J32a2
Old Feb 7, 2019 | 12:05 AM
1deep4lyfe's Avatar
6th Gear
J32a2
I have a 2001 Acura Cl Type S J32A2
Currently running 2002 Cl Type S ECU an 5 speed automatic transmission with CompTech Headers an exhaust Also AEM Intake.
im lookin for advice,recommendations,ideas ect on performance upgrades such as what intake manifold an throttle body is best for my J32A2
Is the AEM Series 2 something that is Compatible an beneficial to J32a2 with Automatic transmission
Ect ........
Thank you all in advance...
Old Feb 7, 2019 | 07:12 AM
Karanx7's Avatar
Unregistered Member
The basic bolt on mods are usually intake, headers, exhaust and pulleys. Since you already have headers and an intake, I would recommend an exhaust or lightweight stock sized pulleys. You can do a J37 intake manifold swap and/or a Blox throttle body for some extra hp as well. And no, you can't use the EMS 2 with an auto transmission.
Old Feb 7, 2019 | 08:03 AM
horseshoez's Avatar
Latent car nut
Ect ........
Why not just drop in a plentiful and cheap J35 (J35A3?) into your car?
Old Feb 7, 2019 | 08:05 AM
then will have more torque stock and will have the ability to tune with hondata
Old Feb 7, 2019 | 11:02 AM
1deep4lyfe's Avatar
6th Gear
so if i do go with J35 swap what all will i need to change out on my car beside of course the motor like will i have to get new ecu, harness ect?
Old Feb 7, 2019 | 11:03 AM
1deep4lyfe's Avatar
6th Gear
also will i need to go with new trans as well. The 5 speed auto trans is farly new just put in 4months ago
Old Feb 7, 2019 | 11:06 AM
Man.. auto trans? I'd just save up and not do engine mods because that AT will inevitably die again.
Get a 6 speed MT if you want to start doing Engine mods
Old Feb 7, 2019 | 11:16 AM
horseshoez's Avatar
Latent car nut
I believe a J35A3 is a drop in replacement for a J32A2; no wiring harnesses or ECU required. Note; I haven't down such a swap, but if you run some searches here I think that's what you'll discover.
Old Feb 7, 2019 | 02:45 PM
Hondadata supports the automatic 02 Cl Type S ECU now??
Since you have an automatic transmission, I believe the only thing you would have to use off your J32A2 would be the water passage (#8) and the connecting pipe (#11) on the link below:
https://www.oemacuraparts.com/v-2001...er-pump-sensor
As you can see when compared to the 02 MDX J35A3 they are different (#8) & (#11):
https://www.oemacuraparts.com/v-2002...-pump-sensor-1
People have also switched out the J32A2 EGR valve and, IIRC'ly, the J32A2 MAP sensor because the connector on the MDX wire harness is different; otherwise, it's pretty much plug and play with gobs more torque.
Old Feb 7, 2019 | 07:09 PM
Iggy's Avatar
Correct, J35A3 is plug and play with the Type-S ECU
In addition, swap your A2 cams into the A3 for higher end power. You'll also be able to use your current headers and cold intake.
Old Feb 7, 2019 | 09:30 PM
Karanx7's Avatar
Unregistered Member
As far as I know, Hondata doesn't support any drive by cable engines.
I wouldn't bother swapping an engine yet. Might as well get all the bolt-ons first, and then consider an engine swap if you want more power. Like others have suggested though, the auto trans isn't going to last forever.
2ndgentl
2G CL Problems & Fixes
135
May 5, 2019 07:32 PM
alexanderbowen
Jan 29, 2019 07:48 AM
BigLizard
2G CL Frequently Asked Questions
184
Jun 22, 2014 09:44 PM
PowerRev
Mar 10, 2009 10:53 AM
