AcuraZine Dallas/Ft.Worth Crew
Old 06-08-2013, 03:10 PM
  #8721
All Around Klown
EvilJoker's Avatar
sorry I bailed on the monthly... I was a little hungover...
Old 06-08-2013, 09:32 PM
  #8722
NAiL05's Avatar
Just a lil bit
HondaProdigyX3.2 (06-16-2013)
Old 06-09-2013, 03:47 AM
  #8723
Phat_Type S's Avatar
Anyone gonna go to Honda fetish meet on June 23 2013?
Old 06-09-2013, 12:24 PM
  #8724
Dallas Chapter Leader (Midwest Region)
NBP_BALLER's Avatar
Cool
Sounds fun, might have to look into it! You going?
Old 06-09-2013, 12:54 PM
  #8725
NAiL05's Avatar
I will most likely be there. Usually has a good turnout.
Old 06-09-2013, 01:46 PM
  #8726
Thumbs up
Yes sirrrr,what time anyone going?
Old 06-09-2013, 04:46 PM
  #8727
NBP_BALLER's Avatar
I have no idea. R u gonna go to show your car or check em out?
Old 06-09-2013, 05:54 PM
  #8728
Thumbs up
I'm gonna show my Type S
Old 06-11-2013, 07:28 AM
  #8729
Honda+Blue=My garage
pmptx's Avatar
Comp[tech Rear Sway Bar-2nd Gen-FREE
2nd Gen TLS should fit all 2nd gens.
FREE, yes FREE. Includes Bushings-4 bolts, 2 end links and it is on.
Just come by and pick it up (Keller,TX)
PM me if interested
Anyone???????
Old 06-11-2013, 08:44 AM
  #8730
NBP_BALLER's Avatar
Yeah ill bring my TL out, looks like alot of ACURA's are gonna be there. People are driving from other states for the meet, gonna be sick!
Old 06-11-2013, 08:48 AM
  #8731
slobalt defender
Hockeyman's Avatar
PM me if interested
Anyone???????
Is this the one you picked up from me years and years ago? Wish I had a use for it!
Old 06-11-2013, 07:58 PM
  #8732
Everyday I'm rofling
opboarding's Avatar
Received 1,788 Likes on 1,103 Posts
I like free things
Old 06-12-2013, 09:27 AM
  #8733
pmptx's Avatar
It is. I still have the Koni/HRs on though.
Old 06-17-2013, 03:27 AM
  #8734
Anyone else gonna show the TL ?
Old 06-17-2013, 03:51 AM
  #8735
TEXAS PSYCO
stellalegend's Avatar
I would love to show my 94 legend coupe but there's no category for us
Old 06-17-2013, 10:18 AM
  #8736
Big Guns 101st
NastyTL's Avatar
Phat_Type S where is the honda meet?
Old 06-17-2013, 10:41 AM
  #8737
NBP_BALLER's Avatar
Honda Fetish meet, june 23rd in grand prarie, tx.
http://honda-fetish.com/hondafetishsummershow/
NastyTL (06-17-2013)
Old 06-17-2013, 11:02 AM
  #8738
Giant Blue Car
Catfisha's Avatar
And that's just WRONG!!! If you did show up, everyone would drool over your car anyways!
Old 06-17-2013, 01:12 PM
  #8739
NBP_BALLER's Avatar
Note to self: keep drool in mouth
Old 06-17-2013, 02:12 PM
  #8740
Your mom is in
thevikas87's Avatar
Hey guys, I thought I might try the chat thread for a more immediate response:
I have a 2006 Acura TL Automatic with the same symptoms as described in the below thread. While I think it may be the same issue (pressure switches) I don't want to speculate.
Thread: https://acurazine.com/forums/3g-tl-2004-2008-93/acura-transmission-problems-808475/
Can anyone recommend a good transmission shop in the DFW area that won't charge an arm and a leg? If the transmission needs to be replaced that is fine, just want to get it diagnosed properly and go from there. I know the dealer charges somewhere in the range of 4-5k for transmission replacement. I thought I'd give it a shot to find another indy shop here.
Old 06-17-2013, 02:40 PM
  #8741
NAiL05's Avatar
Well check with acura first...they had an extended drivetrain warranty on auto trans for the older v6 cars. I would check before spending the money on them...Hell you might get a free trans out of it.
Old 06-17-2013, 02:51 PM
  #8742
NBP_BALLER's Avatar
Thread: https://acurazine.com/forums/showthread.php?t=808475
I would go ahead and replace your pressure switches first and do a flush and see if you can get her going for a while. Im a mechanic and can do them if you need help. Also I have a guy I work with that used to work for acura. Im sure he could get you a good rate on replacing if needed and i would order one online for cheaper. I wouldnt take it somewhere unless they put an oem one back in. Transmissions are not something you mess with aftermarket crap unless your building it up with performance parts. Tranny shops are CRAP! Ive had many many customers have us re-build their trannies or put a new one in because a crap shop screwed it up. Do it right the first time. Just do your switched and a drain/refill. What exactly is it doing? That thread is all rambling
Old 06-17-2013, 03:27 PM
  #8743
NAiL05's Avatar
Thats what I was looking at too. Couldn't really see an issue that was posted. But acuraoemparts.com is where I would go to order the switches online.
Old 06-17-2013, 03:48 PM
  #8744
Regions Leader
trancemission's Avatar
airbag light came on today.....went back out but I see this being a problem
Old 06-17-2013, 05:15 PM
  #8745
Your mom is in
thevikas87's Avatar
Thanks for the quick response. So basically, when we start the car, it goes into Drive, Neutral, Reverse, etc fine. It will drive fine for about 10 minutes until it gets warmed up then it starts mis-shifting. For example, you will start off from a red light and the gear will not engage, the RPMs just go up. Eventually it might catch, but usually it won't. So then you have to turn off the car, turn it back on and it will usually let you get into 1st and 2nd gears.
It reminds me of the time the transmission in my 2nd gen CL went out. Except no CEL or anything like that. Plus the issue goes away when the car is freshly started.
Where is your shop located btw? I'd like to try having you replace the switches and doing a drain/refill.
Old 06-17-2013, 06:25 PM
  #8746
NBP_BALLER's Avatar
Ooh, if your slipping when your engaging into first that's a bad sign of a toast trans. I work at Sewell Cadillac off lemmon/university on the back side of love field. Switches may help, its worth a shot. If you end up doing a full tranny you can take them off and sell them. When cold the fluid is thicker. Once it gets hit its more susceptible to slipping.
Old 06-17-2013, 06:29 PM
  #8747
NBP_BALLER's Avatar
That's no bueno. You probably have a connector making a bad connection or getting pulled by the seat moving up/down and side/side. If it comes on again get a DTC pulled if you can and I can look up possible common problems.
trancemission (06-19-2013)
Old 06-18-2013, 02:28 AM
  #8748
213swampy's Avatar
im also showing my tl it would be nice if all the tl can park next together
Old 06-18-2013, 08:13 AM
  #8749
NBP_BALLER's Avatar
I think all the TL's and different car categories will be parked together for the judging. Are you boosted?
Old 06-18-2013, 08:26 AM
  #8750
Received 16,266 Likes on 11,974 Posts
MBP_baller, is that how you get RH?
by servicing other's?
Old 06-18-2013, 08:28 AM
  #8751
NBP_BALLER's Avatar
Nevermind, I couldnt remember if that was you that did ther JnR Turbo setup but it was. I gotta see this thing! Im thinking about building a custom turbo setup for ALOT cheaper than the JnR with better turbo, wastegate, intercooler and all, there will be alot of fabricating but for the price of 7k with a flashpro. YIKES! I can build a nice setup for less than 2k with better parts! http://98.158.194.157/forums/showthread.php?t=849924
Old 06-18-2013, 08:29 AM
  #8752
NBP_BALLER's Avatar
Old 06-18-2013, 08:31 AM
  #8753
I'm not hating.
matter of fact; I need some servicing.
Old 06-18-2013, 08:35 AM
  #8754
NBP_BALLER's Avatar
I'm not hating.
Old 06-18-2013, 06:36 PM
  #8755
213swampy's Avatar
yes im boosted
Old 06-18-2013, 07:08 PM
  #8756
NAiL05's Avatar
the gaydar is shooting out rainbows
Catfisha (06-19-2013)
Old 06-18-2013, 07:38 PM
  #8757
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
Old 06-18-2013, 09:27 PM
  #8758
NAiL05's Avatar
SO for this honda fetish deal...should we meet up before and roll in? That would guarantee us all parking together...I will need to get a spare plate since I do not want people taking pictures of that. Do they make acurazine license plates?
Old 06-18-2013, 10:15 PM
  #8759
NBP_BALLER's Avatar
Well they are judging in different categories so I figure they will have us park together. We can meet up tho if u want. Im not really going to expect anything as far as competition. None of our cars are THAT nice like some ive seen that are going. As for plates... I can maybe make some
Old 06-19-2013, 11:01 AM
  #8760
pmptx's Avatar
Blake, the Sway bar has a new home with Jess.
The following 2 users liked this post by pmptx:
Catfisha (06-19-2013), Hockeyman (06-19-2013)
Quick Reply: AcuraZine Dallas/Ft.Worth Crew
