Random Technical Talk
Old Nov 17, 2015 | 01:15 AM
  #681
Mizouse's Avatar
What's a good way to make my PC shut up aside from putting it to sleep or taking a sledge hammer to it?
It's a core 2 duo E6600.
Any recommendations on a heat sink? I'm thinking of maybe going with a fanless heat tube type.
Also thinking of getting a cheapo fanless or super quiet gpu as well.
Kind of irritating turning on my loud ass PC just so i can access all my prawn stored on it.
Guess I've been spoiled by how quiet my 2012 Mac mini is...
Old Nov 17, 2015 | 08:10 AM
  #682
Whiskers's Avatar
Go Giants
get a new one.
Old Nov 17, 2015 | 08:14 AM
  #683
water cooling
Old Nov 17, 2015 | 03:51 PM
  #684
#1 STUNNA's Avatar
Sanest Florida Man
Old Nov 17, 2015 | 05:12 PM
  #685
doopstr's Avatar
That was pretty much my life at my last job. I fixed that about 2 months ago.
Old Dec 3, 2015 | 12:21 PM
  #686
stogie1020's Avatar
Needs more Lemon Pledge
Anyone have a USB3 hub they like?
Must be:
-AC Powered
-4 Port or greater
Currently have a DLink 4port (D-Link DUB-1340 4-port SuperSpeed USB 3.0 Hub - Newegg.com) and it pisses me off on a daily basis. All the ports seem to be upside down from EVERYTHING else and then half the ports dont work on M,W,F, and the other half dont work on T, TH, F... Occasionally the swap days. If I get two working ports at a time I am lucky.
Old Dec 9, 2015 | 11:50 AM
  #687
#1 STUNNA's Avatar
Sanest Florida Man
Apparently this months KB3114409 for Outlook 2010 is shit too! It's supposed allow admins to prevent Outlook from opening in safe mode but instead it sucks which causes Outlook to....................... open in safe mode.
Got clients complaining about this one today, just uninstall it from installed updates list in programs and features to fix it.
Old Dec 9, 2015 | 12:22 PM
  #688
stogie1020's Avatar
weird, it was installed on my W10 machine but not offered to my W7pro machine (both have Outlook 2010 but I delay the updates on the W7 machine)
Old Dec 9, 2015 | 12:37 PM
  #689
Whiskers's Avatar
Go Giants
Awesome - got a call about it today. Thanks!
Old Dec 9, 2015 | 12:40 PM
  #690
Majofo's Avatar
Apparently Microsoft hired a bunch of ninny interns this summer to do shit they have no interest in doing
Old Dec 9, 2015 | 12:58 PM
  #691
nfnsquared's Avatar
Outlook 2010?? Dinosaurs, that's so 2010!!!
No effect on OL 2013
Old Dec 9, 2015 | 03:06 PM
  #692
Whiskers's Avatar
Go Giants
got me paid.
Old Dec 9, 2015 | 03:17 PM
  #693
stogie1020's Avatar
yup, 2010. I enjoy actually being able to see the items in the ribbon as separate and distinct instead of the awful mono color, 1 dimensional look 2016 has... I upgraded OneNote and then immediately downgraded. I couldn't tell where one thing ended and the next began.
Old Dec 10, 2015 | 10:19 AM
  #694
#1 STUNNA's Avatar
Sanest Florida Man
OK Stogie, I need a little help.
One of our clients is in finance and they've been using Symantec Encryption Desktop to encrypt their drives. The recently had to update all their PCs in the office to Windows 10 because the head office wanted to put everyone on the same OS. Symantec was a little behind on supporting 10 and when the new November build came out that broke support for Symantec Encryption. So any PC with their disk encrypted that way will fail doing the upgrade until a compatible version is released and they go and install it. It's a hassle.
So I talked them into replacing it with BitLocker, on the PCs that I was upgrading last week and it seems like they want to replace Symantec with BitLocker on their other PCs in the future. However there's one question. Symantec has a Secure Delete feature that they like to use and BitLocker doesn't. My boss and I don't really see the need for secure delete if the drive is already encrypted. You can't pull the drive and recover data without the recovery key. The only scenario we could see was if a ne'erdogood was sitting at the logged in PC they could maybe recover the deleted file but then they'd already have access to everything else and all the undeleted files as well so you're already fucked.
So is it a big concern that there's no secure delete feature if we remove Symantec and replace it with BitLocker?
Old Dec 10, 2015 | 10:25 AM
  #695
nfnsquared's Avatar
...So is it a big concern that there's no secure delete feature if we remove Symantec and replace it with BitLocker?
No. There's a big misconception in this area. Show this to your clients:
Why You Can?t ?Securely Delete? a File, and What to Do Instead
Old Dec 10, 2015 | 11:18 AM
  #696
stogie1020's Avatar
NFN is on the right track, TRIM and Wear Leveling prevent the absolutely correct usage of file wiping tools. The actual process is an overwrite of the specific bytes in a file. While this can be accomplished at the logical (file system) level (meaning anyone using file system tools to look at files), at the hardware level the SSD may still contain parts of the file in various memory storgae locations due to (a)temp caching on the SSD for performance, (b)TRIM movement of data resulting in the moved-final location being wiped but not he prior locations, and the inherent hardware interface delay between an overwrite command and its actual complete execution on the memory locations on the SSD.
For practical purposes, you should ask your client what their goal is in using secure file deletion. If it is to prevent a forensic recovery by a bad actor of the deleted data, they should look into a file shredder application like Eraser, etc. that LOGICALLY shreds the file. If they simply don't want people with access (with decrypt password) to the machine to be able to recover recycle bin entries, use SHIFT-DELETE or file shredding apps. If they are concerned about bad actors who DON'T have legitimate access to the file system (no decrypt-password) then the WDE solution is acceptable because even a file siting in the recycler/trash is encrypted at rest.
Old Dec 11, 2015 | 04:32 PM
  #697
stogie1020's Avatar
I am cleaning out some old storage and I just came across a CD marked "Windows 98 SE Install Disk" and there is a serial code!
Old Dec 11, 2015 | 05:16 PM
  #698
nfnsquared's Avatar
Load that sucker up. Hurry, quick, before the authorities show up for that other activity of yours....
Old Dec 11, 2015 | 07:24 PM
  #699
Majofo's Avatar
Does it have the y2k patch? Let me know if you find ME.
Old Dec 15, 2015 | 10:20 PM
  #700
doopstr's Avatar
Firefox is finally 64-bit on your Windows PC
Old Dec 17, 2015 | 11:00 AM
  #701
#1 STUNNA's Avatar
Sanest Florida Man
That Outlook update is a complete fuck up. I'm still getting calls over that and I just removed it from someone who didn't even know it was fucking them up. I saw she had 2010 so I decided to check and sure enough it's running in safe mode. I'll probably be getting calls for months because of it.
Old Dec 17, 2015 | 06:42 PM
  #702
stogie1020's Avatar
What would you do with an old 10" netbook running Linux Mint on an Intel atom processor with a 250GB HD?
Not sure what to make out of this, found it cleaning out my closet.
Old Dec 17, 2015 | 06:50 PM
  #703
nfnsquared's Avatar
Load Win98 SE on it
Old Dec 17, 2015 | 06:53 PM
  #704
Whiskers's Avatar
Go Giants
Put 10 on it.
Old Dec 17, 2015 | 07:01 PM
  #705
stogie1020's Avatar
It never had better than XP on it, Is there a way to get 10 free for it?
Anything I could do with it as a media center PC, etc?
Old Dec 17, 2015 | 07:22 PM
  #706
nfnsquared's Avatar
Does it have HDMI out? I doubt it.
How about NICs? Wireless only? What speed?
Best and cheapest use would probably be to just load XP back on there and make it a "guest" internet access tool so your "guests" aren't DLing porn on your computer.
Old Dec 17, 2015 | 07:39 PM
  #707
Whiskers's Avatar
Go Giants
No free upgrade to 10.
Old Dec 17, 2015 | 08:11 PM
  #708
doopstr's Avatar
Put the latest build of mint on it and donate it.
Old Dec 18, 2015 | 10:11 AM
  #709
stogie1020's Avatar
no hdmi, has vga and 10/100/1000 nic
will probably do that...
Old Dec 18, 2015 | 10:42 AM
  #710
#1 STUNNA's Avatar
Sanest Florida Man
If you have any spare 7 keys lying around you might be able to activate the latest build of 10 using a 7 key. It supports that now...
Old Dec 18, 2015 | 12:02 PM
  #711
stogie1020's Avatar
I don;t think I have a spare 7 key, but even if I did, to what end? What would I do with it?
I guess I am looking for creative uses for a light processor and storage.
Old Dec 20, 2015 | 02:10 PM
  #712
#1 STUNNA's Avatar
Sanest Florida Man
Old Dec 21, 2015 | 09:43 PM
  #713
#1 STUNNA's Avatar
Sanest Florida Man
Check out uBlock Origin for your ad-blocker needs. I've switched to it from AdBlock/AdBlock Plus. It's much more efficient than any other ad blocker I've used. I think it helped fixed my horrible battery life while using Chrome on OS X, it's on Chrome/FF. It allows you to choose which 3rd party lists you want to use to block shit, though the more lists you choose the more RAM it uses. But it seems like it has access to all the popular list like Fanboy, EasyList, MVPSHost, etc., and even does malware blocking.
There's also uBlock which is different than uBlock Origin. Still uBlock seems better than AdBlock/ABP though
In April 2015, Hill transferred administration of the "uBlock" software repository to Chris Aljoudi[13] who created the site ublock.org. However, in May 2015, Hill announced that he would no longer contribute to the version maintained by Aljoudi, but would continue to develop and maintain only "uBlock Origin", where he retains full control.
https://en.wikipedia.org/wiki/UBlock
uBlock Origin added support to block pop unders with the latest release.
Chrome:
https://chrome.google.com/webstore/d...jbkeiagm?hl=en
Firefox: LOL Find it yourself
Old Jan 8, 2016 | 11:41 AM
  #714
stogie1020's Avatar
OK, gents... need someone to try something simple for me.
For the most part I have switched to using Chrome from FF for various reasons.
One thing I notice, though, is when I am posting to AZine via Chrome, I am unable to use the CTRL-B and CTRL-U to bold or underline text in the post entry box. In FF these work ok. Is there some way to enable this function in Chrome?
Is this just happening for me or is it universal?
Is it because aliens?
Currently in Chrome, CTRL-B does nothing and CTRL-U opens the "view source" tool.
Old Jan 10, 2016 | 02:10 AM
  #715
Mizouse's Avatar
oooo so tuesday is end of life of internet explorer 8,9&10.
i hope this means the work computer will finally upgrade from IE9
my work computers are such pieces of shit anyways.
Old Jan 19, 2016 | 03:37 PM
  #716
Mizouse's Avatar
Interesting according to SpashData the #15 worst password for 2015 was 1qaz2wsx
Honestly never would've guessed that. It looks semi-complex
#1 password is 123456
Space balls combo is #5
Old Jan 19, 2016 | 03:40 PM
  #717
Mizouse's Avatar
Would've expected Love Secret God or Sex to show up in there.
Old Jan 19, 2016 | 04:55 PM
  #718
nfnsquared's Avatar
Honestly never would've guessed that. It looks semi-complex....
Dude, look at it on the keyboard....
Old Jan 19, 2016 | 04:59 PM
  #719
Mizouse's Avatar
Yes i know where it came from
Old Jan 19, 2016 | 05:04 PM
  #720
It's okay Miz, I didn't know either
