Brake Lights
Old Mar 9, 2020 | 03:54 PM
BlkAk2006's Avatar
5th Gear
Post Brake Lights
Okay so I've been searching forums for about 5 days and I have found no clues so I thought I would post. Recently I have found that the brake lights on my 2013 ILX are not working. My third brake light works so I replaced my bulbs, but no luck. My turn signal lights work and running lights at night work. Im wondering if anyone has experienced this. I also went and switched out the brake switch, but that did not yield results either. Any suggestions would be great. Again I hope I haven't overlook any posts on this matter.
Old Mar 9, 2020 | 04:05 PM
DaIll1's Avatar
Have you checked the stop light fuse?
Old Mar 9, 2020 | 05:33 PM
BlkAk2006's Avatar
5th Gear
I did, it was intact
Old Mar 9, 2020 | 06:37 PM
are the brake lights stock or did you replace the bulbs recently?
Old Mar 17, 2020 | 09:46 AM
Chrifff's Avatar
I know this is a dumb question but did you replace the brake light bulbs with the correct double filament bulb? Also check both fuse boxes for any blown fuses.
my user name
2G CL Problems & Fixes
Jan 19, 2018 08:45 PM
smoore
May 27, 2015 12:23 PM
falconsman
Jan 21, 2013 11:49 AM
Nersh7
17
Jun 9, 2010 12:19 PM
euroStyle
1G TSX Problems & Fixes
Nov 4, 2007 09:05 PM
