Need Some Amp Opinions Please
Old Jun 10, 2005 | 06:20 PM
AcuraX2's Avatar
I just sold my amp for the Pilot and I am looking at new 5 channel amps. Here is my list so far. I am probably buying a good used one or a great deal on a new one.
Arc Audio 5150XXK ($335-$400)
US Amps 5600x ($375)
JL 500/5 (maybe a bit out of my price range)
I am running Diamond Hexes up front and an Image IDQ 10" sub. I am thinking of running the Hexes active and biamping.
Any suggestions and opinions would be appreciated. Thanks.
Old Jun 10, 2005 | 08:08 PM
elduderino's Avatar
VP Electricity
How about a DLS Classic CA-51?
50 w 4 RMS, 80 x 4 typical, plus 150W x 1 at 4 ohms and 225W x 1 at 2 ohms.
three independent xovers, and a 0-180 phase switch, high-level in and auto-start if you need it.
Old Jun 10, 2005 | 08:12 PM
dark inspire's Avatar
El Presidente
how much do those DLS amps usually go for?
Old Jun 10, 2005 | 08:17 PM
elduderino's Avatar
VP Electricity
MSRP is $350.00. : )
Old Jun 10, 2005 | 08:25 PM
El Presidente
that's not bad!
Old Jun 10, 2005 | 10:18 PM
OCguy's Avatar
Id say US Amps cant go wrong there.
Old Jun 11, 2005 | 03:12 PM
optomos's Avatar
I=X - optomos
DLS or USamps. I like the auto start feature on the DLS's.
Old Jun 11, 2005 | 06:40 PM
I'm Batman's Avatar
Boom goes the Dynamite
Yeh, but does it have remote start?
Old Jun 11, 2005 | 06:46 PM
AcuraX2's Avatar
Well the US Amps is out. He sold it already. I really like the idea of the Arc but, will it be enough power for a set of Diamond Hexes?
Old Jun 11, 2005 | 07:03 PM
AcuraX2's Avatar
Also, I am really thinking about running the Hexes active and biamping. But, if I run a tweeter and a mid of seperate channels, does anyone know the impendence of each driver? The system impendence is 4 ohms. Is each driver 2 or 8 ohm or do they do it differently. If they were 2 ohm each, then the Arc would send about 75 watts to each driver. That sounds pretty good. Am I close to the right track?
Also, are there any other 5 channel amps I should look at?
Old Jun 11, 2005 | 07:31 PM
shawhite's Avatar
hey acurax2 been a minute since i have posted on here but i had to throw you a quick suggestion.. i personally like arc amps.. but how are you planning on running the amp... is it powering anything in the rear or are you going to bridge it and power just the hexes and sub with it.. if so go with a 4 channle amp...
also have you looked at the zapco or the diamond audio amps...
Old Jun 11, 2005 | 08:46 PM
optomos's Avatar
I=X - optomos
The woofers are 4ohm@150watts minimum/300max. The tweets are 8ohm@50watts minimum/100max.
I would get 1 4channel amp & 1 1channel mono amp to drive the sub.
Old Jun 11, 2005 | 09:30 PM
AcuraX2's Avatar
Shawhite...good to hear from you. been a while. I am looking at running my Diamond Hexes active and use each of the 4 channels to drive one driver. Then the 5th channel for the sub. Diamond amps are too big for my install and Zapco does not have a one amp solution in my budget.
optomos...I am looking for a single amp solution, not two for space reasons. thanks for the specs.
Old Jun 12, 2005 | 05:28 AM
xX24Xx's Avatar
audio sq guru
Arrow
I think Diamond Audio has one too. D7 series... I know its a 5 or 6 channel. Check it out!
Old Jun 13, 2005 | 01:43 PM
AcuraX2's Avatar
I decided on the Arc amp. I have heard nothing but good and since I am going for SQ, it should do the trick. I think bridging the amp and running 150 x 2 into the Diamond Hexes and 190 x 1 @ 2ohms on the Image IDQ10 should be pretty good. How does that sound?
Old Jun 13, 2005 | 02:03 PM
elduderino's Avatar
VP Electricity
For SQ, wouldn't you run the mids and tweets on separate channels and NOT bridge it?
Old Jun 13, 2005 | 02:20 PM
AcuraX2's Avatar
I have been told two ways to go. Running everything active or bridging and running using the passive setup. I would love to try running them active but, is 45 watts enough? If the tweeter is 8 ohm, will it see even less. I may try both ways to see which works best. I know the Diamond Hex mid likes alot of power to really sound good. From what I have read anyway.
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
