ROTORA Big Brake Kits: CL, TL, TSX
Old 09-06-2006, 12:20 PM
  #41
Former Sponsor
Excelerate's Avatar
Originally Posted by pits200
Ha, I wish our car had some competition in the market. My buddy and I just put upgraded his car to 14 inch slotted rotors and 4 piston calipers on his 99GT mustang.
Total cost = $520 for the whole front setup.
I will toss another grand into the money I want to spend on brakes and go buy myself a Sony SXRD for the football season.
There is competition: Brembo, ROTORA, Ksport, Stoptech. ROTORA is still the best bang for the buck. Try looking for a used BBK if you want to save more $.
Old 09-06-2006, 02:39 PM
  #42
De La Rocha's Avatar
wheel size question
I currenly haev 18" enkei PK6's on my whip...will the rotora bbk kits fit with this wheel?
Old 09-06-2006, 02:51 PM
  #43
Former Sponsor
Excelerate's Avatar
More than likely yes. I can't say for sure. I could send you a file that allows you to confirm. You have to cut out a diagram similar to the caliper and take off your wheel and see if it would hit the diagram. Worse case scenario you buy a 5-10MM spacer.
Old 09-06-2006, 10:24 PM
  #44
TOPHER33884's Avatar
what is the normal offset needed on a wheel to clear the 13" rotors and 4-piston caliper? Thanks in advance, and Josh......Thanks for the fast shipping of the Rotora Rotors I ordered, YOU ARE A GREAT VENDOR!
Old 09-07-2006, 09:36 AM
  #45
Former Sponsor
Excelerate's Avatar
Well it depends on the vehicle and the BBK. The 1 pc BBK is the 330X23MM whereas the 2 pc BBK is 330X30MM. To give you a reference, though, at least for the 1 pc BBK, the 99-03 TL and 01-03 CL require a 5MM spacer on the OEM wheels. I think you really only need 3 MM but they don't usually make spacers that small. The 04+ TL does not require a spacer for the 1 pc BBK with the OEM wheels.
Old 09-12-2006, 05:31 PM
  #46
Racer X
webhead's Avatar
I have a Rotora BBK on 2002 CL-S and I need new pads. . .do you have any recommendations. . .do I need to replace with Rotora race pads or are there others that are as good or better
Old 09-12-2006, 10:58 PM
  #47
Former Sponsor
Excelerate's Avatar
It needs to be a ROTORA pad specifically designed for the ROTORA BBK. PM me your year, model, zip code, and what you want and I will get you a price.
Old 09-23-2006, 11:23 PM
  #48
ny'r residing in maine
getright's Avatar
The 1250 price is still valid right? If so pm me with payment info for a front bbk for a 01 cl. Can you quote the 1 and 2 pc. Thankx bro.
Old 10-06-2006, 01:51 PM
  #49
Retired!!! ON TOP!!!
rodneyc77's Avatar
Joshua,
When said that the BBK 1pc fits the 04+TL OEM wheels... did you mean the 17" or the 18"????
Old 10-08-2006, 01:57 PM
  #50
Former Sponsor
Excelerate's Avatar
Originally Posted by rodneyc77
Joshua,
I haven't personally installed on the OEM wheels but I read on the forums that a customer had the 1 pc BBK installed on his car and he was using the stock 17's.
Old 10-08-2006, 04:13 PM
  #51
Phrosttz0's Avatar
ive read up on the BBK kits, i have 99TL, i run type s rims in the winter, and 19x8 49offset rims in the summer, i know ill need a spacer for the type s rims, will they fit behind the 19s?
Old 10-08-2006, 07:44 PM
  #52
Former Sponsor
Excelerate's Avatar
More than likely yes. I can send you an excel file which you will have to print and cut out to verify if you would like.
Old 10-14-2006, 11:19 PM
  #53
Type S Zero's Avatar
is there a large difference in brake force distribution between :
13" front BBK / 13" rear BBK
and
14" front BBK / 13" rear BBK
i'm projecting to buy fronts first, but i'm afraid to be disappointed about the balance if i get 13" front first, and after a while, putting rear 13" : that i should've taken 14" for fronts.
any input/review on this ?
thanks !
Old 10-16-2006, 01:34 PM
  #54
Former Sponsor
Excelerate's Avatar
and
thanks !
To be honest I think the 14" kit is a little overkill unless you're doing a lot of track time. The 13" kit will be more than enough to stop the car. The kits are balanced and the 13" rear BBK will work perfect with the front 13" BBK.
Old 10-16-2006, 07:31 PM
  #55
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
can you buy cross-drilled (non-slotted) rotors only with the other stuff?
Old 10-16-2006, 08:22 PM
  #56
Former Sponsor
Excelerate's Avatar
For OE size rotors or Big Brake Kit rotors the options are slotted only or cross-drilled and slotted. There is no cross-drilled only.
Old 10-18-2006, 07:59 PM
  #57
Lajit-CL's Avatar
What about a 97, is there a kit. Why do we always get neglected? S/H 96789
Old 10-19-2006, 12:45 PM
  #58
Former Sponsor
Excelerate's Avatar
Sorry no BBK but I do have slotted rotors available.
Old 10-26-2006, 10:09 AM
  #59
royco's Avatar
Do you have crossdrilled rotors (rotors only, F&R) for an 06MT Brembo setup? Can't seem to find them anywhere at all.
Old 10-26-2006, 12:35 PM
  #60
Former Sponsor
Excelerate's Avatar
Sorry. Not yet, but ROTORA is working on it.
Old 10-26-2006, 02:27 PM
  #61
rodneyc77's Avatar
Joshua,
Please send me the file for the fitment test.... 06 tl one piece 13" BBK.... 06 TL.... rodney_68@msn.com
Thanks you
Old 10-26-2006, 04:57 PM
  #62
Former Sponsor
Excelerate's Avatar
Joshua,
Thanks you
I'm going to send it now. Also note that another member had the BBK installed with his stock 17's and they cleared fine.
Old 01-30-2007, 11:27 PM
  #63
I have car ADD
BLACKURA_NY's Avatar
Josh i think i am ready to get Rotora BBK's. Could you please send me the Excel file you were talking about so i can research..
I have 2006 TL (if you rememeber, u did my coils/rsb 2 months ago). In the summer i run 19 x 8.5" + 42MM. They are the same EXACT specs as the ron jon inspyres. Think it will clear?
i noticed you said that 14" is much
is 13" front * rear more then (overkill wise) the just 14" upfront.
I have to be real honest, the stock 5AT brakes are HORRIBLE. i need a resolution. especially if i become s/c
Thanks josh
Allon
Old 02-02-2007, 12:55 AM
  #64
Former Sponsor
Excelerate's Avatar
Thanks josh
Allon
Allon shoot me an email: Excelerate@sbcglobal.net
Request the info you need so I can send you a chart/file on the BBK's. I would think the kits would clear fine. I know RJ designs his wheels based on the ROTORA BBK fitment.
Old 03-14-2007, 12:47 PM
  #65
rodneyc77's Avatar
Just a Note: ROTOTA FITMENT FILE
Once you print the pdf fitment file from Rotora PLEASE verify that the dimensions were to SCALE... when I initially printed it, the dimensions were off by 9%... so I changed my printing options and set the file to print at 109% and everything worked out... remember that the dimensions are in milimeters (mm) and there's 25.4 mm to an inch = 25.4mm=1in
Old 03-26-2007, 10:48 PM
  #66
kataklyzm's Avatar
can you post pics of the blue caliper?
Old 04-01-2007, 01:15 AM
  #67
Former Sponsor
Excelerate's Avatar
See this link. It is pics from an Acurazine member (MichaelBenz) with a 3rd gen TL w/ front and rear ROTORA BBK's.
https://acurazine.com/forums/ramblings-12/those-who-know-watches-138689/
Old 04-02-2007, 10:43 PM
  #68
shayan's Avatar
pm'd you
Old 04-03-2007, 12:39 PM
  #69
rodneyc77's Avatar
FYI... they do fit...
Old 04-04-2007, 08:01 PM
  #70
Former Sponsor
Excelerate's Avatar
Looks great Rodney. Yes they do fit fine over the 3rd gen TL wheels.
Old 04-19-2007, 08:05 PM
  #71
swoodle's Avatar
Hey Josh. How about the Rotora BBK Front 1 piece (slotted only)? Are they in stock? What is the shipped cost to 31904? Thanks again
Old 04-20-2007, 01:55 PM
  #72
Former Sponsor
Excelerate's Avatar
Same price as the drilled/slotted setup. I can order the slotted setup on my next stocking order. It will take a few weeks to get it.
Old 04-20-2007, 06:33 PM
  #73
swoodle's Avatar
Thanks Josh. Let me know when you get them.
Old 04-20-2007, 09:16 PM
  #74
Former Sponsor
Excelerate's Avatar
Well I won't order that kit unless you send payment for it or at least a deposit. It is not a kit I typically stock so you would have to order it for me to order it.
Old 04-25-2007, 08:46 PM
  #75
swoodle's Avatar
PM sent thanks
Old 04-27-2007, 12:26 PM
  #76
Former Sponsor
Excelerate's Avatar
My ROTORA shipment is arriving on Tuesday. I will begin shipping pre paid orders on Tuesday and should be done by Wednesday. Thanks for your patience.
Old 05-05-2007, 02:18 AM
  #77
shayan's Avatar
Im really interested in buying these, but I have a couple of questions
1. What is the difference between 1pc and a 2pc set?
2. What is the advantage of getting just slotted rotors instead of slotted/drilled rotors? and getting drilled rotors instead of slotted/drilled rotors?
Old 05-05-2007, 03:51 PM
  #78
Former Sponsor
Excelerate's Avatar
1. The difference between the 1 pc and 2pc BBK is that the rotor. The 1pc rotor is one piece of an iron composition. The 2 pc rotor is an aluminum hub with iron disc.
The 2-piece rotor does have its advantages:
- Aluminum hat w/ iron disc
- Cool more effectively due to less restrictive air flow
- Less prone to distortion/warping due to hat being separate from disc
- Hat can be reused so less cost on replacing rotors
2. If you have the slots you don't need the drills. The majority of BBK buyers do drilled and slotted b/c it looks nicer.
Old 05-07-2007, 09:13 AM
  #79
THE_FIRM_ENT's Avatar
hey excelerate, if i was to purchase the kit can your store do the install as well and if so how much all together with a 1 piece front kit for a 05 TL?
Old 05-07-2007, 10:20 PM
  #80
Former Sponsor
Excelerate's Avatar
Yes we can do the install. Call me for further info and pricing. 203-483-6100
Quick Reply: ROTORA Big Brake Kits: CL, TL, TSX
