The Official Honda S2000 Thread
Old 05-07-2014, 08:16 PM
  #2641
Honda+Blue=My garage
pmptx's Avatar
Did the K&N FIPK installation yesterday..
It sounds amazing!
I love the intake sound on my FIPK, vs the exhaust sounds.
Great pickup and a steal of a price.
Old 05-08-2014, 10:13 AM
  #2642
The Dumb One
Rockstar21's Avatar
either im weaker than I thought, or that allen bolt that holds the idle gear was tightened by the hulk himself.
Old 05-08-2014, 10:46 AM
  #2643
Ken1997TL's Avatar
Received 2,329 Likes on 1,309 Posts
It's tight.
Old 05-08-2014, 11:10 AM
  #2644
Turd Polisher
TylerT's Avatar
Received 3,017 Likes on 1,515 Posts
Got the car back yesterday afternoon.
2 things to note:
1: Engine is silky smooth- on cold starts & when the oil temperature finally peaks, vibration is cut down quite a bit and feels great
2: While the plugs were out, they did a compression test and it came back with flying colors (230 - 235 across all cylinders) - fresh oil, plugs and valve adjustment brought my numbers up a bit since my purchase 4 months ago.
Aside from purchasing new rear tires, I'm on the hunt for some Buddy Club N+ ... these F&F Type 2s are feeling a bit aged.
Old 05-08-2014, 03:30 PM
  #2645
E92
TommySalami's Avatar
2 things to note:
Any particular reason for buddy club? Those seem like what people get when they just want to lower the car and don't care about how it really handles. I'd recommend at a minimum the KW v3 or Bilstein pss9, though if you're tracking the car you'd probably want something more like kw clubsports
Old 05-08-2014, 05:50 PM
  #2646
I drive a Subata.
JS + XES's Avatar
Received 2,603 Likes on 1,571 Posts
2 things to note:
This!
F&F and Buddy club are all pretty.. well.. low quality.
Save up and go for something a little better.
Old 05-09-2014, 10:00 AM
  #2647
Turd Polisher
TylerT's Avatar
Thanks for the suggestion fellas! I think the Bilstein PSS9 will be a worthy replacement.
KW V3s are running around $2500 - $2700 new
Old 05-09-2014, 11:51 AM
  #2648
oonowindoo's Avatar
Received 4,273 Likes on 3,050 Posts
Do not get buddyclub coilovers.
I had it on my 05 and removed it after 2 weeks.
It was so stiff to the point that your head will hit the roof when there is a tiny bumps on the freeway, literally.
and the spring had no travel at all, which means you will not be able to drive up to any kind of entrance ramp without getting stuck.
if you track often, i would recommend buddyclub Spec 3 single. It is ugly and ridiculously loud. but it is probably one of the very few exhaust that actually give you some power vs. - power
It is as straight as it gets and the whole entire pipe only weights like 8 or 9 lbs if i recall correctly. The weight is comparable with most of the Titinum exhaust, but it only cost around $400 brand new.
It sounds nice but your ear will bleed if you drive it on the street, but you can't find a better performing exhaust for the track tho.
Old 05-09-2014, 08:17 PM
  #2649
Chapter Leader (Houston)
TLDude876's Avatar
Received 1,085 Likes on 810 Posts
Installed BC racing coilovers a few weeks ago and they feel great IMO. I have them on my TL also
Old 05-11-2014, 07:51 AM
  #2650
neuronbob's Avatar
Received 4,613 Likes on 2,193 Posts
I think I figured out my noise problem after much research and a little thinking. It's probably rear wheel bearings. Have a appointment at the S2000 specialist at my local dealer for that issue and to have the axle nut checked for proper torque. There was a TSB from Honda on loose axle nuts from the factory, and I'll ask about it. I'm going to get the yearly oil change and an alignment while I'm at it. I'd try replacing the bearings myself, but that looks a little time consuming, and I'd likely need a press to get it done right.
Besides, the dealership's owner and at least one service manager have an S2000 as well, and they keep one guy on staff who has worked on S2000s for many years, so I am willing to pay a little for appropriate expertise.
If it is bearings, I suspect I did them in after my last set of wheels, the Rotas from lots earlier in this thread, as I left the hubs exposed due to fitment. Or it could be age. The car is 12 years old next month, after all.
Old 05-11-2014, 08:38 AM
  #2651
kreapin's Avatar
I spent quite a bit of time doing research and seat time in any s2 before I purchased my coilovers. I agree with some of the posts above except I understand saving $2000 for just coilovers can be difficult. The bilsteins are excellent DD coilovers but for more aggressive or some track use look into fortune auto 500 with swift springs. Both the bilsteins and fortune auto use digressive struts, excellent high speed control and ride quality. That's just my opinion from my own experience
Old 05-11-2014, 10:09 AM
  #2652
The Dumb One
Rockstar21's Avatar
How is it that normally a place like tire rack that is known for giving you "conservative" options when you search using your car, says that 17x9 rear and 17x8 front both with +45 will fit.
But I'm hearing lots of different answers. Saying I need +55 to make those sizes fit without rolling fenders.
I wouldn't think tire rack would sell you wheels that would crush your fenders after the first big bump in the road?
Old 05-11-2014, 11:30 AM
  #2653
kreapin's Avatar
17x9 +45 will fit and not rub (should not rub ). +45 is minimum offset for 9" rear with 245 tire
Old 05-11-2014, 11:33 AM
  #2654
kreapin's Avatar
Oh and +45 with 8" front might rub, I think +48 with 17x8 is minimum
Old 05-11-2014, 02:00 PM
  #2655
E92
They will fit. May need to run a little more than stock camber (which is not nearly enough anyway) and roll fenders at most if you're putting 245/255s on.
Old 05-12-2014, 01:02 AM
  #2656
4th Gear
boredstudent3's Avatar
I'm a track noob, so please forgive my lame moves. Enjoy!
I'm going back for more.
got addicted to thr track, eh?
Old 05-12-2014, 11:32 AM
  #2657
pmptx's Avatar
This^^
Rears are fine no issue. My fronts with the TRM C3 9" +63 clear fine, but I run track camber -3.2 and am lowered on AST4150.
Just get a bit more offset and you will be fine.
Old 05-12-2014, 01:38 PM
  #2658
The Dumb One
Rockstar21's Avatar
Unfortunately that's the highest offset enkei offers in 17x8 for our bolt pattern.
It will be ok. I'll add a little front camber if necessary. Thanks for the info guys.
Old 05-12-2014, 07:57 PM
  #2659
StreetKA's Avatar
http://blog.caranddriver.com/honda-m...-the-original/
Old 05-12-2014, 08:13 PM
  #2660
rockstar143's Avatar
Received 19,994 Likes on 14,502 Posts
What took me so long to find this thread...
and other RS!
Thoroughly enjoying this car. Those that say the N+ buddy club are harsh, you sure you had the preload set correctly? I find them to be very comfortable for daily driving. I mean, the ride is somewhat harsh due to the sporty nature of the car but sitting pretty much maxed rear height and rebound set to almost soft, I'm quite happy with the handling characteristics and the "give" over bumps in the road.
I'm also still somewhat baffled at the offsets on this car. I have 15/20mm spacers on the ap2v2 wheels...and had 10/20mm spacers on the te37's 7.5" 225/40/18 +48 all around and had to play with height a lot. Ended up pulling fender getting that fixed now.
DSC_9390 by swimex37, on Flickr
The following 2 users liked this post by rockstar143:
Ken1997TL (05-12-2014), VR1 (05-12-2014)
Old 05-12-2014, 09:23 PM
  #2661
E92
Do you like the style of the PF01ss? They were designed to fit this car just right and I like mine better than the rpf1.
Old 05-13-2014, 01:39 PM
  #2662
oonowindoo's Avatar
and other RS!
I think that picture just made me broke my promise to myself to never buy a silver car again.
Old 05-13-2014, 02:07 PM
  #2663
Hey, I was always against a silver car! I think they're boring but something about it, looked like it was molten silver and the wheels matched so well.
I will say, hides the dirt and swirls pretty effin well too!
Here's what it looked like with the TE. They were a bit too big and a bit too narrow, I liked the overally look, but the car drives so much better on the oem 17's.
DSC_9963 by swimex37, on Flickr
This is my favorite shot of the car
DSC_9077 by swimex37, on Flickr
The following 3 users liked this post by rockstar143:
Ken1997TL (05-13-2014), RPhilMan1 (05-14-2014), Undying Dreams (05-13-2014)
Old 05-13-2014, 04:14 PM
  #2664
Turd Polisher
TylerT's Avatar
Oh great, the picture whore is back
Car is looking great man!
rockstar143 (05-13-2014)
Old 05-13-2014, 04:30 PM
  #2665
oonowindoo's Avatar
OEM 17s with some spacers look better than most of the aftermarket wheels on s2k.
Except for BBS LM.
Old 05-13-2014, 04:31 PM
  #2666
Ken1997TL's Avatar
@ 'Botox for Dummies' in the picture
Old 05-13-2014, 07:12 PM
  #2667
No kidding, that was unplanned...
Tyler, STFU, you know you love me! :gheyhug:
Thanks everyone, yeah, I agree...I'm likely going to sell the TE and be happy with the AP2 wheels on proper spacers.
Old 05-14-2014, 05:45 AM
  #2668
kreapin's Avatar
and other RS!
The buddy clubs do have a pretty good ride but in my opinion your better off spending $200 more and picking up the fortune auto for a 2 reasons, they can be rebuilt for $100 each and custom valving to match whatever spring rate you choose to use. 2nd reason is digressive struts vs progressive struts, digressive can be harsh during low speed cruising but very good during higher speeds.
Old 05-14-2014, 07:38 AM
  #2669
Good information!
Well, in all fairness I picked up my set for $530 shipped, so I really couldn't complain. I'd likely give the fortune or bc racing a shot if I ever decide to swap or they fail.
Old 05-14-2014, 09:07 AM
  #2670
2024 Honda Civic Type R
RPhilMan1's Avatar
Received 1,475 Likes on 932 Posts
I never thought I'd get a silver car, either, and in the end I really like it.
Old 05-14-2014, 09:31 AM
  #2671
Honestly, I love how much of the dirt it hides and how I don't have to dry it perfectly and not see water spots. Up side to everything!
Old 05-14-2014, 10:26 AM
  #2672
kreapin's Avatar
I had a berlina black s2 and it was dirty 90% of the time, it was dirty within minutes of a wash & wax SUCKS
Old 05-14-2014, 10:39 AM
  #2673
RPhilMan1's Avatar
I would never buy a black daily driver again. Only a garage queen.
Old 05-14-2014, 10:48 AM
  #2674
Ken1997TL's Avatar
+1
My first TL was black, looked amazing when I bought it.. all downhill from there..
Old 05-14-2014, 12:26 PM
  #2675
The Dumb One
Rockstar21's Avatar
how much you sellin them TE's for old man....
Old 05-14-2014, 01:17 PM
  #2676
Hmmm...I'm not sure I'm doing it just yet, but I'll certainly let you know when I decide to.
and we can't BOTH be the dumb one!
Yeah, my daily is a black TL. That's why I specifically did NOT go black on another car.
Old 05-14-2014, 02:57 PM
  #2677
The Dumb One
Rockstar21's Avatar
what were the specs on them? they look like the fit pretty well judging by the height you set the car at.
Old 05-14-2014, 04:07 PM
  #2678
kreapin's Avatar
I picked up a 07 tl-s in silver and an 03 m45 also in silver, I love black but 6 weeks with no wash and car still looks good
Old 05-14-2014, 04:52 PM
  #2679
Yeah, with black, you keep it waxed and it looks good enough for the most part because you focus more on the reflection than the dirt on the surface IMO.
Rock, they are 18 x 7.5 +48 all around on 225/40. I had 10/20MM F/R Spacers in addition...
Old 05-14-2014, 07:09 PM
  #2680
neuronbob's Avatar
I love my silver S2000. I've been driving it all week in the rain, and it still looks clean from 20 feet.
My first TL was black. OMG that was hard to care for. My second TL was silver. Bliss!
Now I've got my blue Beastwagon. The blue really pops but it's as hard to care for as black.
rockstar143 (05-14-2014)
Quick Reply: The Official Honda S2000 Thread
