civicdrivr's golfcart and Z8 - 5 thread
Old 05-28-2020, 02:57 PM
  #6201
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,394 Likes on 4,939 Posts
A lot of cars have "lifetime" tranny/diff fluid and have removed the fill plugs - VW is one of them. Lifetime typically just means the life of the factory warranty.
e30cabrio (05-28-2020)
Old 05-28-2020, 02:59 PM
  #6202
rockstar143's Avatar
Received 19,994 Likes on 14,502 Posts
Bowtie boys...
GTFO
Old 05-28-2020, 03:10 PM
  #6203
Received 6,110 Likes on 4,010 Posts
Huh? Both manual and DSG box for the mk7 have a drain plug?
Old 05-28-2020, 03:32 PM
  #6204
LFG RANGERS!!!!!!!!!!!
e30cabrio's Avatar
Received 1,954 Likes on 1,342 Posts
Originally Posted by SamDoe1
So does Lexus. The previous gen IS didn't even have a drain port for the tranny fluid.
I consider exotic cars to be the hand built, small volume, bespoke things like Ferraris, the real Lambos (Aventador), etc. Even then, the issues are almost never the engine itself, it's usually something else that takes the car down.
Same. I'm torn between getting a GT350 or Cayman and daily driving the Jeep or offloading the Golf for a Tesla or lightly used CPO AMG wagon/Porsche sport turismo wagon. Though if Caddy brings back the real V wagon with manual, I'm all in on that.
My X5, All Toyotas for some time have no trans dipstick & make changing the oil a bloody (U.K. English usage) pain in the arse to change. I have done it on the X5 & Tundra, shockingly the X was easier!
As far as my wife I learned years ago I can do what I want if I am willing to put up with a sh!tstorm & choose my battles with care. Having her onboard with things generally makes life much easier. I have gone against her wishes and usually wish I had chosen the path of lesser resistance.
lol
Yup, so true. It's bull$hit.
Costco (05-29-2020)
Old 05-28-2020, 03:38 PM
  #6205
civicdrivr's Avatar
They have drain plugs, but some do not have fill plugs.
Old 05-28-2020, 03:40 PM
  #6206
e30cabrio's Avatar
Thanks. Now I HAVE to find out how the f00k they fill them.
lol
I'm assuming before they are installed through the drain? That would mean the transmission has to come off to fill it. Wholly sh!t!
This is great!
https://www.noln.net/articles/3318-n...hout-dipsticks
Old 05-28-2020, 04:06 PM
  #6207
civicdrivr's Avatar
lol
This is great!
Like this:
Speaking of transmissions - I swapped the factory trans fluid out for Motul Gear 300 last night. In the process, I found out that VW has two different transmission housings - one with a fill plug and one without. Guess which one I have
Thankfully, there is a bolt that can be removed at the top of the transmission to add fluid, but you have to pay attention to how much you are adding so you don't overfill. VW is really pushing this lifetime fluid BS... The new fluid definitely smoothed out shifting once it's up to temp. I think gear lash at low speeds (which was amplified by the single mass flywheel) is lessened as well.
Old 05-28-2020, 04:29 PM
  #6208
e30cabrio's Avatar
I wonder if they all have that secret hole. (Sounds like a new age porno) lol
Old 05-28-2020, 04:42 PM
  #6209
civicdrivr's Avatar
Are you going to go searching for the secret hole on all of the trannies??
The following 3 users liked this post by civicdrivr:
CLtotheTL32 (05-29-2020), cu2wagon (05-28-2020), TylerT (05-29-2020)
Old 05-28-2020, 04:44 PM
  #6210
e30cabrio's Avatar
Nope, but I'm glad my joke landed.
lol
The following 2 users liked this post by e30cabrio:
civicdrivr (05-28-2020), TylerT (05-29-2020)
Old 05-28-2020, 09:42 PM
  #6211
I did a dsg service on the S4 but I don't remember there being a drain hole...I had to pull the pan regardless to access the filters so it didn't matter.
Refilling was annoying and I recall running a hose outside the engine bay higher up to let gravity do it's thing...but it was a very specific process of
starting fill when temp reached exactly 41 degrees cellulite or whatever.
Old 05-29-2020, 07:54 AM
  #6212
e30cabrio's Avatar
On the tundra, I had to get it up to temp, measure the trans temp with Techstream, open the valve that forces the trans cooler open (tow package) fill to fluid dripping out of the fill plug. Drive to get the fluid to flow.
Of course all of that was after pulling the pan, changing the filter and associated cleaning of the magnets & filling the not cheap fluid.
Took three cycles to get fully clean fluid running through the system.
Old 05-29-2020, 08:30 AM
  #6213
Costco's Avatar
Received 3,489 Likes on 2,089 Posts
Another reason to go with a manual
The following 2 users liked this post by Costco:
civicdrivr (05-29-2020), TylerT (05-29-2020)
Old 05-29-2020, 08:35 AM
  #6214
Okay, that just made the Audi seem easy.
Old 05-29-2020, 08:43 AM
  #6215
Your Friendly Canadian
Aman's Avatar
Received 1,485 Likes on 1,049 Posts
Old 05-29-2020, 09:09 AM
  #6216
e30cabrio's Avatar
I doubt the 6k lb CrewMax has a 6cyl which is the only Tundra available (not sure of 2020) manual. I know I would not want to drive a 6 Cyl Tundra.
The X5 was easy in comparison.
Originally Posted by Aman
Yup
Also,
Hey! it's a Scirocco!
https://offerup.com/item/detail/8828...71327530138105
Old 05-29-2020, 09:27 AM
  #6217
Like this:
How did they factory fill it then? Fill through drain hole then flip it over before installing? Either way, this is something I'll pay to get done. I just don't want to deal with it.
Old 05-29-2020, 10:02 AM
  #6218
Received 5,491 Likes on 3,748 Posts
And I thought doing a 3x3 on the 2G TL was a bit of a pain...
The following 3 users liked this post by 00TL-P3.2:
Costco (05-29-2020), Midnight Mystery (07-14-2020), TylerT (05-29-2020)
Old 05-29-2020, 10:18 AM
  #6219
Turd Polisher
TylerT's Avatar
Received 3,017 Likes on 1,515 Posts
In some respects .. older / simpler cars are much more enjoyable
The following 3 users liked this post by TylerT:
Costco (05-29-2020), Marcelechka (05-29-2020), Midnight Mystery (07-14-2020)
Old 05-29-2020, 10:47 AM
  #6220
in almost all respects
unless you get used to newer tech and then you know it's missing and you miss it.
Old 05-29-2020, 10:57 AM
  #6221
Aman's Avatar
Going from a car with a backup camera to one without a backup camera wasn't fun. That's definitely a piece of tech I have to get used to living without again.
The following 2 users liked this post by Aman:
Old 05-29-2020, 11:02 AM
  #6222
try parallel parking the yukon xl without one
I don't wonder why almost all of them have the passenger side rear quarter damaged.
The following 2 users liked this post by rockstar143:
Aman (05-29-2020), ttribe (05-29-2020)
Old 05-29-2020, 02:46 PM
  #6223
StreetKA's Avatar
I'd consider 3rd gen CTS-V if you want AMG, freaking badass car.
Old 05-29-2020, 04:12 PM
  #6224
I would save the cash and get a 2G and make it a monster.
Old 05-30-2020, 11:48 AM
  #6225
e30cabrio's Avatar
Here's an odd twist. I found an M2 on Truecar I like. For sh!ts & giggles I entered the Tundra info to see the trade in offer, with only having aftermarket radio, they deducted 1500. WTF?
Forget it has a 1500.00 Pioneer NEX 2 year old but top of the line DVD NAV HU, Pioneer amps, Hertz speakers, JL sub fully integrated into the oem system & steering wheel controls professionally installed I get I'm not getting the close to 5k spent but -1500. No.
Old 05-30-2020, 12:13 PM
  #6226
Aman's Avatar
Old 05-30-2020, 12:24 PM
  #6227
Costco's Avatar
What year and model is the Tundra?
Usually you get screwed on trade-ins. If not they will find another way. You probably know but sadly aftermarket add-ons rarely add value to a car, especially not what they should be worth.
I made the decision a while ago that whatever mods I do, I do for my own enjoyment. Keeping the miles off for resale value is just making the car nice for the next owner.
Helps me not justify a "weekend car" but maybe that's just a bit of cognitive dissonance.
charliemike (05-30-2020)
Old 05-30-2020, 12:38 PM
  #6228
e30cabrio's Avatar
It's a 2010. I have never expected to get mod money back and agree it's insane not driving the vehicle (truck has 182k) I expect 15k and won't let it go for less, I don't need to sell it. It has over 10k spent on mods (for me) but I do expect to be able to say the 2k old 3k in suspension isn't making it worth that much more but it sure as hell goes towards upkeep done and no use deduction like the tires needing to be replaced would. (It has new tires also)
It also has (retail) 1400 per 2020 Sequoia LEDS that I spent about 1200 on used that make it look newer than a 2020 Tundra & 1500 ARB bullbar, 1000 winch, 700 powercoated steel rear Ranchhand bumper 2018 Tundra interior etc.
It's an SR5 but has limited Optiron gauges & Auto AC that was a hassle to get in there and makes it much nicer to drive.
KBB with mileage dealer sale price is currently 15k-18 bone stock.
No way aftermarket accessories can reasonably cause a deduction.
civicdrivr (06-01-2020), Costco (05-30-2020)
Old 05-30-2020, 01:01 PM
  #6229
Costco's Avatar
WTF? Toyota trucks hold their value like crazy, that wasn't right at all. I thought given the trade-in offer that it was maybe an early '00s model. Suppose the requirement of a diagnostic tool to do a trans fluid exchange should have been a hint...
Definitely private party it, if nobody bites for what you feel is right return it to stock.
e30cabrio (05-30-2020)
Old 05-30-2020, 01:03 PM
  #6230
Aman's Avatar
I know the rule is generally that mods don't add value, but they occasionally can for the right buyer/market. A dealer trade-in will almost never appreciate any kind of modification.
A $1500 deduction for car audio is hilarious, though.
Old 05-30-2020, 01:05 PM
  #6231
e30cabrio's Avatar
It's all academic seeing I'm not taking on a payment now. If I want to do a car for truck trade though there's a SC miata.....
https://phoenix.craigslist.org/cph/c...116405431.html
lol
Old 05-30-2020, 02:24 PM
  #6232
e30cabrio's Avatar
It's funny, I listed some mods & forgot the important ones. It has a S&B cai, Doug Thorley long tube headers, full dual exhaust, and a tune all which makes it stupendous fun to drive, I remembered when I just went to get lunch and embarrassed a Challenger that thought he would walk all over the lumbering truck.
lol
(there's still a bunch of other stuff too)
Old 05-30-2020, 11:04 PM
  #6233
@CLtotheTL32 I know this wasn't the upgrade we were after immediately but couldn't you sell the Taco enough
to cover this upgrade at bro pricing? Sounds like it's decked the fuck out.
ttribe (06-02-2020)
Old 05-31-2020, 09:55 AM
  #6234
e30cabrio's Avatar
Created a thread specifically not to pollute here. (even in the title)
https://acurazine.com/forums/car-tal...thread-987844/
lol
Old 06-02-2020, 04:30 PM
  #6235
e30cabrio's Avatar
I'm ashamed how my posts derailed Morgan's majestic thread. God forgive me.
lol
Old 06-02-2020, 04:37 PM
  #6236
Yumcha's Avatar
Received 22,861 Likes on 14,005 Posts
lol
Old 06-02-2020, 04:39 PM
  #6237
e30cabrio's Avatar
Seeing as how there's been nada I could not resist.
Old 06-02-2020, 05:28 PM
  #6238
civicdrivr's Avatar
e30cabrio (06-02-2020)
Old 06-03-2020, 06:09 AM
  #6239
Morgan is town whore.
Old 06-05-2020, 12:44 PM
  #6240
Received 8,711 Likes on 6,718 Posts
now your thread is a ghost town
civicdrivr (06-05-2020)
Quick Reply: civicdrivr's golfcart and Z8 - 5 thread
