JS+MS3's 2010 Mazdaspeed3 Updates (Still a 4x4)!
Old Feb 16, 2012 | 04:11 PM
  #961
JS + XES's Avatar
I drive a Subata.
Originally Posted by phee
i bet people have given you great advice so far but i will chime in anyway.
do not let air out of your tires on your first run. you need a baseline.
when at the tree you will be asked to the pre-stage lights, as you roll forward the first yellows come on and then you roll forward a bit more for the 2nd stage read lights.
-i typically do not roll onto the 2nd stage ready lights until my opponent give me a nod or rolls up.
once at the tree you will have a countdown, do not leave when the green is on. leave when the last yellow turns on. this will net you a great reaction time since it takes .500 for your brain to tell your foot to hit the gas.
Preloading:
driving a FWD high powered car is a bit difficult but it doesnt mean you have to run shitty times, this is where preloading comes in.
preloading simply means finding your optimal launch RPM (whatever that may be) holding that RPM in place and slowly releasing your clutch pedal until your car is on the verge of moving. this will get your right at the perfect spot to release the clutch and go without too much slipping or wheel hop.
the reason i pre-load is because it prevents the sudden jerk of the engine when you launch and the weight transfer is minimized.
once you are on your way focus on your tach, shift 100-200RPM before your fuel cut (this takes time to get perfect) remember your clutch pedal doesnt need to be slammed all the way down to allow you to get in and out of gear, if you can learn to shift rapidly at your clutch sweet spot that will be good for a few tenths.
If you have wheel hop, ease off the gas slowly. if you have wheel spin, stay in it, the tires will grip and be ready for your next run.
if at any minute you feel that youre going to lose control or go into the other lane LET OFF and coast. no sense in killing anyone.
some more tips:
go around the water unless you have slicks.
do not do burnouts as radials just get greasy.
open your hood between runs and let the engine cool off.
since your car is turbo i wouldn't shut it off between runs.
drop 4 psi per run till you find the perfect amount of spin and grip.
inflate your rears to 40 PSI
i currently drive a 93 civic hatch with a b swap. i used to have a swapped 6mt 2nd gen TL
WOW Thank you very much man. That's a lot of great advice.
I do have Launch Control and Flat Foot Shifting. Should I use both of them? I can set the LC to be at any RPM and I found out that around 2500rpm is the best. I don't know how the road condition is at the track since I've never been to one, but on regular street, when I use my LC, the car just shoots out of the hole. I kinda have to shift into 2nd pretty fast.
And my car pulls the hardest up to 6000rpm, after that it just keeps the power but doesn't pull any harder. So, I should shift when it's at like 5900rpm, correct?
Hopefully, the day won't be too hot!
Old Feb 16, 2012 | 05:26 PM
  #962
phee's Avatar
I got the Shifts
Because of the stickier surface of the track 2500rpm may be too low. I used to launch my TL at 4000 rpm. No was I could do that on the street and not leave tire chunks on the doors.
What is your redline? And what does your power band look like? Give me gear ratios too if u have them and the speeds at which each gear ends.
Old Feb 16, 2012 | 06:28 PM
  #963
JS + XES's Avatar
I drive a Subata.
Let me post some datalogs for you later today.
Old Feb 16, 2012 | 10:38 PM
  #964
JS + XES's Avatar
I drive a Subata.
Old Feb 16, 2012 | 10:42 PM
  #965
JS + XES's Avatar
I drive a Subata.
As you can see, the car pulls hardest up until 6k rpm and kinda tapers off from there. My redline is at 6.7k though. But it was proven from other Mazdaspeed3 members that it's best to shift at 6k to achieve the best result at the drag strip.
I can add about 1-1.5 timing for more aggressive map. But if I add +2 timing, I get KR. California really gets some gay quality gas.
Old Feb 16, 2012 | 10:43 PM
  #966
JS + XES's Avatar
I drive a Subata.
So, the track is stickier than the street, right?
Old Feb 16, 2012 | 10:59 PM
  #967
JS + XES's Avatar
I drive a Subata.
Oh yeah, Calculate = Calculated Load
Old Feb 17, 2012 | 02:55 PM
  #968
phee's Avatar
I got the Shifts
dyno graph?
Old Feb 17, 2012 | 02:56 PM
  #969
phee's Avatar
I got the Shifts
i would still shift at 6500 so that you can drop closer to your powerband. depending on your gear ratios i would even say 7k but i dont know what your max redline is.
Old Feb 17, 2012 | 03:58 PM
  #970
charliemike's Avatar
Fahrvergnügen'd
i would still shift at 6500 so that you can drop closer to your powerband. Depending on your gear ratios i would even say 7k but i dont know what your max redline is.
6700 rpm.
Old Feb 17, 2012 | 04:13 PM
  #971
phee's Avatar
I got the Shifts
Definitely shift at 6700. Shifting at peak power makes you drop further away from your peak power band and just because your power isnt increasing doesn't mean your car isn't accelerating.
Old Feb 18, 2012 | 10:16 AM
  #972
JS + XES's Avatar
I drive a Subata.
Cool. I'll do couple runs with different shifting point to see how it is.
Old Feb 18, 2012 | 11:32 AM
  #973
JS + XES's Avatar
I drive a Subata.
I swear Mazda probably paid MSN to have MS3 in that dumb list.
http://editorial.autos.msn.com/cars-cops-fear
Old Feb 18, 2012 | 11:54 AM
  #974
civicdrivr's Avatar
Old Feb 18, 2012 | 01:33 PM
  #975
phee's Avatar
I got the Shifts
No need for the different shifting points. If you shift lower in the Rpm band you will run slower times.
Old Feb 18, 2012 | 01:44 PM
  #976
JS + XES's Avatar
I drive a Subata.
Maybe I'm missing something. Let me get the dyno graphs from others who have the same mods.
Most people who are tuned with the stock k04 turbo shift at 6000rpm to get the fastest time.
We got no VTEC.
Only the BT guys run it up to 6700rpm.
Old Feb 18, 2012 | 01:50 PM
  #977
Sly Raskal's Avatar
No VTEC? :ghey:
Old Feb 18, 2012 | 01:55 PM
  #978
JS + XES's Avatar
I drive a Subata.
No VTEC, Yes Smile.
Old Feb 18, 2012 | 01:58 PM
  #979
JS + XES's Avatar
I drive a Subata.
Here you go. This guy has everything that I have plus a Downpipe as well as FMIC. But the power points should be similar.
  #980
civicdrivr's Avatar
Ewwww, unibrow!
Old Feb 18, 2012 | 01:59 PM
  #981
civicdrivr's Avatar
Yea, I think shifting closer to 6k where the power trails off will put you right into peak torque.
Old Feb 18, 2012 | 05:27 PM
  #982
phee's Avatar
I got the Shifts
oh wow... that dynograph really helps. I should have asked for that before.
shift at 5500.
if your powerband looks like that you need to retard timing a few degrees.
Old Feb 20, 2012 | 01:20 AM
  #983
JS + XES's Avatar
I drive a Subata.
These pics were taken more than a year ago. Was just bored at home, so I processed them.
Like 3 minutes into processing them, I realized why I didn't touch these when I shot them. They are pretty shitty. But I'm posting them anyway.
Old Feb 20, 2012 | 01:27 AM
  #984
Hapa DC5's Avatar
אני עומד עם ישראל
^ license plate light out
Car still looks good.
Old Feb 20, 2012 | 06:27 AM
  #985
rockstar143's Avatar
That car would love a CCFL plate light...
Have you ever checked out one of those $20 OBDII bluetooth readers and the android app called "Torque"!?!?
I just got it and am AMAZED at what it can do. Your graphs up there reminded me of it.
Old Feb 20, 2012 | 11:49 AM
  #986
JS + XES's Avatar
I drive a Subata.
Thanks guys. The license plate lights had been changed to white LED soon after that shoot.
And yes, I've heard a lot of good things regarding that app. Good to hear that you like it.
Old Feb 20, 2012 | 01:20 PM
  #987
23109VC's Avatar
how is the MS3 on the twisties? does it outhandle your old TL???
i'm looking at getting an MS3 and am curiosu how it is in the cornering / fun dept???
Old Feb 20, 2012 | 05:05 PM
  #988
civicdrivr's Avatar
I liked Torque and the bluetooth adapter - when it worked. The adapter worked for about a month.
Old Feb 21, 2012 | 12:04 AM
  #989
JS + XES's Avatar
I drive a Subata.
Hey, I got your PM. I'll get back to you with more detailed answer tomorrow. I'm like dying everyday preparing for my wedding next month.
But really, MS3 does very well on the twisties. Google up Insideline review of my car. They did a review just on suspension geometry of 2010 Mazdaspeed3. Mazda didn't touch anything on the engine spec for the second generation because they didn't have to. It's just the handling department that they really focused on improving. It certainly shows.
I loved my 3G TL so much, but in terms of cornering/fun department, it's incomparable to MS3.
You just gotta do a test drive at the dealer. You'll know.
As for the interior space, I just bought a Samsung 55 3D TV and fit that in my car. That TV is fucking huge. That should give you an idea of the utility side of this little hatchback.
Old Feb 21, 2012 | 06:47 AM
  #990
To me, a hatchback is the ultimate automobile. And this one is fast also...and affordable. Doesn't get much better than that.
civic, that sucks to hear...had to be within warranty, no? My buddy has a cheap one too, been using it for a couple of years. I love it so far.
J.
Old Feb 21, 2012 | 10:19 AM
  #991
civicdrivr's Avatar
Nope, there was I think a 14 day money back guarantee, no warranty though. Doesnt matter to me, I will have no use for the OBDII port soon
Old Feb 21, 2012 | 10:31 AM
  #992
Hmmm...ninja status, huh?!! You're swapping to OBD1, aren't you...
Or going old school American Muscle...
Old Feb 21, 2012 | 10:40 AM
  #993
civicdrivr's Avatar
Who told you I was going to carbs???
Old Feb 21, 2012 | 10:46 AM
  #994
JS + XES's Avatar
I drive a Subata.
You guys need to get the cars that work with Cobb AP. It's so fun learning about tuning. Very freaking user friendly too.
I think I'll get 135 or 335 for my car and get a GTR after? Just because Cobb supports those platforms.
Old Feb 21, 2012 | 12:20 PM
  #995
...I just used conductive reasoning.
I've heard of Cobb...must be easy to tune and awesome to make you use that to decide what car to pick!
J.
Old Feb 21, 2012 | 12:50 PM
  #996
JS + XES's Avatar
I drive a Subata.
J.
Yes. Very easy to tune and Cobb is extremely helpful. You'll know when you get to use it.
Old Feb 21, 2012 | 05:31 PM
  #997
crazyasiantl's Avatar
post a pick of your JBR knob, i want to see how it looks in the car
Old Feb 21, 2012 | 08:47 PM
  #998
JS + XES's Avatar
I drive a Subata.
http://www.mazdaspeedforums.org/foru...thread-100732/
Old Feb 22, 2012 | 05:40 PM
  #999
JS + XES's Avatar
I drive a Subata.
So... next Monday is my birthday and one of my best friends told me that he'll buy me anything that's under $300. I found 2 items that are right under $300.
GoPro = $290 Prime from Amazon
Swift Springs = $299 Shipped
I really really really want both for my bday, but I can only get one.... Which one should I get?
Just to let you guys know, even if I get the springs, I won't install them until later when I decide to get a set of shocks. I'm enjoying every moment with my new rims and tires right now.
Old Feb 22, 2012 | 05:57 PM
  #1000
jjashaa's Avatar
Avant Garde Wheels
do people often sell swift springs on your forum?
like used ones.
