Well, the TSX needed new wheels....ISF is back (Page 64)
Old 01-18-2017, 12:26 AM
  #1601
Majofo's Avatar
Received 11,843 Likes on 8,574 Posts
I either used a 1/16 or 5/64 titanium drill bit.. it effing snapped of course.. but used what was remaining of the bit to finish the job.. hellz yeah!
Sears.com
Sears.com
CCColtsicehockey (01-18-2017)
Old 01-18-2017, 06:57 AM
  #1602
CCColtsicehockey's Avatar
Received 3,836 Likes on 2,572 Posts
Originally Posted by cu2wagon
You're gonna be ready for some rainy weather highway racing in no time. Hunting down STS-Vs... and killing them.
I just hope it is still good at regular rainy driving. It is my DD after all.
Old 01-18-2017, 07:07 AM
  #1603
I haven't pulled the cover off again yet to see if it is flush with the top or sticking out a little bit. It definitely is down in from the top lid for sure a good bit so thinking it is a flush break from below. Going to order myself a 1/4in tq wrench as well for the future along with everything else.
Just need to run to sears if I can't find one of those screw extractors you posted at Lowe's or Home Depot. Amazon really doesn't even seem to carry any.
Old 01-18-2017, 08:12 AM
  #1604
JT4
CTSV,TL, Audi Q7 & A5SB
JT4's Avatar
What are you talking about...........His V isn't RSM.......
Old 01-18-2017, 08:17 AM
  #1605
Received 8,737 Likes on 6,740 Posts
Iuno... I hear BBC's are bad for V's as well
  #1606
(big black cars) ya pervs...
Old 01-18-2017, 09:35 AM
  #1607
Majofo's Avatar
big black cars in vaginas?
Old 01-18-2017, 09:54 AM
  #1608
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
once you go black you never go back...
Old 01-18-2017, 09:59 AM
  #1609
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
False. After going black, there is a possibility of going orange.
Old 01-18-2017, 10:01 AM
  #1610
Orange is the new black after all..
Old 01-18-2017, 10:08 AM
  #1611
KaMLuNg's Avatar
Old 01-18-2017, 12:03 PM
  #1612
Oh lord
Old 01-18-2017, 07:06 PM
  #1613
So after some research I agree it looks like the SMC dual catch can is the best setup. Now the only issue is the fact they are listed as made to order and say they take 8-12 weeks. I don't have that as my build is being done either next week or the week after. So I guess it is back to figuring out which is the second best alternative.
Old 01-18-2017, 10:37 PM
  #1614
Majofo's Avatar
made to order.. wtf?? they must have something on the shelf.. it's an effing catch can..
Old 01-19-2017, 07:02 AM
  #1615
I agree. I sent them an email just waiting to hear back. Hoping it is just something standard they have listed on the site and keep a couple in stock. But 8-12 weeks is what is says on their website.
If I can get one I plan to follow this install. It is really clean. Airaid + Saikou Michi Dual Catch Can Install Even with the easy open valves he installed on the cans I would love to find a way to install something where I don't even have to remove the top of the intake and the fitler to get to.
It sounds like a lot of these guys are emptying theirs every 1000 miles. If I need to do that I will be emptying it 20-25 times a year. I am hoping that I can empty it every 5-10k miles when I do oil changes. Right now I do oil changes every 10k with Mobile1 HighPerf High Mileage. With the new mods and higher boost I might stick with the same oil but switch to doing it every 5k miles.
Old 01-19-2017, 07:03 AM
  #1616
Also anyone that has been doing their own reading on higher boost setups read anything bad about using a 50mm idler pulley?
Old 01-19-2017, 08:26 AM
  #1617
KaMLuNg's Avatar
if you can't wait for the SM, then i'd go Weapon X... they make a great dual setup as well that looks really stealth... it also comes with the drain so you never have to worry about accessing it from the top...
https://weaponxmotorsports.myshopify...ch-can-kit-wxm
otherwise, get the moroso you originally posted and add on one of these...
HTP Catch Can Drains Now Available
CCColtsicehockey (01-19-2017)
Old 01-19-2017, 09:02 AM
  #1618
KaMLuNg's Avatar
that idler is rated to just over 10k rpm... so depending on the size of your upper/lower pulley, the ratio will probably spin if past its max rating... if that is the case you need to step it up to a 70mm idler... but you can get away with the 50mm and just swap out the bearings once they go... it's all going to depend how much more boost you plan on throwing at the car and what pulley size you plan on going with...
they make a relo bracket with the 70mm i think...
Old 01-19-2017, 09:20 AM
  #1619
I will be running a 2.5 upper and a 9.1 lower. Not sure what that will put me at for total. Not sure how to do the calculations. I assume somewhere there are formulas for that stuff?
Old 01-19-2017, 09:22 AM
  #1620
Got an email back from Ben at WeaponX and they have SMC cans in stock actually right now so going to be ordering one of those. For the time being I will have to use the preconfigured drain setup of them but I am going to try and build off the drain setup within that install thread I posted down the road. Just need to get it installed and working before the new tune is done. The shop said it can have an affect on the tune a little bit.
Majofo (01-19-2017)
Old 01-19-2017, 09:32 AM
  #1621
Majofo's Avatar
Yeah I was going to ask.. what's the stock diameter?.. Definitely don't want to go too small.
This is exactly how I'd do it.. what lower are you planning on using? Is it one of those billet lowers like Metco. I always wondered how they held up.
Old 01-19-2017, 09:35 AM
  #1622
Majofo's Avatar
Price is good from Weapon X on the SMC dual catch can..
Old 01-19-2017, 09:41 AM
  #1623
It is the billet one from Metco yeah. I figured I would do pulleys now and a lot of the coiling stuff as well. That will set me up later down the road for just giving everything more air by doing a larger intake, throttle body, port the snout, and do headers.
I don't know when that will be though or if I will be even able to cause I can't afford to make the car uncontrollable to not be a DD in sun, rain, and snow.
Old 01-19-2017, 09:46 AM
  #1624
KaMLuNg's Avatar
if i can get this damn ported tb sold, then i'll pick this up as my next mod as well..
Old 01-19-2017, 10:22 AM
  #1625
rockstar143's Avatar
Received 20,007 Likes on 14,511 Posts
your bank account is probably watching the chappelle show's skit "when keeping it real, goes wrong".
You're so much more a man than I am, J.
I hope you end up with a beast!
Old 01-19-2017, 10:26 AM
  #1626
Not only my bank account but also my head as I never planned to go this quick with mods. Not that I can't it just wasn't in the plans. Excited though and definitely hope it is a beast. Its killing me waiting to know if the parts will all come in time to have the work done next week or if I will have to wait till the week after. Hate that I am not able to do the work on my own either but didn't want to have to have it towed to get the tune afterwards. My previous statements of not being able to break the tires loose should no longer apply after all this too.
Old 01-19-2017, 10:29 AM
  #1627
Why? You're getting a foot and testicle transplant too?
Old 01-19-2017, 11:37 AM
  #1628
I'm not some ladiboi now
Old 01-19-2017, 11:54 AM
  #1629
Post op?
Old 01-19-2017, 11:55 AM
  #1630
Majofo's Avatar
J (RS) has a point, all this modding +power adders.. still haven't gotten that bitch sideways (into a unicorn).
I will say though, what you have planned is still very DD. I think you could DD 800 whp.
The following 2 users liked this post by Majofo:
CCColtsicehockey (01-19-2017), rockstar143 (01-19-2017)
Old 01-19-2017, 12:02 PM
  #1631
KaMLuNg's Avatar
i think after 750 is the breaking point for a reliable DD in all weather...
Old 01-19-2017, 12:04 PM
  #1632
Hay!
Or should I say. Heeeeeeeyyyy! :ghey:
  #1633
Majofo's Avatar
wait.. on E85 or pump?
Old 01-19-2017, 12:26 PM
  #1634
Majofo's Avatar
I can't find the link, but I think GM rated the 6L90e trans to 800 hp in a truck application. Shiett..
There are some guys putting down some epic digs with over 700 whp on it unmodified, so DD the shit out of it.
Anyways.. if fucking Larry Larson daily's his +2000, +3000 hp monsters, you guys are just being pussies
https://www.youtube.com/watch?v=lwF-kr91uxU
Old 01-19-2017, 12:33 PM
  #1635
Majofo's Avatar
Fucking embed is down again.. @IB Jason
Old 01-19-2017, 01:05 PM
  #1636
Majofo's Avatar
Larry Larson is such a bad ass.. I want a shirt with his mug on the front..
and pants with his balls on the front too.. as much as they can print on them anyways..
https://www.youtube.com/watch?v=yrHvNGxJOT0
Old 01-19-2017, 01:17 PM
  #1637
IB Staff
IB Jason's Avatar
Sorry about the embed issues. We're looking into it now!
Majofo (01-19-2017)
Old 01-19-2017, 01:19 PM
  #1638
Majofo's Avatar
Somebody buy @IB Jason a beer.. one of you guys, not me.. you guys being the owner of the store and such.
https://www.youtube.com/watch?v=UVSk4NvsFZE
Old 01-19-2017, 01:32 PM
  #1639
Well then I should be fine. I don't really want to go more than 700whp and even that I really am not sure about. Maybe it is just this area but I have had several people in Hellcats want to go to Mexico and I refuse to. I really want to be able to go to Mexico sometime as the victor. Just not when it is wet out. I think 650 should probably even make that capable. Getting to 700 I would only do cause it just sounds so crazy and would be double the HP output of the TSX.
Old 01-19-2017, 01:33 PM
  #1640
93 pump gas. I travel way to much to both with the flexfuel stuff.
Quick Reply: Well, the TSX needed new wheels....ISF is back (Page 64)
