03 TL multiple engine issues
Hey guys I have an 03 Acura TL type s and It had a blown timing belt tensioner when I got it, i replaced the hydraulic cylinder and a couple weeks later, it blew again, could there be something wrong with the wheel? Also when I am stopped in gear the rpm fluctuates slightly between 4 and 500 rpm with a bit of a vibration.
Latent car nut
Received 2,005 Likes
Sounds like you may have more issues than the tensioner; I'm guessing you have some bent valves in your cylinder heads.
I wouldn’t doubt that, the end of the crankshaft is stripped completely so the balancer wobbles too, I’ve been debating on figuring out the issue or just finding a new motor
Walk away from the original 3.2 and put in a 2002 3.5 from an MDX. It's plug n play, almost.
Also consider using the cams, if the valves are bent, from the 3.2 and put them on the 3.5 for a Type-S.
Latent car nut
If you are seriously considering the 3.5, look at the discussion on the thread below (post#9) for the parts, from the 3.2, that you need to transfer over to the J35A3 to plug and play with your 03 TL-S automatic:
https://acurazine.com/forums/second-.../j32a2-976998/
People usually find their J35A3's by searching car-part.com in their local area.
GoodLuck!
You need the J35A3 engine from a 2001-2002 Acura MDX.
GoodLuck!
GoodLuck!
thanks guys I’m going to run this motor for now until it decides to quit but I’m going to look into another 32a2 or the 35 for the summer
cajunsteve
03-01-2014 07:43 AM
italiancip14
24
01-06-2012 04:47 PM
dsc888
12-14-2005 12:00 AM
