Old Sep 18, 2013 | 08:11 PM
  #4321
Yumcha's Avatar
Originally Posted by Aman
So that's the original Snowplow, huh?
It looked good. Versus kit looks a little too aggressive for me, but I bet it popped with aftermarket wheels.
Thanks, dude.
Yeah, the CL-S definitely stood out in a good way I think. Definitely good memories...
Old Sep 19, 2013 | 08:16 AM
  #4322
RPhilMan1's Avatar
2024 Honda Civic Type R
I have yet to see my TSX around, and it would definitely stand out. Probably just too big of a city and area to ever see it again.
Old Sep 19, 2013 | 09:28 AM
  #4323
CLtotheTL32's Avatar
CL
Old Sep 19, 2013 | 01:32 PM
  #4324
srika's Avatar
Moderator Alumnus
damn one of the very few MB's that holds its value....... and I do it...
http://www.dupontregistry.com/autos/...itemid=1895916
Old Sep 20, 2013 | 08:03 AM
  #4325
Ehhhhhhh. I wouldn't call $25k in depreciation per 1k miles "holding it's value"
Old Sep 20, 2013 | 09:46 AM
  #4326
Yumcha's Avatar
Interesting! Thoughts on the look of the concept/design?
Old Sep 20, 2013 | 09:51 AM
  #4327
chill_dog's Avatar
Oderint dum metuant.
I like it.
Old Sep 20, 2013 | 10:38 AM
  #4328
Aman's Avatar
Your Friendly Canadian
It's got all kinds of awesomeness that don't go together.
DB5s, knock off wire wheels are awesome.
The shooting brake shape, wide tires, big brakes are awesome. But they don't go together IMO.
Old Sep 20, 2013 | 01:42 PM
  #4329
srika's Avatar
Moderator Alumnus
some of you probably already seen this... F40, F50, and Enzo for sale as one collection.... all with under 300 miles on the clock
http://www.dupontregistry.com/autos/...itemid=1806178
Old Sep 20, 2013 | 01:45 PM
  #4330
srika's Avatar
Moderator Alumnus
friend put his ZR1 up for sale... check out the mod list
http://www.chicagomotorcars.com/web/...inois/1331186/
C6ZR1 1 7/8 American Racing Stainless Steel Headers
C6Z American Racing X-pipe with high flow cats
02 Extensions
NGK Spark Plugs(Iridium)
MSD 8.5m spark plug wires
Custom Heat Exchanger
Heat Exchanger water pump with connector
C6 ZR1 High Flow Supercharger Air Intake Snout
C6 ZR1 LS9 2.60 11 Rib 10 Bolt Pulley
ZR1 Corvette High Flow Air Intake Kit
100 mm Diameter Idler Pulley Kit
C6 ZR1 CORVETTE OVERDRIVE HARMONIC BALANCER 2009-2011
160 degree thermostat
LS3 Comp Cam Kit, Comp custom grind cam shaft, comp Double valve spring kit good for .675 lift, Titanium Retainers(custom for ZR1), Spring Seats, Valve seals, and comp chromoly pushrods
Water pump gaskets, Oil pump inlet tube, front cover, crankshaft front seal
LS9 Crank Bolt
Mild to Wild Exhaust Switch
Lowering Bolt Kit
CNC'd LS9 Stage 3 Cylinder Heads
Gm Head Gaskets
ARP Head Studs
Balance, Blueprint & Assemble Shortblock: fully deburr block, line
hone block w/ ARP main studs, deck block to desired deck height
w/ BHJ deck true fixture, bore block on 3 axis CNC, hone block w/
torque plates, balance crankshaft to 1/4 oz. in. tolerance, hang
pistons on rods, check bearing clearances, file fit rings, assemble
shortblock
Lunati 4.0 Lunati forged 4340 4.0" stroke crankshaft
Rods Customer supplied GM Titanium LS9 Connecting Rods
Pistons Diamond custom pistons w/ lateral gas ports
Pins Upgraded Tool Steel Wrist Pins .210" Wall Thickness
TS stainless Total Seal stainless chrome top, napier 2nd., 3mm HT oil rings
Bearings2 Clevite MS 2199 H mains, Clevite CB 663 H rods, Dura Bond
CH-23 cam bearings
LSX main studs ARP Pro Series 12pt. main stud kit
Cloyes LS7 std. chain Cloyes LS7 4x single roller w/extended crank drive for dry sump oil pump
Stage 2 Boost Cooler Methanol Injection
Nitrous Outlet Single Nozzle System
Custom Porting on Supercharger
Old Sep 20, 2013 | 07:51 PM
  #4331
charliemike's Avatar
Fahrvergnügen'd
The SL Black was $300,000?
Old Sep 24, 2013 | 06:14 PM
  #4332
Fahrvergnügen'd
So Autoblog loves the new CTS ... Link
Though, $52k base price is a huge step up from before. For the first time, it feels like the CTS is in the segment it was supposed to be in ...
Old Sep 24, 2013 | 07:37 PM
  #4333
ttribe's Avatar
Ill just leave this here...
10 Ugliest Cars of 2013: http://www.bankrate.com/finance/auto...s.aspx#slide=1
Old Sep 24, 2013 | 10:39 PM
  #4334
Aman's Avatar
If those are the ugliest cars of this year, it's a pretty good year.
Old Sep 24, 2013 | 11:08 PM
  #4335
Fahrvergnügen'd
The 500?! If it had a six speed manual I might have considered an Abarth. Great looking little car.
Old Sep 24, 2013 | 11:11 PM
  #4336
ttribe's Avatar
Saw this camo prototype on the freeway in Phoenix today. Most definitely a Nissan, and most definitely an SUV (duh). Not sure if the Rogue or Murano are up for re-design, but I'm guessing it's one of those.
Old Sep 25, 2013 | 12:12 AM
  #4337
Rick_TL-S's Avatar
So basically, small or "boxy" cars are all ugly besides 1 Buick. Mkay, then.
Old Sep 25, 2013 | 12:28 AM
  #4338
ttribe's Avatar
Didn't say I agree with it...just made it available.
Old Sep 25, 2013 | 06:43 AM
  #4339
Fahrvergnügen'd
I blame you for the article
Old Sep 25, 2013 | 07:33 AM
  #4340
Nice spotting skills Tim!
Old Sep 25, 2013 | 11:02 AM
  #4341
Fahrvergnügen'd
Ford of Europe just reported in a PR that they got 1000 miles hypermiling a 1.0L Ecoboost Focus. That's pretty impressive. 125hp 1.0L Ecoboost 3-cylinder. I imagine we'll see it in the Fiesta at some point in the US.
Link
Old Sep 25, 2013 | 12:28 PM
  #4342
Aman's Avatar
T, I blame you for not strongly disagreeing with the article.
It'd be cool to see that engine in the US. Don't think it'll get that much better fuel mileage in the real world, though.
Old Sep 25, 2013 | 12:45 PM
  #4343
srika's Avatar
Moderator Alumnus
ugliest cars list at a site for "Mortgage rates, home loans, refinancing, credit cards, CD rates with personal finance advice."? yea ok
Old Sep 25, 2013 | 12:46 PM
  #4344
srika's Avatar
Moderator Alumnus
I love those. I would consider owning that top model. I might have to wear a disguise while driving it tho. just kidding. sort of.
Old Sep 25, 2013 | 01:08 PM
  #4345
Costco's Avatar
Same. I've never worried about being an "Asian guy in a muscle car" and I have no problem driving a Miata, but I have some reservations about the Abarth. Big round headlights on a small hatchback is just too cutesy. I do love that shifter position, and the interior simplicity is actually what I prefer.
Old Sep 25, 2013 | 01:09 PM
  #4346
ttribe's Avatar
Just add eyelashes to complete the image.
Old Sep 25, 2013 | 01:10 PM
  #4347
srika's Avatar
Moderator Alumnus
to the car or to the driver? or both?
Old Sep 25, 2013 | 01:11 PM
  #4348
ttribe's Avatar
Whichever floats you boat.
Old Sep 25, 2013 | 01:16 PM
  #4349
Costco's Avatar
Pink eyelashes for the car, fake black eyelashes for the driver, problem solved.
Old Sep 25, 2013 | 01:20 PM
  #4350
srika's Avatar
Moderator Alumnus
I don't like eyelashes on cars
Old Sep 25, 2013 | 02:11 PM
  #4351
ttribe's Avatar
You would if you had a Fiat 500...or a Mini.
Old Sep 25, 2013 | 02:15 PM
  #4352
srika's Avatar
Moderator Alumnus
I get the impression it's a very fun car.
maybe some "it's a rental" graphics all over it would do the trick
Old Sep 25, 2013 | 02:18 PM
  #4353
Yumcha's Avatar
Wow, that's like...grounds for eunuching a person...
Old Sep 25, 2013 | 02:19 PM
  #4354
ttribe's Avatar
Got your attention faster than I anticipated.
Old Sep 25, 2013 | 02:21 PM
  #4355
srika's Avatar
Moderator Alumnus
I don't get it.... care to explain ?
I'm joking, btw.
  #4356
Yumcha's Avatar
Old Sep 25, 2013 | 02:40 PM
  #4357
Yumcha's Avatar
@ movie based on "Need for Speed" video game series...
Old Sep 25, 2013 | 02:41 PM
  #4358
Aman's Avatar
A little too cheesy for me, but if they play it right they could replace F&F
Old Sep 25, 2013 | 02:44 PM
  #4359
Yumcha's Avatar
^ Yeah, started the thread in Ramblings already.
No thank-you.
Old Sep 25, 2013 | 05:44 PM
  #4360
srika's Avatar
Moderator Alumnus
friend's car
