Apple: iPhone News and Discussion Thread
Old 11-23-2011, 06:43 AM
  #7921
Go Giants
Whiskers's Avatar
Received 1,236 Likes on 825 Posts
4G is faster internet
Old 11-23-2011, 09:29 AM
  #7922
Sanest Florida Man
#1 STUNNA's Avatar
Received 10,840 Likes on 6,588 Posts
Yes but currently it has limited coverage and a lot of 'mericans aren't covered and LTE comes with really bad battery life right now. I think battery life is more important than "ZOMG 4Geeeeeee"
My IT boss has an Epic 4g and that thing is always low on battery, it doesn't usually last through the business day without going on a charger.
Old 11-23-2011, 09:33 AM
  #7923
CocheseUGA's Avatar
Battery life is a touch overrated if you have access to charge it.
People complaining about not getting through a day when they sit at a computer. Um, hello? If you don't have access, then it's another story.
Old 11-23-2011, 09:37 AM
  #7924
CGFebTSX04's Avatar
Or just get an extra battery. Batteries are $10 on eBay and swapping between each is so easy if you're a crazy power user. If need be, they have the extended batteries that double or triple battery life. Really, you have options for such things. Obviously this option is for Android phones.
Old 11-23-2011, 09:53 AM
  #7925
Sanest Florida Man
#1 STUNNA's Avatar
I'd rather not have to worry about it. We don't sit in front of one computer, we travel all over the area going from client to client. He def plugs it in when he can and it usually gets him through the day, barely. IMO it's not worth all the hassle so that when I do a web search it's a little bit faster on my phone. Like you said we sit in front of computers all day, if given the choice we're going to use the PC to do web searches instead of a phone.
4G mifi's sure sign me up but not 4g on my phone until they get better battery life which is supposed to be coming, Qualcomm's got some chip that combines modem on the SoC.
Old 11-23-2011, 09:54 AM
  #7926
Mizouse's Avatar
Received 2,811 Likes on 1,991 Posts
They've got extended batteries for iPhone, in the form of a case
Or battery based chargers
Old 11-23-2011, 09:56 AM
  #7927
CocheseUGA's Avatar
Give me the better performance (in both areas) over battery life.
USB is so ubiquitous now that it takes about ten seconds to find a place to charge. With the customization one can do to reduce battery use, I'd rather have that option on the user end than be restricted by the hardware.
Old 11-23-2011, 09:58 AM
  #7928
Mizouse's Avatar
Old 11-23-2011, 09:59 AM
  #7929
CGFebTSX04's Avatar
Yes they do but they're usually ugly and way overpriced. Give me a regular cheap battery any day that doesn't ruin the aesthetics of the phone. Also, changing a battery literally takes 2 minutes tops. If you have problems changing a battery for 2 minutes, then you've got bigger issues.
Also one more thing, you can turn off 4G if you don't want to use it. Not sure if people are aware of this. Just because you have 4G doesn't mean you have to use it. You can even go down all the way to 2G if you want to save even more battery. You can always go back to 4G when you want it.
Old 11-23-2011, 10:08 AM
  #7930
Sanest Florida Man
#1 STUNNA's Avatar
^All of that = hassle that I don't want to deal with.
Old 11-23-2011, 10:10 AM
  #7931
Sanest Florida Man
#1 STUNNA's Avatar
I don't want to micromanage my phone or buy extra batteries or carry around my charger just to get through the day
If I need to micromanage it every once in a while when put through heavy use, fine, but every fuckin day? No, thank you....
Old 11-23-2011, 10:16 AM
  #7932
CocheseUGA's Avatar
Two finger presses is too much of a hassle?
Old 11-23-2011, 10:18 AM
  #7933
CGFebTSX04's Avatar
Really? That's micro managing? You can put a widget on the home screen and with one button press turn on/off 4G. How much micromanaging is involved in that? Or if you really want, they have apps that can automate all of this based on your location with Tasker and many other apps. If that's micromanaging then I don't know what using a smartphone is?
Old 11-23-2011, 10:51 AM
  #7934
nnInn
jupitersolo's Avatar
Received 1,084 Likes on 646 Posts
People need to stop effing whining. They demand a phone do more and more as much as a laptop use to. With that comes fast use of batteries. Buy extra , buy a mophie or two. Either find/invent a better battery and go back to a StarTac and use it as a phone.
Deal with the limitations are invent something better.
Old 11-23-2011, 10:57 AM
  #7935
Go Giants
Whiskers's Avatar
When my laptop gets better battery life then my phone there is an issue.
Old 11-23-2011, 11:12 AM
  #7936
CGFebTSX04's Avatar
Not sure if trolling...
Considering they're pretty different in many ways. With the much smaller size of phones today, you can't cram the same size battery found in other electronics which is really the limiting factor at the moment for phones. A phone also has to deal with radio waves for calls which are the most draining in a phone on top of everything else it has to do in the background. Cell towers are also inconsistent and depending on your location can have different strain on your phone's battery life. If you want to do a fair comparison of a laptop and a phone, put the phone in airplane mode and use WiFi only. That cell phone can best that laptop almost all the time with usage. A better comparison would be the tablets vs. laptops but even then, most tablets bests laptops with regular usage and with the new Tegra 3s leap beyond them.
Old 11-23-2011, 11:17 AM
  #7937
nnInn
Yes there is an issue with that, from what I've read it an app problem, not hardware. If I can find the article, I'll post it, but this is the jist of what was said by an owner of two 4s's.
He has two phones, one for work (which is used only for testing apps he and his company make) and one for self. Was having problem with his phone, so he wiped clean both phones and switch them over. The battery problem follow the switch over.
Also the battery in the laptop is bigger.
Old 11-23-2011, 11:19 AM
  #7938
Sanest Florida Man
#1 STUNNA's Avatar
I shouldn't have to manage it at all to get through a normal day, it should just work....
Old 11-23-2011, 11:24 AM
  #7939
CGFebTSX04's Avatar
I don't know how many brain cells I lose every time someone says that.
Old 11-23-2011, 01:11 PM
  #7940
CocheseUGA's Avatar
And I don't have to manage anything on my phone in a regular day. Just plop it on the charger at bedtime and it has only once absolutely needed a charge during the day.
I can go two if I forget.
Old 11-23-2011, 01:17 PM
  #7941
Mizouse's Avatar
Old 11-23-2011, 07:42 PM
  #7942
Costco's Avatar
Received 3,489 Likes on 2,089 Posts
All I know is my friend's Thunderbolt was lightning fast when I tried it out, pun not intended.
Apple will probably roll out 4G, LTE or HSPA+ depending on the network within half a year or year and most likely tout it as the next big thing and so on and so forth. I'll be surprised if they dont within a year.
Call it just a marketing term if you want but Apple does the same thing. Every manufacturer out there does this. Synthetic motor oil vs conventional, premium unleaded vs regular unleaded, organic, ceramic, semi-metallic brake pads, etc
Old 11-23-2011, 08:10 PM
  #7943
Mizouse's Avatar
The iPhone 4S on AT&T is HSPA+ already...
Old 11-23-2011, 08:30 PM
  #7944
Go Giants
Whiskers's Avatar
AT&T's 4g is not even close to being ready.
Old 11-23-2011, 09:07 PM
  #7945
CGFebTSX04's Avatar
The iPhone 4S is still using last year's 14.4 Mbps version of HSPA+ while all the other phones are currently using 21 Mbps (AT&T Android phones) and 48 Mbps (T-Mobile Android phones) HSPA+. On XDA people have been reporting to hit anywhere from 6-10 Mbps with their Galaxy S II's (the regular one without LTE) so the radio difference is pretty significant.
AT&T's current infrastructure for HSPA+ can only go up to 21 Mbps right now which is probably why Apple decided to stick to 14.4 for the moment and to unveil it in their next iPhone most likely. This is also why AT&T wanted T-Mobile's "4G" 48 Mbps to cover them until their LTE was ready. Bad planning on the part of AT&T. The T-Mobile deal was their scramble plan which is looking less likely to happen each passing day. Of course all of these are theoretical speeds and most likely won't be seen with the current tech and spread out of their towers.
Old 11-25-2011, 10:48 AM
  #7946
Mr. Maker's Avatar
Received 3,628 Likes on 1,768 Posts
My friend found an iphone. All apps, contacts and history have been deleted. Its a Verizon iphone and my carrier is Verizon. If I buy it from him can I just put my service onto the phone?
Old 11-25-2011, 12:27 PM
  #7947
CGFebTSX04's Avatar
Probably not. That ESN is most likely blacklisted. You can use it for everything but a phone as you won't be able to activate it with Verizon's network.
Mr. Maker (11-25-2011)
Old 11-25-2011, 01:02 PM
  #7948
nnInn
That's why they are so desperate to get T-Mobile. But FCC and JOD, doesn't look like that will happen...
Old 11-25-2011, 01:14 PM
  #7949
CLtotheTL32's Avatar
Received 9,528 Likes on 6,183 Posts
I may be getting my AT&T 4S replaced tomorrow.
Since I've had it earlier this month, when I place a call, it doesn't ring yet I become connected to the person I'm calling. They can hear me but I can't hear them. I thought maybe upgrading to 5.0.1 would solve the problem but it hasn't. I've restored the phone twice as well.
Old 11-25-2011, 02:02 PM
  #7950
My Garage
GIBSON6594's Avatar
AT&T LTE has already launched in several cities.
Old 11-25-2011, 02:19 PM
  #7951
Sanest Florida Man
#1 STUNNA's Avatar
^ so then you agree with him....
Old 11-25-2011, 04:17 PM
  #7952
Mizouse's Avatar
Old 11-25-2011, 06:18 PM
  #7953
nnInn
sev·er·al/ˈsev(ə)rəl/
Adjective:
More than two but not many: "the author of several books"; "Van Gogh was just one of several artists who gathered at Auvers".
Separate or respective: "their several responsibilities".
Old 11-25-2011, 09:40 PM
  #7954
I'm Craig
cjTL's Avatar
Might just be the network in my area but whenever I place a call, it takes a long time for it to start ringing. And then when I get a call and answer, I always have to say "hello" two or three times until the other person can hear me. Kinda annoying.
Old 11-25-2011, 09:54 PM
  #7955
It doesn't take me long to connect when placing a call. Since I don't hear anything after placing the call, I look at the screen, and it will say connected but I can't hear shit. The person on the other end can hear me but I can't hear them.
I've only had the phone for 3 weeks. If they can replace it for free why not? It's not a guaranteed fix but I'm sick of having to call people two or three times just to have a conversation.
Old 11-25-2011, 11:12 PM
  #7956
CGFebTSX04's Avatar
Do you have a spare (previous) phone to place your sim card back to and test? Might be a network problem. I don't see why they wouldn't replace it though if you can show them that you don't have the problem with another phone.
Old 11-26-2011, 02:39 PM
  #7957
My Garage
GIBSON6594's Avatar
I don't follow...he said it's not even close to being ready and I said it's already launched.
How is something already launched not even close to being ready?
Old 11-26-2011, 02:52 PM
  #7958
nnInn
Everything I've read so far has said that it isn't 4G, even though they are selling it as 4G.
Old 11-26-2011, 03:30 PM
  #7959
My Garage
GIBSON6594's Avatar
http://androidandme.com/2011/11/news...-65-mbps-down/
Disclaimer is that AT&T isn't crowded yet, but it is still nothing to laugh at.
Old 11-26-2011, 04:05 PM
  #7960
Mizouse's Avatar
HSPA+ that AT&T has is 4G, they also have 4G LTE out in like 6 markets.
Quick Reply: Apple: iPhone News and Discussion Thread
