Morimoto HID help ! Acura ILX
Old Mar 13, 2021 | 10:23 AM
REEEEEEE's Avatar
Hi y’all just wana talk about morimoto hid’s however it’s spelled. I have it on a ILX and it’s the worst Hid I’ve ever seen as in terms of turning on. But the best lights ever I’ve had. Mix bag.
i tried troubleshooting it with the seller I bought it from but still my lights either one side turns on or the other side or sometimes none turn on. Then the other 50% of the time they work fine. Needless to say 50% issues 50% working. Still no idea why I got replacement ballasts cause they have great support but it still doesn’t work properly.
Old Mar 13, 2021 | 10:26 AM
something is missing here.
what do you mean you tried troubleshooting with the seller? you bought it 2nd hand????
p.s. it really sounds like user error/installation error.
perhaps it's not grounded correctly?
Old Mar 13, 2021 | 10:49 AM
REEEEEEE's Avatar
it’s a authorized dealer and no it was new. By troubleshooting they told me to check the leads for rust my ground and relays etc for rust which in California doesn’t happen but still checked. I have the + on my battery terminal. And the ground I changed from battery to the body radiator support brace area. Got a new battery and replacement ballasts still the same. It can’t be user error cause it works 50% of the time if it wasn’t hooked up correctly it would never work not just half the time :/
Old Mar 13, 2021 | 11:08 AM
Pics please. Did you get a wiring harness as well? I’ve had nothing but good luck with Morimoto but perhaps you got a dud.
Old Mar 13, 2021 | 11:25 AM
something still doesnt sound right. it still can be user error
like thoiboi said; perhaps take pictures of what you received and how you set it up.
Authorized dealer? which authorized dealer????
Old Mar 13, 2021 | 03:00 PM
REEEEEEE's Avatar
is this sound normal ? ( new ballast was sent out month ago)
here are pics too
Old Mar 13, 2021 | 05:21 PM
Did you sand down that 'grounding point' before putting the negative terminal there? id' get some sand paper or a file and sand it smooth to bare metal so you get the best contact, Justin is onto something there, That body part is coated i believe.
Old Mar 13, 2021 | 05:44 PM
REEEEEEE's Avatar
Under the screw was clean bare metal non painted. But either way i had it to my (-) battery post the same issue. Been talking to the dealer SWB or something like that and they said maybe its the wiring harness and i asked for a replacement under warranty hopefully they accept. :/ anyone else have or had the same lights on a ilx?
Old Mar 13, 2021 | 06:47 PM
your issue isnt specific to the ILX.
it's either user installation error or faulty components.
Old Mar 13, 2021 | 06:48 PM
does the ILX not come with HIDs from the factory?
Old Mar 13, 2021 | 07:19 PM
REEEEEEE's Avatar
mine came with halogens. Base ILX
radicalrad
4G MDX (2022+)
May 15, 2021 08:18 PM
ed99
Oct 28, 2011 06:21 AM
termigator
Sep 19, 2005 12:22 PM
Saysana
Dec 4, 2002 11:02 PM
shawhite
Jul 25, 2002 04:01 PM
