C&P Random Thread -
#5762
I shoot people
#5763
Earth-bound misfit
Sweet! Is this DCist?
#5765
if it's from a different angle, and same distance, same light modifiers (if any), aiming at the same spot, then I would say yes. BUT suppose one is further than the other, then remember the "Inverse Square Law""Inverse Square Law" even at the same power, the light drops as the distance increases.
I did a little test and even though my 430ex is older than the yongnuo yn560 it does better in syncing and recycle time is faster. In 6 shots using cowboy studio triggers the 430 fired on all 6 but the yongnuo only fired twice. Not knocking on the yongnuo since its a good flash on a budget. A yn560 and external battery pack is about 90 bucks on amazon which is good if you are shooting with just hotshoe flashes on a softbox.
I just need a 28" soft box and I am good to go
#5766
Earth-bound misfit
#5767
I shoot people
Ah thanks man. No diffusers are going to be used though
#5768
Well that's about to change... I was one of the winners of a local blog photo contest and will be displaying a photo at a gallery in DC
They're suggesting mpix.com for printing - has anyone use them before? It has to be acid-free, archival paper... not sure if WHCC does that?
#5769
I shoot people
#5770
I miss my 03 CL-S :(
#5771
lovely - nice job.
#5772
intended...
actual
actual
#5773
My first Avatar....
When buying a used lens....Do you guys think there is a downside to getting a NON USM lens?
#5776
My first Avatar....
#5777
Check if this guy still has it
http://photography-on-the.net/forum/...ighlight=100mm
#5779
Creepy guy in the mirror.
It is just a question of noise and focus speed. The non-USM motor is gonna be noisier and slower than the USM. Depends on if it matters for you.
#5780
Received 2,787 Likes
If you are using it for macro check if the front element goes in or out when focusing.
the USM version doesn't. Not sure about the non-USM.
#5781
My first Avatar....
Thanks Guys. I think the lens does extend on the NON USM example. The AF is slower and noisier too.
I'll stick with a US model rather than pay less, and take the chance on it not being what i want it to be.
#5782
Nvm it does get longer
http://photography-on-the.net/forum/...d.php?t=452037
Optically there is very little difference between the 100mm macro USM and non-USM. The bigeest difference is that the USM version does not get physically longer when focusing closer. The non-USM version of the 100mm macro gets nearly twice as long physically when focused at 1:1 than when focused at infinity. The non-USM version gets physically longer the closer you focus the lens.
This is a decided disadvantage when trying to light your subject with natural light and/or flash. You can use a ringlite with both lenses but a ringlite delivers flat and unattractive lighting.
Also, since working distance is measured by Canon, from the film/sensor plane, the USM macro will allow for a greater working distance from the front of the lens to the subject being photographed. The USM version of the 100mm macro lens has decided advantages over the non-USM and is well worth the price difference between a used 100mm non-USM lens and the current 100mm USM macro lens.
#5783
My first Avatar....
#5784
Sorry if I am stating the obvious. USM does not have anything to do with country of origin. It stands for Ultrasonic Motor.
pttl (01-18-2013)
#5785
My first Avatar....
#5786
My first Avatar....
#5788
#5789
the next time you question why battery grips cost so much, have a look at how much Leica charges for their M9 "grip" - this is ONLY a grip - it does not hold batteries.
http://www.adorama.com/LCHGMM.html
#5790
I shoot people
#5791
They have a 50% off deal certain sizes ending today with code FB50off
#5792
I shoot people
have you guys seen this? It's by Sunbounce call the "Bounce Wall"... so it's like you have a wall to bounce your flashgun everywhere you go
#5793
That's just silly looking,
It's like that one guy that made a setup where the 2 flashes were sticking over his left and right shoulder, like old school rabbit ear antennas.
If that makes sense.
#5794
I shoot people
I don't think it's a bad idea, because I HAVE seen people hold a speedlite with one hand, stretched out (slaved)... But for $125 (B&H), I'd rather just put a big bounce card on the flash and use the technique of holding the flash out with one hand, and deal with the camera with the other.
#5797
Interesting....... may really look into this.
http://photography-on-the.net/forum/....php?t=1270039
I haven’t been posting much here on POTN recently but did want to bring a new piece of flash gear to the attention of POTN’ers. If a powerful, bare bulb, remotely-controllable, non-TTL flash sounds interesting, read on.
Let’s get the disclaimer out of the way first: I’ve been working with Edward Tang of CheetahStand as a beta tester of his new CL-180 flash for the better part of a year now. I have absolutely no financial involvement with this product whatsoever and do not stand to profit from it in any way. Edward is a friend and I help him out with product development and testing every so often purely as a friend. As this flash can be viewed as a successor to the greatly missed “Sunpak 120J, I thought the soon-to-be available Cheetah Light CL-180 might be of interest to forum readers.
So what we have here is a shoe-mountable flash unit somewhat larger than a Nikon SB-910 or Canon 600EX. The Cheetah CL-180 is rated at a bit over 150Ws of power; slightly more than a Quantum QFlash. It’s a bare bulb unit as mentioned above and is able to accept a variety of head-mounted accessories which includes a standard 5” reflector, two types of snoot, folding 19” octabox/beauty dish, and a cleverly designed umbrella holder with dedicated reflector. It is also compatible with virtually all existing Quantum/Lumedyne mount accessories. The only exceptions I’ve encountered are the Lumedyne snoot and the Lumedyne ANEC mount adapter. The diameter of these two accessories is fractionally too large for the CL-180.
An additional potentially attractive accessory which I was unable to test is the Cells II transmitter. The Cells II enables high speed sync with Canon cameras.
Here's the flash with radio receiver and umbrella mount, battery pack, and transmitter:
Power output of the flash can be varied from 1:1 down to 1:128 in third stops using the rotating dial on the back of the unit. A focus assist lamp and audible recycle alert are also provided.
The accessory of greatest interest would have to be the radio transceiver set. The small receiver plugs into the side of the flash while the transmitter sits in the camera hotshoe. The transmitter can control various flash functions but, most noteworthy, is its ability to control flash power. The current flash power setting can be seen on the transmitter’s backlit LCD screen. Range is very good. The flash triggered reliably at unobstructed distances in excess of 500 feet during beta testing. Of course, multiple groups and multiple channels are supported.
This is a view of the flash from the back. Here it has the optional umbrella holder and reflector mounted:
Power for the CL-180 is provided by an external 4500mAh lithium-ion power pack. The pack has two power outlets and a removable battery cartridge. In my testing, a fully charged pack provided over 800 full power pops. Full power recycle time is approximately 2-1/2 seconds. With the appropriate cables (Quantum compatible cables will work) Nikon and Canon flash units can also be powered by the battery pack as can Quantum flash units.
The preceding should not be taken as a review. It’s intended as a product announcement. That said, I will add that the test units functioned flawlessly throughout the long beta test period. I believe Cheetah will have the CL-180 and accessories available some time later in February.
#5798
interesting. cost?
#5800
600+ ?
