BMW: 3-Series News
Old 08-09-2006, 10:57 AM
  #1841
derrick's Avatar
I can see why CS likes the 328 rims ... look just like BBS rims.
But the 3-series coupe will sell like hotcakes for very reason why Beltfed has mentioned. I would consider getting one but can't justify the 'snootiness' that comes along driving a BMW. If I were to lease it for the short term, then it would be OK, but I plan on buying my next car so no to BMW & maintanence costs.
I just don't 'get' the yellow reflector right near the wheel well. It's just like on the G35 coupe ... something's bad to happen when it's placed there.
Old 08-09-2006, 11:34 AM
  #1842
Yumcha's Avatar
Received 22,663 Likes on 13,899 Posts
Post Top Gear review: Too literal, too passionless...
Aw shucky-darns!
Here we are, 130 years since Messrs Otto, Benz and Maybach got together and sort-of-perfected the four-stroke, and the contraption's still got life in it. In the hands of BMW, it's improving at an ever-accelerating pace.
This new direct-petrol-injection twin-turbo is just astonishing. Imagine the high-rev brilliance of your usual BMW straight-six. Add to that the low-rev torque of the best diesel engines - only with far, far better refinement. It's even economical... if you can bear to drive it gently.
Actually this is such an athlete of an engine - and it's mounted in a car that handles big speeds with such effortlessness and grace - that I reckon your friend in his M3 is going to have to pedal pretty hard to stay ahead of you. Which means that to keep the required headroom above the 335i, the next M3 (V8 engine and all) is going to have to be pretty darned swift.
Of course, the 3-Series Coupe isn't always about keeping up with anyone on the road. It's about keeping up appearances. To that end, this brand new, two-door version of the E90 3-Series is actually more different from the four-door than ever before.
The roof is pressed down, the tail's longer, and both front and rear ends are lower. The saloon's gawky five-sided rear lights have given way to a wraparound horizontal set. BMW says the whole thing looks squatter, wider and sleeker, and in itself that's undeniable.
But something else strikes me. BMW's design language has been toned down here, so as not to scare off any of the 3-Coupe's ultra-broad buyer pool. But toning down the more confrontational surfaces doesn't seem to have brought any special beauty. Instead it leans to the bland.
If you were shown the side profile (maybe with the characteristic 'Hofmeister kink' - the angled portion to the inside edge of each C-pillar - blacked out) and told it was a new Honda accord coupe, you'd not be so surprised.
But take it as a whole and it couldn't be anything else but a new 3-Coupe. Not with that nose and tail, and certainly not once you add a set of the enormo-wheels BMW buyers seem delighted to stump up so much extra for.
The 320i and 320d versions will doubtless roll as standard on diddy little sofa castors, for the sole reason that BMW can grab the profit opportunity of purveying upgrades. The 335i is better off, as it gets 17s as standard. Yet even 18s manage not to look quite big enough, so 19s might be de rigueur.
A coupe mustn't just look different, it ought to feel different from a saloon. sitting in it, the 3-Coupe obliges. The dash is basically as per the saloon, but the lower screen line and more inclined driving position feel just a little bit racier. It's OK for grown-ups in the back, though no one would want to be climbing in and out too often unless they were in training for a pot-holing weekend.
Does it feel different from a saloon to drive? Not terribly. Certainly not if you optioned the saloon with the same hopped-up powertrain, suspension and tyre packages that the Coupe has. And you can: from this autumn, all the Coupe's engine range will be available on any other 3-Series body.
At first meeting, the 335i engine doesn't exactly run up and greet you in a big friendly hug. Press the start button and it idles a little gruffly. But get a few revs on and the thing really does become your friend.
The peak torque arrives at 1,300rpm, and stays on the same high plateau until 5,000. OK, if you go looking for it there's some turbo lag at the very lowest revs, but beyond 2,000 it picks up and runs like a giant V8.
Engines with such a wide working range are very rare. The only one that comes to mind is VW's new twin-charger 1.4. Sure there are diesels that go this low, but can they sing to 7,000rpm? Don't be daft. And the higher the revs go, the more it sounds like what it is, a BM straight-six petrol engine, which is good news indeed.
So there's an ocean of easy, stealthy performance. In absolute flat-out acceleration, it isn't actually far ahead of the non-turbo 330i (272bhp vs 306), but it's easier to make swift progress along give-and-take roads, and to overtake, because the urge is so accessible.
This easygoing nature means you don't have to be too pernickety with your gearshift timing. Just as well actually, as there's some shunt in the driveline, and the six-speed manual transmission is on the clunky side. BMW used to be good at this.
Still, the alternative is a six-speed auto and it's really good. I say this as someone who normally detests autos. But this one changes fast, almost always locks up its torque converter (so it feels like a manual) and answers immediately to the lovely, aluminium steering-wheel paddles.
On the go, you could easily imagine it was a DSG. But wafting through towns, it's smoother than a DSG. Best of all worlds? Pretty much.
I drove with and without the £925 active steering and preferred it without. Self-centring in straight running is more natural when the fancy gadget is absent, and so is the initial feel into corners. But either way it's a really fluent and obedient car.
It never does anything unexpected. In streaming wet corners, it keeps superb balance, and you can press a DTC button that calls up a slightly looser traction-control setting, so you can push harder before the electronics intervene, but still be saved from yourself.
In the dry you get heaps of grip, though the huge torque makes it easy to spin the inside rear wheel coming out of tight bends. Habitual drifters would want a limited-slip diff, but it's unavailable. Oh, and does the ride have to be so hard?
And now the science bit. The engine is actually a three-litre (so why not call it 330Ti?). It's not just the turbos that make it special but direct injection. This allows enough control that they can use good boost at low revs and get clean emissions and low consumption. There are two turbos, each of them feeding three cylinders. That makes them small and quick to spin up, cutting lag time.
The lovely cornering balance is the reason why the twin-turbo six is such a good idea. The engineers say it mostly performs like a four-litre V8. It does. But it's a lot lighter than a V8. And not just because the engine itself is lighter than a big V8.
To get the same low-down torque as the turbo six, a V8 would develop higher peak torque. That would mandate a bigger gearbox and stronger driveshafts. you'd need a bigger battery. That would add enough weight that you'd be talking about bigger, heavier brakes. One engineer told me that might mean 200kg in all, which could turn the 3-Series into a right old barge.
The 3-Coupe will soon come with seven engines. Count 'em: 320i, 325i, 330i, 335i, 320d, 330d and 335d.Yyes, the mighty 286bhp twin-turbo diesel is coming down to the 3-Series from the 5. Should kick up some dust. All will also be available in saloons and Tourings from late this year.
And a car with the Coupe's silhouette will eventually get yet another engine. This is the next M3, with a 400bhp V8. To offset the weight of the V8, it'll have lightweight panels, even probably a carbon-fibre roof.
And they're just in the process of deciding whether it'll get the M5's seven-speed SMG transmission or a manual, or even a dual-clutch device that's still under development. Sounds like a pretty committed car, from the committed people of BMW M.
The final 3-Series bodystyle will be the next Cabrio. This one has a folding hardtop roof, the first one of those BMW has done. I asked Wilhelm Becker, the man responsible for development of the whole 3 range (and the Z4 and X3 and 1-Series, busy bloke) why it is, when everyone else says a Coupe-Cabrio is two cars in one, that he is going to launch both a Coupe and a CC.
He said the Coupe is for people who want a proper lightweight sporty car, and the CC is much heavier. The CC will be positioned as convertible that you can use all year round. A refreshingly honest answer.
But actually the Coupe itself is a mere 10kg lighter than the saloon, even though it does have plastic front wings to keep the nose weight down. Becker promised me the next all-new 3-Series saloon, due in 2012, will be lighter than the current model. If he achieves that he'll be a hero - this feat has so far only been achieved by specialist cars like the Audi TT and Jag XK.
But for now we've got the 335i and it's an unimpeachably good car. At £33,420 there aren't any obvious rivals. To match the price, Mercedes has the CLK 280, but to match the power you'd need to pony up £47k for a CLK 500.
A new TT 3.2 isn't as fast, either. If you don't need the back seats, though, the new base-model Cayman would be a whole lot more fun to drive, if noisier on long journeys.
As usual, BMW's 3-Series is displaying amazing breadth. Most cars have an obvious sweet spot in the range. Usually that's somewhere near the bottom of the list, because if you pay too much you get more power than the chassis can handle (see Saab, Volvo) or too much tinsel for the fundamentally cheap interior (Fiats, Peugeots).
But the 3-Series manages to make some kind of sense as a stripped-out 130bhp base model, without this 306bhp job feeling out of its depth. To do that you need really sound fundamental engineering.
If anyone ever comes to you and says, "Hey, you're supposed to know about cars aren't you? What car should I buy for £x?" the answer is easy. £x can be any sum between £20,000 and £40,000, really. Your role in the conversation is to look thoughtful and say, "BMW 3-Series". Can't go wrong: it's simply a matter of determining which model.
The 3-Series is beautifully engineered and finished; some models are quick, some are economical and most are both; it handles like a dream; it looks just fine; and it holds onto its value.
Yet here's a thing. Here's the best-looking, fastest, most fun 3-Series of the lot. Sure to be the most widely admired and desired. But is it sexy? Absolutely not. There's something slightly haughty and offhand and reserved about this thing. Too perfect, too literal, too passionless. And sorry generalise, but I tend to ascribe the same qualities to its owners.
Does my view of those drivers inform my view of the car? Or is it the other way around? Probably a bit of both to be honest, but the result is BMW has bust a gut to build a brilliant 300bhp-plus two-door sporting coupe and I can't quite fall in love with it.
Old 08-09-2006, 12:42 PM
  #1843
Crazy Bimmer's Avatar
Pricing 07 Sedan
http://www.e90post.com/forums/showthread.php?t=25892
Old 08-11-2006, 02:22 AM
  #1844
Yumcha's Avatar
Some 1/4 mile and 0-60 stats are coming in from reviews...Courtesy of Leftlanenews...
Car magazines are beginning to publish statistics from their in-depth tests of the new twin-turbo BMW 335i coupe. According to Automobile magazine, the four-seater can hit 60 mph in just 5.1 seconds — compared to the current M3's 4.8. Meanwhile, the quarter-mile sprint takes 13.6 seconds, according to the magazine — only slightly slower than the M3's 13.4 second run. 0-100 mph for the 335i takes 12.7 seconds, compared to 11.5 for the M3. Over in Germany, Auto Zeitung is reporting a 0-62 mph time of 5.3 seconds, 0-100 mph time of 11.9 seconds, and a 0-124 mph time of 18.7 seconds for the automatic version of the 335i. Overall, it seems the new six-speed auto performs almost identically to its manual counterpart. However, the 0-100 mph time appears to be significantly faster for the automatic version.
Old 08-11-2006, 09:54 AM
  #1845
Fahrvergnügen'd
charliemike's Avatar
Received 1,568 Likes on 985 Posts
286hp TT diesel? WOOF ...
Stupid American market.
Old 08-11-2006, 10:24 AM
  #1846
Moderator Alumnus
gavriil's Avatar
Yeap!
https://acurazine.com/forums/showthr...96#post4960096
Old 08-11-2006, 08:38 PM
  #1847
Test - M3 - 335i
0-60 - 4.8 - 5.1
0-100 - 11.5 - 12.7
0-110 - 14.5 - 15.6
0-120 - N/A - 18.6
0-140 - N/A - 28.2
1/4 mile - 13.4@105 - 13.6@104
peak g - 0.7 - 0.68
30-70 (6th) - 14.7 - 12.5
30-70 (3rd) - N/A - 6.5
70-0 - 162 - 150
Peak g - 1.12 - 1.12
Weight - 3480 - 3560
%F/R - 50.6/49.4 - 51.1/48.9
Redline - 8000 - 7000
Power - 333 - 300
Torque - 202 - 300
Tires 255/40 ZR-18 255/35 WR-18
http://www.automobilemag.com/feature...i_dynamometer/
Old 08-11-2006, 08:56 PM
  #1848
Pinky all stinky
phile's Avatar
Wow, that's fast. Looks like the only lead the Lexus IS had over the 3-Series, which was straight line acceleration, is now gone.
Old 08-11-2006, 08:58 PM
  #1849
275 rwhp and 300 lb-ft to the wheels is just nuts.
Holy underrated
Old 08-12-2006, 01:33 PM
  #1850
Moderator Alumnus
gavriil's Avatar
Originally Posted by Crazy Sellout
Ha! See what torque does. The flexibility numbers (30-70) prove the 335 is quicker than the M3.
The 335 will certainly feel quicker than the M3 in real world driving conditions. Just as the C6 feels so much quicker than the 911.
Old 08-12-2006, 01:37 PM
  #1851
Moderator Alumnus
gavriil's Avatar
From the above link, very interesting piece:
We used a DynoJet chassis dyno, which measures an engine’s power output at a vehicle’s rear wheels. Because of frictional driveline losses, this number is always lower--generally by fifteen to twenty percent--than the quoted power output from the manufacturer, which is measured at the engine itself.
Here’s what we found:
The non-turbocharged 330i, rated by BMW at 255 hp and 220 lb-ft of torque, puts about 200 hp and 180 lb-ft to the rear wheels. That’s roughly a twenty-percent loss. Since they have similar drivelines, you’d expect the 335i to put down 235 hp and 250 lb-ft.
But it didn’t. It put down a whole lot more: 275 hp and 300 lb-ft. A few quick taps on our trusty calculator shows that this engine is likely putting out closer to 350 hp and 360 lb-ft of torque.
Technical editor Don Sherman’s ears perked up at all this number crunching. With all that power, he wondered, is the 335i faster than the outgoing 333-hp E46 M3? We waved goodbye to the shiny new coupe’s rear tires, and sent him to find out.
Don coaxed the 335i to 60 mph in 5.1 seconds--only 0.3 seconds slower than the M3. The 335i covered the quarter-mile in 13.6 seconds @ 104 mph--again, only 0.2 seconds and 1 mph behind the M3.
So in an all-out drag race, the 335i comes close, but can’t quite match the M3’s blistering acceleration. Those numbers, though, only tell half the story. Have a look at the top-gear acceleration figures. In sixth gear, the M3 needs 14.7 seconds to get from 30 to 70 mph – but the 335i does it in only 12.5.
That, my friends, is the beauty of this engine. At full bore, it’s as fast as an M3. But at moderate engine speeds, it’s even faster. What a great way to keep us all interested until the next M3 comes along.
Test - M3 - 335i
0-60 - 4.8 - 5.1
0-100 - 11.5 - 12.7
0-110 - 14.5 - 15.6
0-120 - N/A - 18.6
0-140 - N/A - 28.2
peak g - 0.7 - 0.68
70-0 - 162 - 150
Power - 333 - 300
Torque - 202 - 300
Old 08-12-2006, 01:38 PM
  #1852
Moderator Alumnus
gavriil's Avatar
^ With the 335 being 80 pounds heavier and I am guessing with longer gear ratios, it totally makes sense. I dont believe it makes as much as 350HP at the crank, but I would believe 325HP.
Old 08-12-2006, 01:44 PM
  #1853
Moderator Alumnus
gavriil's Avatar
Source: autotitre.com
Old 08-12-2006, 01:45 PM
  #1854
Moderator Alumnus
gavriil's Avatar
Who's that old guy driving this on the track?
Old 08-12-2006, 01:46 PM
  #1855
Doom878's Avatar
Received 1,299 Likes on 954 Posts
And it's way cheaper than the M3.
Old 08-12-2006, 01:48 PM
  #1856
Moderator Alumnus
gavriil's Avatar
I would not say way cheaper. In reality there is probably a 5K-7K difference.
Old 08-12-2006, 05:44 PM
  #1857
biker's Avatar
Talk about underrating - must be an insurance thing in Europe.
Old 08-12-2006, 05:47 PM
  #1858
biker's Avatar
And no helmet either.
Old 08-12-2006, 07:19 PM
  #1859
mrdeeno's Avatar
it may be just me, but this M3 looks pretty conservative compared with the last generation. It may just be the "rounded" shape of the current 3-series models.
Old 08-12-2006, 07:30 PM
  #1860
_____ like a rabbit
stangg172004's Avatar
^^ ya, but im thinking thats the camo doing its job, at least i hope so...
Old 08-12-2006, 08:23 PM
  #1861
I been thinking the same but it might be just the pics.
The E46 looked great because it was wider than a 3series. In these pics that doesnt look like it is, but we could be fooled.
Old 08-12-2006, 09:20 PM
  #1862
ajs887's Avatar
Front end looks nice. But it get's all bland at the back. Plus the back looks like it sits up high. Hopefully by adding a diffuser and wider wheel wells it'll look better and more planted to the ground. At this point I still like the look of my e46 M3 better, but who knows when the final product comes out it'll probably grow on me.
Old 08-12-2006, 10:26 PM
  #1863
Moderator Alumnus
gavriil's Avatar
I believe that the black color has more to do with the underwelming look than anything else. The secondary factor is the carefully placed camo, covering all the aggressive lines on the car. It will look just fine when unveild, watch.
Old 08-12-2006, 11:59 PM
  #1864
Moderator Alumnus
Beltfed's Avatar
Do not go by a vehicle that has heavy camo.
I'm sure the M3 will have side vents, flared fenders, hood, M front/rear bumpers....usual exterior enhancements.
Don't judge it just yet.
Old 08-15-2006, 12:24 AM
  #1865
I'm the Firestarter
Belzebutt's Avatar
I love it. Love the tail lights, unlike on the sedan, and all the little sporty touches make it come together. This is going to be a hot car.
Old 08-15-2006, 01:51 AM
  #1866
_____ like a rabbit
agreed
Old 08-15-2006, 06:45 AM
  #1867
Living the Dream
cmschmie's Avatar
Just kind of curious, and it may be earlier in this thread, but it's a little long for searching....
Does anyone know of the performance numbers of this M3? How will it compare to the S4/RS4?
All I know is.......I want one damnit!! 2 or 4 door....I'll take it.
Old 08-15-2006, 11:32 AM
  #1868
Nope, nothing yet.. just rumors.
Rumor, v8 with 400+hp.
(ill guess a 425hp v8 starting at $55k)
Old 08-15-2006, 12:28 PM
  #1869
Maximized's Avatar
This car has some huge shoes to fill. The competition has gotten fierce since the E46 M3 was introduced. I am hoping that BMW finds a way to keep weight in check on the new model. A 400hp V8 isn't going to cut it if the car weighs 3600+ lbs.
Old 08-16-2006, 01:12 AM
  #1870
K-Fed's Stunt Double
broly's Avatar
How dare some people compare to this toan M3 lol
A brand new m3 is 10k more stock. It's gonna be about 10 more in reality too.
The M3 is the M3, you can't compare a 335i to it . You think BMW would release a competitor to it's own car? THe m3's interior now is still probably some of the nicest I've seen, and even though it may not have gadgets liek HD RADIO it is the true fanatic's car
Old 08-16-2006, 01:31 AM
  #1871
Pit Stop?
Minch00's Avatar
Are you fucking daft? Let's see, it's a BMW, it's a coupe, it's RWD, and it has roughly the same performance figures as an M3. WHY WOULDN'T WE COMPARE IT TO THE M3!? You know why, because the M3 is about 6 year old technology at this point, and the NEW M3 will reinstate your lauded "fanatics car" terminology compared to the rest of the BMW 3-series line up. However, with the introduction of the 335i, to buy an E46 M3 brand new seems a bit.............well, like a waste.
To say you can't compare a 335i to an M3 is like saying you can't compare a man to a woman, sure there are some subtle differences, but the overall performance is roughly the fucking same.
Old 08-16-2006, 01:40 AM
  #1872
broly's Avatar
No it's not you idiot.
How can you COMPARE It? Because OH MY GOD IT"S A COUPE AND Rwd?
There is no car that will inherit SMG. SMG Is THE transmission, 80 ms shifts, twice as fast as ferraris' F1 solutoin. If you really want an m3 you get with smg.
Oh and if it's so good where is the 335I's smg? Even the 330CI Came with SMG ROFL! I remember seeing it was too funny. It was a DAMN JOKE. The 335i isn't meant to be an m3 competitor, it is meant for those who can't afford an M but would want the performance, not the drive.
Old 08-16-2006, 01:41 AM
  #1873
broly's Avatar
Oh and 6? It wasn't even heavily produced utnil 2002, so more like 5.
And who said the car didn't get better with time anyways? The 06 has 'features' just like your TL, pal.
Old 08-16-2006, 01:49 AM
  #1874
chewi's Avatar
calm down.... we are just comparing how the 2 cars have similar dyno performances.
I'm sure they will bring out the 2 cars to the drag to do some quarter mile times.
  #1875
Pit Stop?
Minch00's Avatar
Not sure who you think I am, but I don't drive a TL, pal. SMG is the transmission 16 year old girls get in their high school graduation M3s because they don't know how to drive stick. A proper 6-speed manual is THE transmission for anyone with half an ounce of automotive enthusiasm in their blood. No amount of computers and aids will ever replace the skill of heel-toe, proper downshift and rev-matching, and precise throttle control that..........wait for it...........a true fanatic would be fanatical about being able to achieve.
Old 08-16-2006, 09:22 AM
  #1876
ilitig8's Avatar
Sorry but your wrong about the SMG, it is not THE tranny in fact it won't be long before you can't buy a new BMW with one, but that is another story. You also are incorrect about it being twice as fast as the F1 tranny in the F430, the issue there is the method of measuring the time for shift which varies between BMW and Ferrari. The SMG is best left on the track, the manual can live in both lands equally well but requires a better driver to extract the last bit of performance on the track.
I must admit I am a little biased given my M3 is a three pedal car.
In general the comparison is valid, if the 335 wasn't a BMW I don't think anyone would blink if they were compared. The 335 is a newer car and has some advantages as a result. The M3 is certainly a more focused car and will win in any performance category sans maybe mid range flexibility and would certainly shine in lap times compared to the 335. Given the choice I would pick the E46 M over the 335 E92 but given the probably tunability and the newer chassis they both beg a look if you plan to drop 45-60k on a sport coupe. But even given a 10k price difference if all-round performance is what you seek by the time you mod the 335 to meet the M3 in acceleration, braking and handling the 10k you save will dissapear and likely more, plus it is unlikely you will ever reach the feel.
Old 08-16-2006, 09:29 AM
  #1877
ilitig8's Avatar
I think you probably went too far as well, the SMG has its place...the track. I agree that there are those of us who prefer the satisfaction of three pedal lap times but we are unlikely to ever match our potential in a SMG car. One must never forget the VAST majority of road racing cars use an SMG of some ilk. Last time I checked Michael Schumacher is pretty fanatical and despite this has raced every one of his GPs in a car equipped with a sequential manual.
Old 08-16-2006, 12:21 PM
  #1878
Maximized's Avatar
The future of transmissions are DSGs. Porsche, for example, stopped R&D on a SMG and dedicated itself to DSG technology.
Old 08-16-2006, 12:58 PM
  #1879
Moderator Alumnus
gavriil's Avatar
LOL
Old 08-16-2006, 01:04 PM
  #1880
Moderator Alumnus
gavriil's Avatar
Relax guys. The 335i can be compared to the M3 only with regard to price and straight line acceleration (from a stand still or not). Certainly the M3 is a more sporty/track tuned car than the 335. Actually BMW has admited that they tried to make the 335 even "softer" than the previous gen. 3er coupe model. It's got more GT character than the previous gen. model that is. So far from an M3 with respect to handling, agility, reflexes, etc.
But as a daily driver and a cruiser, it sounds, at least on paper, as being the right choice.
Quick Reply: BMW: 3-Series News
