Brake light on with no issues
Old Oct 7, 2009 | 03:55 PM
Nersh7's Avatar
I Drive Like A Dick 8≈
Ok so first of all its my understanding that there are two break lights in the CL; one when the e-brake is engaged to show that it is engaged and when your low on fluid, the second says "Brake Lamp" I'm guessing its purpose is to tell you when one of your bulbs is dead, out or not turning on.
So my brake lamp light wont go off, I recently smoked my tail lights so I was playing around back there a bit, but made sure everything went back the way it was supposed to. Also Ive made sure that all my bulbs work all the time as well as signal lights and reverse lights. Everything is in perfect working order but my car seems to disagree with me.
Any suggestions as to why its on or how to turn it off??
Old Oct 7, 2009 | 04:25 PM
civicdrivr's Avatar
I think you mixed up the lights on the dash. Check your fluid.
Old Oct 7, 2009 | 05:43 PM
Nersh7's Avatar
I thought that could have been the issue and checked it any way, it was perfectly full.
Old Oct 7, 2009 | 09:01 PM
civicdrivr's Avatar
Double check and make sure all of your brake lights are operational.
Old Oct 7, 2009 | 11:34 PM
Nersh7's Avatar
All lights are working fine and fluid is tip-top, I checked tonight.
Old Oct 8, 2009 | 01:11 AM
aznboi2424's Avatar
make sure sure the brake lights work when you step on it. I broke one of the filments in one of the double-filiment bulbs for the brake light so that when you step on the brake, it doesnt come on brighter.
Old Oct 8, 2009 | 01:32 AM
Nersh7's Avatar
Ya I tried that as well And still no issues all 4 bulbs brighten up when someone steps on the brakes.
Old Oct 8, 2009 | 03:29 AM
aznboi2424's Avatar
and if the high mount brake light is functional too, then im clueless
Old Oct 8, 2009 | 08:05 PM
CLSLV's Avatar
Check the wires going inside the brake fluid. That was my problem, easily solved. GL.
Old Oct 13, 2009 | 04:47 PM
Nersh7's Avatar
That seemed to work, Thanks for the help guys!!
Old Feb 13, 2010 | 07:26 PM
Craig92117's Avatar
7th Gear
Replace the Brake Master Cylinder Cap. The Float has gone bad. Most likely this happens @ 44 Degrees outside temperature or below. I had the same problem on my '01 CL and my '02 TL.
Old Feb 16, 2010 | 02:01 AM
victorvu's Avatar
my problem is i had a spoiler on my car and i cut the old line when i took the spoiler off so theres a BRAKE LAMP light on. my dash looks like a christmas tree with the cruise control, srs, and brake lamp light on.
Old Feb 16, 2010 | 08:53 AM
StreetKA's Avatar
if you put LED bulbs this is whats gonna happen but i c you fixed it
Old Feb 16, 2010 | 10:10 AM
civicdrivr's Avatar
Why cut the wires? Mine has a sub harness that just unplugs.
Old Jun 6, 2010 | 01:41 PM
acura_dipset_tl's Avatar
AM To WDP In My Garage
My light just came on gotta toubleshoot hope its something easy to fix. thanx for the tips in advance.
Old Jun 8, 2010 | 10:26 PM
Add-dee's Avatar
Noobalicious
sounds like a dead to ground or a bad break switch... 2cents
I also could of read your problem wrong...
Old Jun 9, 2010 | 11:30 AM
Nersh7's Avatar
I pulled a noob move and didn't have resistors on my led's
looking back its quite obvious now lol
Old Jun 9, 2010 | 12:19 PM
Add-dee's Avatar
Noobalicious
Ok, thats kinda funny... sucks that it was such an easy fix and took so long.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
wusty23jd
Sep 24, 2015 11:41 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
nishant11
Sep 2, 2015 10:34 AM
