Innovative Mounts Groupbuy: 2nd Gen Acura CL/TL
#442
Originally Posted by rp_guy
i guess it's like the NRG engine dampers.. front gives a little bit of increase, not much vibration, front and back gives a lot.
#443
Originally Posted by TCM 01 CL-S
I wonder if the humming has something to do with the plugging up of the vaccum lines.
#444
Uses turn signals in my
Originally Posted by Silvaccordex01
That would cause more of a hiss like air escaping. Just cap the vacuum line for that thats what i did. Go to an auto parts store and get a little pack of vacuum caps there cheap
#445
Yeah, they are already capped, but I was pondering a possible explanation for the humming/change in sound.
#446
Originally Posted by distortedolskool
you do not have to jack up the motor for the removal but it will help take the pressure off the main through bolt when you slip it out. The jack may be required to push the engine back up slightly on the re installation of the bolt but the engine didn't seem to drop much when i removed it.
I laid across the motor and reached down behind the motor. the bottom plate 4 bolts have to be unbolted from the top.
I didn't use any swivel attachments even though i have all that fun stuff. i did unbolt the small black fuse box and drop it down out of the way to make more arm room. basically it is really tight and you only get a few ratchet clicks plus you have a bad angle for apply lots of leverage. i bought an air ratchet now to i'm sure it would of been a whole lot easier.
it took me around 4 hours to get the entire assembly out. keep in mind it weighs 9 pounds and the other tricky part was figuring out how to spin it and pull it out the left side.
#447
Did you pull it out through the top or the bottom?
#448
My car vibrates as it is now. The AC makes it do this. I have it on all the time. I turn the AC off & the vibrations go away. So I don't know what the new mounts will do to that. Lesson it or increase it?
My whole car shakes it's that bad.
As of now I know my side mount is torn. I guess the front or rear mounts could be bad as well. They look ok but that doesn't mean much.
I have tracked my car several times & do hard launches a lot. Plus it was used so who knows how it was treated before me.
#449
Lead Footed
Originally Posted by TitaniumCLS6MT
yikes - anyone know what size bolts/qty required for more secure mount?
And I agree that it new bolts should be included . . .
Ruf
#450
Lead Footed
I have that same humming too. I took a look and it doesn't seem like anything is touching anything it shouldn't. As for the vibrations on my end, nothing too bad.
I think it sounds pretty badass. Let me know what happens with this incase it is an issue of some sort.
As for virbrations go, it's a lot less than the vibrations I get from the Comptech springs. It's mostly noticeable when the car is in drive, but note that I still need to install the rear mount.
Ruf
#451
A few comments:
1. The mounts do take a little while to break in so if you have some vibrations they may subside.
2. The front and rear mounts are different (obvious for the M/T guys) on the A/T. They look similar but they are not the same. The front mount is taller IIRC; compare it to your OEM mount and make sure you put the front mount in the right location and likewise for the rear. If you didn't this could cause unnecessary vibration.
3. Hardware is needed for the side mount I can see. What exactly is needed? Longer bolts? Does anyone have hte specs? Quantity? Just for the side mount? Anyone who wants to can call Innovative directly and they will send them free hardware for the side mount, but we need to know what you guys need.
4. Mike, Innovative said to stop by their shop and they will check out your mounts to make sure everything looks ok.
5. All the rest of the orders are shipping today so it's just the last 3 M/T orders: Bonlie, Fuzzy, and Rehmat.
#452
Originally Posted by RUF87
Humm . . I've not noticed any humming . . . without looking at a car that was doing it, I could only guess . . I'll noodle on it and see if something comes to mind.
Ruf
Ruf
#453
#454
Lead Footed
[QUOTE=Excelerate]A few comments:
QUOTE]
Hey Josh, here are my
on items 1-3.
1) I thought and commented the same some posts back. I do believe these mounts will soften up . . . so I think I need a few runs to help it out.
2) Whoops, I must have had a senior moment, I had it in my mind that the taller mount went in the rear.
Well, I'll fix that this weekend when I do the rear. The swap should be easy since the Innovative mount offers better clearence.
Also, don't forget that the steel nipple (pin) is used to align the front and rear mounts.
3) I don't have the technical specs on the bolts, I just know it's a metric thread and the new bolts are 1/4" longer. I'll take some measurements this weekend and get your or Innovative the specs.
Ruf
QUOTE]
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Ruf
#455
![Rant](https://acurazine.com/forums/images/smilies/rant.gif)
![Pissed](https://acurazine.com/forums/images/smilies/pissed.gif)
are you absolutely sure about that Josh?
Originally Posted by Excelerate
A few comments:
#456
#459
wut.
I installed mine today at a shop. A lot of cabin vibration but I'm not complaining. I'm actually happy. It 'feels' better. HUGE improvements on everything. Shifts feel amazing and the whole car just performs better. Thanks Josh!
#460
#461
OG 3.x^7 rawr
Is it just me or is something different on the 6MT. The front and rear mount dont look the same. I have one where the pic goes into and the other, guessing its the rear, is solid with no pin and is not 2 piece.
#462
'03 ABP YA4-S 6MT
#463
![](http://i110.photobucket.com/albums/n83/distortedolskool3/rearmotormount.jpg)
#465
I just got the last drop shipment tracking #'s last night. This is the last 3 orders, at least from the initial order. If anyone needs a set let me know as I will be keeping these in stock.
FEDEX Tracking #'s
Fuzzy 632885961009162
Rehmat 632885961009155
Bonlie 632885961009179
And CleanCL's mounts were free b/c of the delay and he provided us the side mount.![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
CleanCL 632885961009124
If you want hardware you must contact Innovative. I still need to know the size of the bolts needed and specs on it so that they can provide it.
FEDEX Tracking #'s
#467
does this mean everyone is going to have to call in, or will they be sending out new bolts on goodwill? i haven't received mine yet so obviously i haven't done the install, but if all these guys are saying that there isn't much thread holding the side in.. i would assume the problem applies to everyone
#468
Originally Posted by CleanCL
thanks for all the hard work josh, i'll get back to you on that info, i'm looking into some other stuff.
#471
hold off on that recommendation. just got the car back and there's a loud humming when i accelerate and vibrations in the cabin.
going back tomorrow to see if they can fix it.
The side mount in my opinion needs to be redone. The cause of the humming sound your hearing is from the side mount. I put my stock side mount back in and the sound is completly gone. I noticed the sound after i put the side mount in and just thought it was something that was always there. Also, i put on my P2R plenums today and noticed that the front right (passenger side) was rubbing the liner very lightly. The reason is because the side mount lifts the engine about a guarter to half inch. Basically, when you put the side mount on, to get the bolt to line up and go through, you have to lift the engine up to line it up. The height is correct on the mount, but notice the bolt hole is significantly smaller than the bolt hole on the OEM mount. Because of this you have to raise the engine to line up the bolt for it to go through. This coupled with the fact that the rear bolt hole doesnt line up correctly and the mount causing a humming sound on acceleration i think the mount needs to be remade. My factory side mount is back in, and there is no more humming, and as far as i can tell the Plenum no longer touches the hood liner. Also, i think the Innovative side mount needs a little bracket built on the side so yuo can pop the clip on there that holds the AC line in place. That is as least to me a pretty important thing to include.
So Josh, could you please inform Innovative of these problems and see what they can do to remedy it? I think people should be able to ship there old side mount back in, and get the remade one in return. But see what you can do.
#473
in reply to the above issue with the side mount lifting the motor... are you sure it's the mounts fault. isn't it possible your side mount was torn and sagging? notice people, you SHOULD NOT be able to swap these mounts without support to the motor. these are MOTOR MOUNTS, they hold a 300+lb motor. of course if your mount is torn, there is more room to pull the mount out without moving the motor, but then you will need to lift the motor up into the proper place.
#477
can people start posting their experiences? i'll create a new thead in the cl section. please keep comments to a minimum so we can concentrate on the issue at hand. it should look something like this. please add info i may omitted.
1. mike - 3 mounts installed. STRONG vibrations through out the cabin while stopped. strong vibrations at low rpms. large increase in engine note at all rpms.
https://acurazine.com/forums/showthr...88#post2736888
#478
the 3 new bolts for the side are 10mm 1.25p and 30mm long.
i have the rear installed and then did the side. my side mount went in fine and i didn't have to raise the motor any with the new rear and oem front mount installed.
