suggest you research a sealant to put on before you wax. a decent sealant will last 6 months or more where as the best wax in the world can burn off in 2 weeks on black car in fla.
the meguiars forums are great for techniques.
i am currently using the menzerna sealant. its not too expensive for a large bottle on amazon.
its a bit thick but can be applied by hand and removed by hand, it will make it feel like you just dipped the car in clear M&M. HELPS A TON with stuff sticking.
and then you can periodically wax ON TOP of the sealant as you like to add more protection and some extra depth.
GL
Old Oct 28, 2014 | 03:15 PM
this hobby of keeping your car clean is obsessive.
I always try new products and new techniques!
Old Oct 29, 2014 | 10:48 AM
Jesstzn's Avatar
The static is created from the wax on wax off movement itself. Wash the car and the majority of the issue will go away.
The sealant comment is right.. Will outlast carnauba based waxed by a long shot BUT you don't need to apply a wax over it. An excellent low $$ sealant is Meguiars #21 and it layers well. Another thats not as pretty but gives great protection is Duragloss #105 usually available at Car Quest.
Costco yellow MF towelas are also excellent for sealant removal, cut off the tags.
Old Oct 30, 2014 | 11:18 AM
C8N's Avatar
C8N
Congrats on the new TLX!
Without saying what has already been said.... let me guess. It a dark color car? Especially black, it just shows everything. That's why you do not own a black car... it owns you!
Old Nov 1, 2014 | 02:38 PM
colohusker's Avatar
Yeah, it's dark red. Not as bad as black, but shows quite a bit. Just seems to attract anything light weight like a magnet. I've held little things in my fingers about an inch from the car and let go and they just zip right onto the car.
Old Nov 4, 2014 | 12:44 AM
spf1410's Avatar
Your car is beautiful! I've had the same situation before, I used a detail spray and fresh microfiber to calm it down, seems to do the trick for me. Someone mentioned earlier in the thread, to make sure your microfiber towels are not charged before using them.
4drviper
Apr 23, 2025 07:13 PM
MrHeeltoe
20
Feb 23, 2023 01:54 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
