rockstar143's VAG pounding S4 & S5 thread
Old 07-24-2019, 08:38 AM
  #721
rockstar143's Avatar
Received 19,927 Likes on 14,464 Posts
normally on my way to work if I keep the mph down I get to about 24mpg...so far I've been getting 22.
Who knows...initially I didn't like the idea of mixing in 85 but I guess if it doesn't hurt anything it's fine.
I think the fuel in Florida is different...whenever I travel elsewhere I am able to get better gas mileage.
Probably the bath salts additive.
Old 07-24-2019, 09:15 AM
  #722
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
i average 15 in the V... J needs to teach me how to drive...
rockstar143 (07-24-2019)
Old 07-24-2019, 09:44 AM
  #723
Received 5,893 Likes on 3,891 Posts
My Vagon sold for enough money to pay for the Odyssey and S4
Zero ragrets there.
And 20mpg is actually good for me...I have a lead food...I got the Volvo that was advertised as a 37 mpg car down to
like 25.
Caddy averaged 12.5 mpg for reference...13.5 if I was a good boy.
E85 burns hotter and faster so adding it actually lowers your efficiency...I'm testing to see how well I can do
while still enjoying the added power.
E85 doesn't burn hotter or faster than gas, it just contains less energy content per unit volume but the benefit is that it's got a 105 octane rating so you can run more boost and advance the timing to get more power without getting engine knock. So, because you're both running more boost and the fuel has less energy content you burn way more of it and get way worse fuel economy. It does burn "cleaner" though which is good for the environment.
#science
I'm running about 27 in the C, have seen as high as 36 straight highway & low as 22 all city.
[/MPGtalk]
The Golf will do ~20mpg or worse in the city depending on how you drive it and 36mpg or better all highway in the summer. In the winter (because winter blend gas), it's ~3mpg worse on the highway.
Aman (07-25-2019)
Old 07-24-2019, 10:06 AM
  #724
there's no replacement for small displacement when it comes to good miles per gallon...
no matter what, you're filling 6 liters of space vs 3 vs 2...
pound for pound I guess for the amount of liters the bigger motor is actually more efficient if the numbers were extrapolated based on size.
thanks for the correction, Sam. I don't even know if what you said was any different than me but it sounded better the way you explained it.
I actually use this getupside app to get cash back on fuel fillups and the e85 station was like 3 miles from the good cash back premium gas station...
so I chanced adding the 3 gallons and then the additional 10 at the other station.
Old 07-24-2019, 10:21 AM
  #725
Well with FI engines, the displacement is less of a big thing. Power isn't free, all things the same you have to burn the same amount of gas to get a certain power output no matter what. Whether you add displacement to put more fuel in or add a turbo to cram more fuel into a smaller space, the amount of fuel burned is still the same. The advantage of FI motors is that when you're not on the boost, it burns way less fuel. On the boost, you get just as crappy of fuel economy out of a 300hp 2.0L turbo as you would out of a 300 hp 4.0L V8.
Old 07-24-2019, 10:40 AM
  #726
Yumcha's Avatar
Received 22,713 Likes on 13,930 Posts
Higher grade fuel also seems to help. I finally used 94 and the car seems to have a nice further improvement on mileage.
Old 07-24-2019, 12:15 PM
  #727
Null and proud of it
Midnight Mystery's Avatar
Zero ragrets there.
like 25.
100% solid words here man!
Old 07-24-2019, 12:45 PM
  #728
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,200 Likes on 4,842 Posts
#science
Yep, E85 contains less energy, but has a high octane rating. J isn't running any additional boost in his car though - for one, it's not tuned for it, and two, he hasn't swapped pulleys. E85 also burns "cooler", so it will lower combustion temps (good for engine and power, bad for mpg), which will pack more air molecules into the cylinder. Any gains in power and losses in mpg is strictly due to timing adjustments, less energy in the fuel, and his lead foot.
Are we talking about your 1.8T? My GTI could manage 34-35mpg highway, but the R can barely crack 30. In the winter I get ~25mpg highway. The difference between our cars could be gearing, but 6mpg is a pretty big difference, especially compared to the EPA ratings.
Old 07-24-2019, 12:56 PM
  #729
Just talking about reasons for running E85, you can run more boost because of the octane rating.
And yup, I can regularly get 35-36mpg on long highway jaunts. It surprised the hell out of me too. Just stick it on cruise at 70-75mph and let it go. In the winter time, I'm in the low 30's for longer trips. Maybe it's that extra gear.
civicdrivr (07-24-2019)
Old 07-24-2019, 01:46 PM
  #730
civicdrivr's Avatar
Most likely. Cruising at 80 is ~3k rpm in 6th for me. Boost is constantly around -3 to +4psi. Part of the reason I want a larger turbo is to bump the threshold up a few hundred RPM to maintain vacuum at cruise.
Old 07-24-2019, 03:06 PM
  #731
Azine Jabroni
kurtatx's Avatar
Received 2,159 Likes on 1,387 Posts
Driving downtown in the spring or fall gets me about 30 mpg in the same engine you have. But yeah, the hot summer and AC is killing it
Old 07-24-2019, 03:56 PM
  #732
oonowindoo's Avatar
Received 4,273 Likes on 3,050 Posts
all of you have 300, 400 and even 500hp and we are talking about mpg...
The following 5 users liked this post by oonowindoo:
Acura TL Builder (07-24-2019), Aman (07-25-2019), civicdrivr (07-24-2019), rockstar143 (07-25-2019), RPhilMan1 (07-25-2019)
Old 07-24-2019, 09:26 PM
  #733
Yumcha's Avatar
We are environmentally responsible.
Old 07-24-2019, 10:20 PM
  #734
svtmike's Avatar
Received 3,864 Likes on 2,031 Posts
I only have 250ish hp.
Old 07-25-2019, 06:20 AM
  #735
I just want the best of both worlds...
decent fuel economy (in the 20's) AND 3 or 4 hunnid herspers.
Went to grab a slice with Pops and Z last night...she spotted a rainbow.
He is impressed with the car...he was like why would you want stick, this thing
is basically stick but also relaxed when you want.
The following 3 users liked this post by rockstar143:
00TL-P3.2 (07-25-2019), civicdrivr (07-25-2019), RPhilMan1 (07-25-2019)
Old 07-25-2019, 06:44 AM
  #736
Forgot to post this one of my cousin's ride too...
He's 10 years younger than me and has 2 brothers but he's the only one
that's really into cars. Over the years we've lowered his, put wheels on, put
intake and exhaust on. He tuned it with a stage 1...it's a real fun little driving
car.
Parked in front of him at my aunt's and thought it was a cool pic of some VAG.
#beaverbumpin
Old 07-25-2019, 08:26 AM
  #737
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
Fuel economy
The following 3 users liked this post by Majofo:
civicdrivr (07-25-2019), KaMLuNg (07-25-2019), rockstar143 (07-25-2019)
Old 07-25-2019, 09:27 AM
  #738
KaMLuNg's Avatar
mojo strikes again...
Old 07-25-2019, 11:12 AM
  #739
Old 07-25-2019, 12:11 PM
  #740
oonowindoo's Avatar
when did you get an ass 4? you finally got rid of the brown brown?
where have i been? WTF lol
Old 07-25-2019, 12:16 PM
  #741
@oonowindoo
I sure did...bought this like March 31st.
Old 07-25-2019, 12:30 PM
  #742
oonowindoo's Avatar
I drove that Gen's S4 extensively while i was working for Audi.... I liked it a lot.. The car felt surprisingly light on its feet.
Old 07-25-2019, 02:28 PM
  #743
Yumcha's Avatar
Next time, for even better gas mileage, maybe don't turn on the launch mode, J?
Old 07-25-2019, 02:29 PM
  #744
Yumcha's Avatar
Guessing this yahoo goes launch-mode at every stop sign and red light.
Just red lights.
Old 07-25-2019, 02:45 PM
  #745
I figured if I lessen the time on the road by arriving faster I would reap the benefits of the gas savings.
The following 2 users liked this post by rockstar143:
civicdrivr (07-25-2019), Yumcha (07-25-2019)
Old 07-25-2019, 02:51 PM
  #746
Yumcha's Avatar
That's how I would think too. You're not the only one. That's why I jump curbs.
Old 07-25-2019, 02:55 PM
  #747
sometimes the fastest way from A to B is over curbs and through trees. Ask @justnspace !
If it's any consolation, I curbed the shit out of my rear driver side wheel yesterday. I miscalculated
how far out the curb went. Rookie shit.
Old 07-25-2019, 02:57 PM
  #748
Yumcha's Avatar
Crap. Not any consolation at all, dude. Sh*t...how bad is the damage? Mine is pretty bad...half the wheel will need refinishing/machining (or whatever the alloy repair shops do).
Old 07-25-2019, 03:11 PM
  #749
oonowindoo's Avatar
H1 Hummer seems to be extremely enviro friendly now..
Old 07-25-2019, 03:15 PM
  #750
Like a 3rd of the wheel...had nowhere to go once I hit and felt the car kinda shimmy along it I knew I fkd up.
I already took 100 grit to it at 11pm last night because i couldnt' sleep...you almost wouldn't be able to tell where.
Old 07-25-2019, 03:16 PM
  #751
oonowindoo's Avatar
You know that is a sign for you to get aftermarket wheels right?
Old 07-25-2019, 03:23 PM
  #752
It's not...
I did it to my aftermarket wheels that replaced the badly curbed stocks!
Old 07-25-2019, 03:59 PM
  #753
svtmike's Avatar
If you guys are going to drive ‘em like you hate ‘em, just get a TLX already.
Old 07-25-2019, 06:23 PM
  #754
civicdrivr's Avatar
The TLX is for those that hate themselves.
Old 07-25-2019, 07:18 PM
  #755
Yumcha's Avatar
I'm not losing the Cucklet title, am I...?
Old 07-25-2019, 07:55 PM
  #756
Azine Jabroni
kurtatx's Avatar
A Hyundai optima driver can't be a cuck
a cock maybe, but not a cuck
Old 07-25-2019, 08:25 PM
  #757
Yumcha's Avatar
I suspect it's Cocklet.
kurtatx (07-26-2019)
  #758
Yumcha's Avatar
But, since I'm in Canada and we le speak le French, it's pronounced as "Coke-lay".
Old 07-25-2019, 11:08 PM
  #759
svtmike's Avatar
Nope.
Old 07-26-2019, 07:54 AM
  #760
svtmike's Avatar
This morning’s commute:
Not bad for a car that runs a 14 flat quarter mile.
Majofo (07-27-2019)
Quick Reply: rockstar143's VAG pounding S4 & S5 thread
