My brake lights don't work
Old Oct 30, 2014 | 12:36 PM
my user name's Avatar
All of my brake lights stopped working out of no where and I'm not sure how to diagnose this any help is appreciated thank you.
Old Oct 30, 2014 | 12:53 PM
RedRyder's Avatar
Be a better driver
Check fuses and brake light position switch. Do the running lights work?
Old Oct 31, 2014 | 04:26 AM
YeuEmMaiMai's Avatar
+1 for brake position switch. make sure it is adjusted properly. Does the car go in and out of park normally?
Old Nov 12, 2014 | 10:03 PM
Nathan Allan's Avatar
Do you have the brake lamp light lit up on your guage cluster? Had an issue like that and it was a bulb problem
Old Nov 16, 2014 | 09:50 AM
catfriedrice's Avatar
I second this, that was my problem. If you have to use a key to change out of park, this switch has gone bad. Most Acura dealers have this part for about $40, there's plenty of youtube videos on how to change one out, very easy to do.
Old Nov 20, 2014 | 01:48 AM
KR3J//'s Avatar
If you have absolutely no brake lights working, no light bulb indicator lights on your dash and your bulbs light up like normal when you have your lights on, you have a stoplight switch issue. The stoplight switch is located on your brake pedal assembly under your dash and looks like this:
Old Jan 19, 2018 | 08:45 PM
GGrid44's Avatar
I had a similar problem and I am still chasing it down on my '02 TL Type S. I've changed the stoplight switch, checked the fuses and relays under the hood and verified the bulbs. What's interesting is that when the dash brake bulb warning light is on, then the main brake lights work. When the warning light is off, only the third light works in the rear window. Very Odd!
I've taken it to the shop (honda/acura specialist) and they can't chase it down. The bad thing is that it is an intermittent problem and they said bring it back when it's not working. Guess what, EVERY time i take it in, the problem vanishes.
Am I crazy?!?!?!? Is this happening to anyone else?
Any ideas are helpful
mada51589
Jan 9, 2025 04:40 PM
wusty23jd
Sep 24, 2015 11:41 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
theinsvnity
Sep 10, 2015 10:22 PM
drewdeezy03
Sep 3, 2015 08:04 PM
