Chevrolet: Corvette News
Old Dec 18, 2003 | 02:24 PM
  #201
Maximized's Avatar
I bet it will be N/A in the end. It's pretty easy to make that amount of hp in a small block chevy.
Old Dec 18, 2003 | 02:28 PM
  #202
gavriil's Avatar
Moderator Alumnus
Originally posted by 80's Boy
Lets just hope that they are spending a few more bucks on the interior. I hate sitting down in the current C5 and feeling like most of the switches came straight out of a Crapalier.
The interior issues are addressed though dont expect an Audi-like interior. It's just going to be better than the old model.
Old Dec 18, 2003 | 02:30 PM
  #203
gavriil's Avatar
Moderator Alumnus
625 HP from 7 liters is doable though you have to make that motor turn fast. And I have never heard of that size of a motor be reliable at the 7K rpm level (personal guess for achieving that type of HP from 7 liters). Hence the Supercharging.
Old Dec 18, 2003 | 02:42 PM
  #204
Chaptorial's Avatar
That thing is gonna fly.
Old Dec 18, 2003 | 05:56 PM
  #205
Maximized's Avatar
My friend has a sb chevy that was bored/stroked to 427 CI. It is all aluminum and makes 900+ crank hp. The motor is supposedly reliable in it's current state. I am sure Chevy engineers can make a 625+ hp N/A engine that revs fairly decent. Heck, In 1969 Chevy had the L88 which made roughly 550 hp thru a carb.
Old Dec 18, 2003 | 06:03 PM
  #206
gavriil's Avatar
Moderator Alumnus
3 things:
1. As you said, your friend's motor is "supposedly" reliable. Your friend I bet has no way of knowing because of lack of resources (test facility, big bucks, know how, etc).
2. I bet your friend has no idea about what emissions his engine puts out. And I bet they are off the charts compared to federal law (I wont examine, noise regulations and noise levels period, NVH, etc)
3. 550HP in the 60s was gross power which is about 60% of that today. Generally speaking 550 HP in 1969 is about 330HP today.
So it aint that simple.
Old Dec 18, 2003 | 06:15 PM
  #207
Crazy Bimmer's Avatar
damn only 2900lbs?!?!
Old Dec 18, 2003 | 06:46 PM
  #208
Maximized's Avatar
3 things:
1. The motor was in a drag car, which bent the frame because of the tq. It was very reliable in this car and was slightly detuned for road racing. It was built by a well know engine builder who blueprinted it and dynoed it.
2. It won't pass new car emmissions and is too loud for use on the street. The car that it's going to be used in is exempt from emmisions in IL, so its not a problem for them. It could be made quieter with the use of chambered mufflers, but at the expense of hp and tw.
3. The 550hp-600hp SAE Gross that was quoted was crank hp. That's rougly 450-500hp by todays standards running thru a carb without todays modern CAD/CAM design. Im sure Chevy can make a 625 hp N/A engine that can pass emmissions, but it might be pricey.
Old Dec 19, 2003 | 12:55 PM
  #209
heyitsme's Avatar
think the 500 zo6 will be enough to beat the gt. ligenfelter already has the 427 zo6 on the streets with 500hp
Lingenfelter Performance Engineering (LPE) developed new Nikasil-coated iron cylinder liners that replace the stock thin-walled units. These new liners allow a 4.125-inch bore, 0.225-inch larger than stock. Combine that with the longer four-inch stroke, and voilà! you get 427.6 cubic inches. Yes, we know 427.6 rounds to 428, and we include that number in our spec panel. For historical reasons, Lingenfelter says he's sticking with 427.
Meanwhile, GM Performance Parts also released its own big-bore version of the LS1 block. It too permits a 4.125-inch bore and is the same block used in the 24 Hours of Daytona-winning Corvette C5R. Since it is meant for racing, it's a beefier, stronger, and more expensive block than the stock unit.
Enlarging an LS1 by 82 cubic inches takes a bunch of work. Add up a lot of labor and new engine internals, and the $22,650 price doesn't seem so obscene. If you want to use the GM Performance Parts block, as our 2001 Z06 test car had, add another four grand. These are the prices for Z06 Corvette conversions, with their better-breathing heads and intake system. If you have a standard C5 Vette, figure in an additional three grand to cover the cost of new Z06 heads and intake. And don't forget the added charge of shipping your car to Lingenfelter's shop in Decatur, Indiana.
If those prices make your sphincter flutter, keep this in mind: In 1966, engines were not nearly as durable and required frequent valve adjustments, tuneups, and general maintenance to keep them in top condition. And don't forget that back then hard starting, stalling, and carburetion hiccups were all part of the package. Those problems do not exist in Lingenfelter's new engine, which ticked easily through our track testing. Lingenfelter says that the 427 needs no more maintenance than a stock Vette, and he even warrants his engines for two years or 24,000 miles.
But you don't care about oil changes. You want to know what kind of stomach-sucking numbers the 427 Vette can muster, and our test car did not disappoint. How does 0 to 60 mph in 3.4 seconds grab you? Or 0 to 100 mph in 7.8 seconds? That's almost a full second quicker to 60 mph than the stock Z06.
The 427 similarly rips through the quarter-mile in 11.7 seconds at 124 mph and on to 150 mph in only 18 seconds flat—both quicker than any other production car built today.
One reason for the 427's strong numbers is the smooth way it doles out the power without the tires breaking loose. Unlike Lingenfelter's turbo conversions (see sidebar), which add power in explosive bursts when the turbos spool up, the 427 pulls consistently from idle to the 6000-rpm redline. A twitchy foot will, however, easily break loose the stock 11.6-inch-wide rear tires.
Part of the 427's magic is the snap in your seat that turns up every time you stand on the gas. We like the turbo motors because they are so docile when they're not generating any boost, but with the 427, there's no turbo lag before the serious kick throws you back in your seat. And yet the 427 suffers no drivability loss. Spend some time in this 427, and you soon see why Corvette guys find that three-digit combo so alluring.
Lingenfelter Performance Engineering, 1557 Winchester Road, Decatur, Indiana 46733; 219-724-2552; www.lingenfelter.com.
LINGENFELTER 427 Z06 CORVETTE
Vehicle type:: front-engine, rear-wheel-drive, 2-passenger, 2-door coupe
Price as tested:$78,173 (base price: $71,778)
Engine type:pushrod 16-valve V-8, aluminum block and heads, GM/LPE engine-control system with port fuel injection
Displacement428 cu in, 7007cc
Power (SAE net)500 bhp @ 5800 rpm
Torque (SAE net)530 lb-ft @ 4400 rpm
Transmission6-speed manual
Wheelbase 104.5 in
Length 179.7 in
Curb weight 3275 lb
Zero to 60 mph 3.4 sec
Zero to 100 mph 7.8 sec
Zero to 110 mph n/a
Zero to 130 12.7 sec
Zero to 150 mph18.0 sec
Street start, 5-60 mph 4.4 sec
Standing 1/4-mile 11.7 sec @ 124 mph
Braking, 70-0 mph 152 ft
Roadholding, 300-ft-dia skidpad 0.98 g
EPA fuel economy, city driving 18 mpg
Old Dec 19, 2003 | 08:30 PM
  #210
charliemike's Avatar
Fahrvergnügen'd
4-spd Automatic? Get that crap out of here ...
Freakin' Hyundais have 5-speed autos now.
Unbelievable.
Old Dec 19, 2003 | 09:40 PM
  #211
gavriil's Avatar
Moderator Alumnus
Unbelievable.
I am guessing that will be fixed with a 6 speed automatic tranny a year or 2 later.
Old Dec 19, 2003 | 09:46 PM
  #212
gavriil's Avatar
Moderator Alumnus
11.7 is Ford GT territory. Nice job and the price is not totally outragous. You could get a Viper RT for this kind of performance though you will pay a few thousand $ more. It almost makes sense.
Old Dec 19, 2003 | 10:10 PM
  #213
gavriil's Avatar
Moderator Alumnus
Notice how much lower that suspension sits with the new car. Or at least how much more room there is between the rear fender edge and the tires with the current car. Looks dropped from the factory.
Old Dec 20, 2003 | 08:58 PM
  #214
dozorca's Avatar
Looks lower because they secure the car to the truck so it won't bounce during transportation... thats why...
Old Dec 22, 2003 | 07:13 AM
  #215
Fahrvergnügen'd
It's ridiculous that they don't have that transmission ready.
From the day they released the C5 to production they should have started working on a 5 or 6-speed auto tranny.
I can't find the breakdown of auto vs. manual transmissions but I'm going to assume it's 50-50 or higher for the auto.
There's no excuse for releasing the new car with a 4-speed auto.
Old Dec 22, 2003 | 07:32 PM
  #216
vuduvida's Avatar
different shot of the rear:
Old Dec 22, 2003 | 08:18 PM
  #217
gdubb's Avatar
Mazda3 and Honda Civic in
How did I miss this thread?
I hope they make this sick car
Old Dec 22, 2003 | 08:32 PM
  #218
spiroh's Avatar
It looks like I found my new car
Old Dec 22, 2003 | 09:10 PM
  #219
gavriil's Avatar
Moderator Alumnus
Source: supercars.net
Old Dec 22, 2003 | 10:00 PM
  #220
SiGGy's Avatar
Moderator Alumnus
Interesting, I wonder if they will build it.
My guess says I would still rather have the GT40 on looks. But I'll wait and see if this monster exists. Easy for anyone to make something faster on paper
Old Dec 22, 2003 | 10:53 PM
  #221
vuduvida's Avatar
damn, I can't edit my post at the bottom of the previous page. Ignore that pic. It's a good chop job. I found the unchopped version here: http://palmeter.com/C6Spy31.jpg
Old Dec 23, 2003 | 12:31 AM
  #222
cusdaddy's Avatar
It has headlights almost exactly like the 360... Very nice IMO
Old Dec 23, 2003 | 08:39 AM
  #223
gavriil's Avatar
Moderator Alumnus
I was gonna say...that looks fake and...ugly. Do you want me to delete the pic?
Old Dec 23, 2003 | 08:40 AM
  #224
gavriil's Avatar
Moderator Alumnus
First thought was, looks like the Viper RT. Looks nice, I agree.
Old Dec 23, 2003 | 08:45 AM
  #225
gavriil's Avatar
Moderator Alumnus
Bedeviled Vettes: Chevy mum about plans for 600-hp C6 supercar
By AUTOWEEK
Chevy is not confirming the existence of a super-high-performance Corvette called the Blue Devil (AW, Dec. 22), but officials acknowledge it’s possible that engineering and racing development prototypes based on the sixth-generation Corvette do exist and may have picked up the moniker.
And yes, as many AutoWeek readers have suggested, the Blue Devil name was chosen intentionally to catch the attention of General Motors CEO and Duke University Blue Devil alus Rick Wagoner.
Chevy officials say they have no production plans for the 600-hp, 7.0-liter V8-powered Blue Devil, despite information obtained by AutoWeek pointing to a 2006 production debut of the $100,000 sports car. The production C6’s worldwide premiere is just days away at the Detroit auto show.
Source: Autoweek
Old Dec 23, 2003 | 10:49 AM
  #226
chungkopi's Avatar
hail to the victors
looks just like a viper!!
Old Dec 23, 2003 | 02:03 PM
  #227
vuduvida's Avatar
yeah, delete it please. Thanks. No point in having Photoshopped pics here when we'll have tons of real pics in a couple weeks after the unveiling in Detroit.
Old Dec 23, 2003 | 02:10 PM
  #228
Well sign me up.
Old Dec 23, 2003 | 03:16 PM
  #229
danny25's Avatar
Old Dec 23, 2003 | 05:13 PM
  #230
Collective27's Avatar
Certified Lurker
hot as hell, i love it.
One thing i dont like is it dosent say corvette across the middle between the lights its on the bottom right...not feeling that.
Old Dec 23, 2003 | 07:03 PM
  #231
heyitsme's Avatar
the interior is changed but i don't think improved
Old Dec 23, 2003 | 08:21 PM
  #232
danny25's Avatar
i think it's improved, but not by a lot
Old Dec 24, 2003 | 11:40 AM
  #233
goat's Avatar
the steering wheel is just way too big, and it ruins everything. it just takes away all your attention, and not to mention, sucks the big one! they should have just shop lifted the cadillac XLR interior!
Old Dec 24, 2003 | 04:15 PM
  #234
gavriil's Avatar
Moderator Alumnus
The steering wheel is awful looking.
Old Dec 24, 2003 | 04:16 PM
  #235
gavriil's Avatar
Moderator Alumnus
Interior looks nice and looks like the quality is upped by a lot. Is it Audi level? No way, though it now looks acceptable. Nice.
Old Dec 24, 2003 | 04:17 PM
  #236
gavriil's Avatar
Moderator Alumnus
Crazy Sellout kudos to you sir. Very nice find.
Old Dec 24, 2003 | 04:24 PM
  #237
I just steal from the rich and give to the poor :o
Old Dec 24, 2003 | 09:26 PM
  #238
gavriil's Avatar
Moderator Alumnus
Hehehe...
I guess the poor are all of us here in this forum right Crazy?
Old Dec 24, 2003 | 09:37 PM
  #239
Hehehe...
poor, stupid.... same thing
Old Dec 26, 2003 | 02:22 PM
  #240
gavriil's Avatar
Moderator Alumnus
Oh so now we are poor AND stupid. I see
