ROTORA Big Brake Kits: CL, TL, TSX
Former Sponsor
This is an Acurazine Special Pricing Event for the ROTORA Big Brake Kit only. The pricing event will consist of the ROTORA Big Brake Kit (BBK) for the Acura CL, TL, and the Acura TSX.
Here is some important information on ROTORA’s BBK’s:
ROTORA’s calipers are made of billet aluminum alloy and CNC machined to ensure the highest quality. Rotora's high performance brake system enables superior brake modulation while improving overall pedal feel to ensure equal distribution of weight transfer when braking. To achieve this proportional front-to-rear brake bias, Rotora’s opposing piston calipers are fine tuned by increasing the clamp load to the optimal level while utilizing the stock master cylinder to retain overall front-to-rear brake bias. Rotora’s full big brake system design delivers excellent initial bite, exceptional modulation, and consistent pedal feel for street and track use applications. All systems are ABS compatible and direct bolt on replacement with minimal modifications required.
COMPONENTS/FEATURES:
-Rotora billet aluminum alloy 2, 4, 6, 8, or 12-piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle. (4 piston calipers for Acura (F), 2 or 4 piston for Acura (R) )
-Rotora billet aluminum hat with “floating” disc assembly to reduce heat related stress and unsprung weight.
-Rotora one piece vented, or two piece heat treated directional vane disc system to improve airflow/cooling under severe braking. Slotted or drilled & slotted oversize discs up to 16” (330mm (13”) and 355mm (14”) for Acura’s) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
-Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
-Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
-Rotora carbon steel (SC45) mounting brackets (depending on application) and hardware.
OPTIONAL:
Standard Caliper Color: red or metallic blue.
Custom Caliper Color: dark blue, chrome, gunmetal, gold, silver, black, or yellow (lead time of 60 days depending on application).
ROTORA’s Front 4 Piston 2 pc 330MM Disc BBK Setup
ROTORA’s Rear 2 Piston 2 pc 330MM Disc BBK Setup
Shipping times will depend upon your location. Prices based on shipping to 48 continental states in the U.S.
The following payment terms are accepted: Bank or Teller Check, Money Order, sent to:
Excelerate LLC
998 West Main St
Branford, CT 06405
You may also send payment to Excelerate@sbcglobal.net via Paypal.
Applications are taken straight from www.rotora.com. The prices will run as follows:
Acura TL 99-03, CL 01-03
- ROTORA 1 Piece Front 330MM Disc w/ 4 Piston Caliper BBK - $1325 shipped
- ROTORA 2 Piece Front 330MM Disc w/ 4 Piston Caliper BBK - $1750 shipped
- ROTORA 2 Piece Rear 330MM Disc w/ 2 Piston Caliper BBK - $1495 shipped
- ROTORA 2 Piece Rear 330MM Disc w/ 4 Piston Caliper BBK - $1750 shipped
Acura TL Base A/T 04-08
Acura TL Base M/T 04-08, TL-S 07-08 (ALL)
- ROTORA 2 Piece Front 355MM Disc w/ 4 Piston Caliper BBK - $2000 shipped
Acura TSX 04-08
NOTE: Larger wheels may be necessary to accomodate space for larger caliper and rotor. Email me for info on how to check caliper clearance.
AIM Screen Name: Excelerate04
E-mail: Excelerate@sbcglobal.net
or PM me.
RETURN POLICY
- ALL RETURNED AND/OR CANCELLED ORDERS ARE SUBJECT TO A 25% RE-STOCKING FEE PLUS ALL SHIPPING CHARGES (Includes original and return S&H fees).
- ALL AUTHORIZED RETURN MERCHANDISE MUST BE NEW, UNUSED, AND IN ITS ORIGINAL PACKAGING. ALL DOCUMENTATION, WARRANTY CARDS, INSTRUCTIONS, AND HARDWARE MUST ALSO BE RETURNED.
- ITEMS MAY BE RETURNED WITHIN 15 CALENDAR DAYS FROM THE RECEIPT OF MERCHANDISE.
- SPECIAL ORDERS ARE NOT RETURNABLE.
- ALL DEPOSITS ARE NON-REFUNDABLE.
EXCELERATE LLC
998 West Main St
Branford, CT 06405
(P) 203-483-6100 (F) 203-483-6101
www.ExceleratePerformance.com
Joshua Lockwood
Owner
OPTIONAL:
Excelerate LLC
998 West Main St
Branford, CT 06405
Acura TSX 04-08
or PM me.
RETURN POLICY
EXCELERATE LLC
998 West Main St
Branford, CT 06405
Joshua Lockwood
Owner
Former Sponsor
Originally Posted by duece_RENAMED
will the front and rear kit fit TL-S oem wheels without spacers?
hey excelerate. you replied on my brake upgrade and mentioned i needed a 5mm spacer. do you carry that? how much? do i need longer stud?is the 2 pc significantly better than the 1 pc? and if i upgrade to 18" rims do i still need the spacers? if i were to go thru with this i have a 2003 cl-s 6mt. thanks for all the help.
Former Sponsor
- Aluminum hat w/ iron disc
- Cool more effectively due to less restrictive air flow
- Less prone to distortion/warping due to hat being separate from disc
- Hat can be reused so less cost on replacing rotors
Former Sponsor
Originally Posted by JDMj20acL
I am actually in need for brake pads for my rotors bbk.. do u sell those?
Former Sponsor
Originally Posted by againstallodds1
Excellerate, I sent you a message about the BBK I ordered. Is it in stock, out in the mail?
Originally Posted by Excelerate
Well the kit I have here is for the 99-03 TL, but the only difference for the 04+ is the brake lines. I had ordered a set but I was sent the wrong set so ROTORA is overnighting me the lines. They told me Friday I should see them and therefore you should have your BBK by early next week. Thanks.
Former Sponsor
Originally Posted by Sebo1
looking for blue caliper BBK for front/rear on TSX.. does anyone yet make the full set??
Former Sponsor
Excellerate, I was just wondering if you recieved the stainless brake lines from Rotora?
Hey excelerate....
Do the BBKs fit a 3G TL (2004) with stock 17's, or will I have to use a spacer? I ask because I run RonJons in warm weather (which are shaped to allow for a BBK), but plan to use my stockers during the winter.
Thanks!
Thanks!
Hey excellerate, my girl put my BBK on yesterday, and I love it. Thanx man, nice mod, the only thing I just want to let everyone know, to avoid wasted time and phone calls is that my left rotor was in the right box and the right rotor was in the left box. Thats it. Everything was smooth, except the screws that hold the rotor in place. They are a bitch to get out. Be careful they can strip really easy.
Thanks Josh.
Thanks Josh.
Former Sponsor
Thanks Josh.
Thanks Josh.
Former Sponsor
can you get two piece rotors at all for the front.
1 Pc 13" Rotors w/ 4 piston caliper
2 Pc 13" Rotors w/ 4 piston caliper
2 Pc 14" Rotors w/ 4 piston caliper
PM me for prices with year and model and zip code. I have some coming in stock in about 2 weeks.
Former Sponsor
Originally Posted by invincible569
Good price! Does that include the 14" Rotors? What colors do they offer?
Former Sponsor
Originally Posted by LeeDan00
i just want to make sure. $2000 is for the front BBK only right?
excellerate i have been looking for pics of the blue kit installed on a car and i cant seem to come up with any. do you have any instock for the CL right now? i think the blue would look better and less flashy than red would on my SSM CL. let me know!
thanks.
thanks.
Former Sponsor
thanks.
thanks.
https://acurazine.com/forums/showthread.php?t=143249
It is on a 04+ TL but you can see the caliper color.
Former Sponsor
Originally Posted by special-ed
are red and blue the only options? Is there zinc plating on these also? Thanks!
Former Sponsor
Originally Posted by pits200
Any chances these have come down in price to lets say,, ummmmm $1,100.
Ha, I wish our car had some competition in the market. My buddy and I just put upgraded his car to 14 inch slotted rotors and 4 piston calipers on his 99GT mustang.
Total cost = $520 for the whole front setup.
I will toss another grand into the money I want to spend on brakes and go buy myself a Sony SXRD for the football season.
